Old 05-10-2017, 01:25 PM   #1
roady61
Default What the Heck is Going on? 81 Volvo 242 WILL NOT SPARK HELPPPPPP PLEASE
Please need some guidance.. 81 volvo 242 W/ B21F MPG . Chrysler ignition. 110K HELP PLEASE 81 242 B21-9/MPG HAS NO SPARK Trying to find out whats wrong . Have read everything I can find related to this issue. PARTS I have replaced ICU mod.and harness,rotor,cap, plug wires, spark pickup inside dist. rotor is turning. coil measures primary 1.3 ohm/ secondary 10.5/ checked white/red wire from icu to #1 on dist its good. checked for voltage at icu green /blue Yes. same at Dist plug both sides .cleaned and checked wires to and at coil/ starter/ micro switch/ ignition switch back. fuse panel and fuses. Any ideas? Thank You
Other coil dont know so I bought a new coil. Still no spark. batt volts. 12.54 -- With key on white/red #1 at coil 11.28. #15 at coil 11.28.-- unplug wire from #1 at coil then # 15 has .01 reading.--- Female end of plug at dist. ign. on point A yellow wire 12.44 volts. -- Point B green wire 12.44 volts -- Point C Black 12.38 Volts..-- Wires at ICU with plug still plugged in green wire 12.44 Volts. large black 12.38 volts. yellow 12.42 .small black 12.37 .orange 12.37. I have tried 3 different ICU units. all are within a small % readings of the next . Have tired 3 spark modules no change. 4 coils no change. .. Not even a tiny spark at the female end at dist at any of the 3 points connectors even with the tiniest of wire. Should there be voltage at # 15 with key on or off With Wire at # 1 disconnected? Wires to starter then to Dist.One diagram shows blue/ yellow --brown on eng. side . then which side goes to coil? then the next diagram for the same model shows a blue wire also to starter . but does not show clearly which goes here. Also is it possible that a wire in the back side of ignition switch is in the wrong hole. It cranks fine aqnd all the dash lights work with key in two positions. Any Ideas> Thank You .
roady61 is offline   Reply With Quote
Old 05-10-2017, 01:28 PM   #2
I recommend writing in paragraphs.
Start at impulse sender. Power and ground? Then check signal out of it with an LED test light.
Old 05-10-2017, 01:58 PM   #3
roady61
What do you mean impulse sender. I dont think this system has a impulse sender unless you mean the spark module inside the dist. I explained that all three wires at female side of plug have voltage. How do you check for ground. Please answer more of what I asked please. Thank you
Old 05-10-2017, 02:04 PM   #4
roady61
I have been working on this problem everyday for over a month trying to solve this.
Old 05-10-2017, 02:06 PM   #5
Run through this diagnostic tree to determine the problem.
image stolen from cleanflametrap.com
Which distributor do you have, the white cap Chrysler or brown cap Bosch?
Old 05-10-2017, 02:12 PM   #6
roady61
I have done that flow chart. It does not explain anything. and is to simplified,
Old 05-10-2017, 02:15 PM   #7
roady61
I have went thought that flow chart 3 or 4 times. Please read what I have asked and said. Thank you
Old 05-10-2017, 02:19 PM   #8
Did you make sure the sleeves are installed?
Old 05-10-2017, 02:27 PM   #9
roady61
Yes it has new sleeves on the plug at the dist. and the icu harness it a newer Volvo one with the small smaller sleeves
Old 05-10-2017, 02:37 PM   #10
roady61
I dont know if if the plug at dist should have voltage at the black wire. should'nt that be a ground somehow? The flow chart at bottom left corner shows check ground but this harness exactly like the old one has only two black wires bigger one that goes to dist plug and other to micro switch. I do think that's something is not grounded or the wires from the ignition switch to the starter are hooked up wrong. Should there be voltage at 15 on coil. with key on or off. there no voltage at 15 with red/white from icu disconnected.
Old 05-10-2017, 03:48 PM   #11
Test sensor in the distributor. IDK if it's hall effect or impulse. If its three wire that should make it hall effect. Check for power on one wire, ground on the other, then signal out on the third. I recommend a scope to check the out signal. Or a LED TEST light will blink.
If it's a hall effect it will produce a square wave that can easily be seen on a scope.
Regular test light to coil negative and check for blinking while cranking is also a test that could be done.
Old 05-10-2017, 04:22 PM   #12
For the third time,
Old 05-10-2017, 05:11 PM   #13
roady61
white cap
Old 05-10-2017, 06:29 PM   #14
Is the foil ground contact for the pick up wrapped under the base plate so that it's making contact with the distributor body? If so, is the distributor body clean where it makes contact?
Old 05-10-2017, 10:25 PM   #15
roady61
It seems that I have used a pick up before with no foil wrapped underneath. But the almost new one im now using the foil was coming off that area so lightly glued the edges of some folded tin foil and made it so it contacted to the top and underneath. Ill have to test the pickup and make sure its making a good contact . and ill lightly brush or sand that edge. Very Good Questions. Something so simple Could be the reason Thank you very very much Would you happen to know if there should be voltage at 15 pos. with the key off ? Or with key on but Neg 1 unplugged. only getting current when cranking at 15
Old 05-10-2017, 10:53 PM   #16
Without a good ground contact, the pick up coil won't output a signal. That foil is a weak spot in the Chrysler distributor and a common cause of problems. There's an updated Bosch distributor that's a direct replacement with the round plug so you can use your harness.
I'm not sure I understand your question. By position 15, do you mean the + side of the coil? There shouldn't be power with the key off, but there should be with the key on and cranking. Without power, the coil can't make spark.
The greenbook has nice wiring diagrams that show the power path with the engine running and stalled.
http://www.volvowiringdiagrams.com/v...20Diagrams.pdf
Old 05-11-2017, 02:04 PM   #17
John242Ti
LH-Jet & Carb Free Zone
John242Ti's Avatar
^Found on later 1983 B23F cars.
Another option is to go with Bosch Breakerless. That and a B cam would give the car an extra 9 hp.
-J
Old 05-14-2017, 02:16 PM   #18
roady61
Hello: Again I want to Thank you all input so far. First a bit of history if ok ? Calif. Car I bought in about 93 had 60k drove it daily for 6 years.to 100k since then it has sat in garage would start up very 3 or 4 months for many years but about 10 years fuel dist plunger was stuck from yearly climate changes . Had to replace that. would start and run until this year did not start up so I took plug wire off to test for spark . cranked it and it sparked a few times then right in the middle of cranking no more spark.So I started cleaning connections ect . one stupid thing I did was remove plug at ignition switch. unclipped the cap to clean the terminals and the wires came out of the holes. got it back together . Guess its right as dash lights gauges and everything else works right. Got a almost new harness and ICU .everything else was good . still no spark. Bought a new coil last week 12 volt no resistor needed I tested primary was 1.5 secondary was 8.5. now after trying the couple of tests suggested here coil was very hot. Would make spark if the neg. side wire was removed. Fixed the spark mod.plate foil wrap very nicely certain to ground it. still no spark. . Im getting voltage only at the blue wire at the icu plug { key on} icu unplugged. With The plug put in the icu I get voltage at all wires coming out by peircing insulation. I am getting today Resistance at coil unplugged 2.8 primary. 8.5 secondary. checking coil all wires on . key on at neg side 0.74 -- Positive lead of meter to neg side of coil and other to neg battery or bolt on strut... doing the pos. 15 side of coil meter .04 Think the new coil went bad already? {{ I AM READY TO TAKE A SLEDGE HAMMER TO THESE WHITE PLASTIC PARTS}} So there should be around 12 volts at 15 pos. Side of coil w/key on ? Is that with Neg side of coil wire from ICU plugged in? OR unplugged ? Anyone know at the starter motor Blue and yellow wire goes to fender side of starter right? Brown to engine side. Piggy backed brown wire or another wire from the engine side starter to Pos. 15 side of coil Is that right? Please One more question What is the model of Bosch Dist. that will just plug into the ICU I have . what year car and model. would it be on ? Thank You VERY VERY MUCH for every bit of your help. I truly do appreciate it. Roady
Old 05-14-2017, 04:05 PM   #19
There should be 12 volts at the positive side of the coil with the key on. It shouldn't matter if the ICU is plugged in or not.
The blue/yellow starter trigger wire and brown coil wires are connected correctly.
The Bosch distributor that drops in came on some '84 cars with B23 engines. It's Volvo part #1332684.
Your posts would be easier to read and understand if you took the time to break them up into paragraphs.
Old 05-15-2017, 04:26 AM   #20
John242Ti
John242Ti's Avatar
The Bosch distributor that drops in came on most '83 cars with B23 engines. It's Volvo part #1332684.
Fixed the year info. Seems that only the early 499802 and 499803 B23F engines had the Chrysler distributor. The rest used the above depicted Bosch unit with a Bosch coil. 1984 uses the flat plug hall switch, like the 1985-88 cars.
1984 version shown here on a B23F that had internal problems, hence the reason why everything was torn apart.
-J
Old 05-19-2017, 12:32 PM   #21
roady61
Hello: Again I am not getting any voltage at the coil Pos. 15 post. with the key on. I only get voltage there if the engine is cranking or if the neg.1 side red/white wire from the ICU is connected to the coil. I realize that I'm far from the brightest bulb in the pack when it comes to fixing this spark problem. I tried running a wire from the coil pos. side to the fuse panel. with the key on tried every fuse there it only engaged the starter. Any ideas where the problem lies Thank You so much in advance.
Old 05-19-2017, 03:32 PM   #22
Default Post a wiring diagran
Post up a wiring diagram.
I don't know if the coil has 12v key on. MSD ignition, for example, do NOT. I learned that the hard way.
Old 05-20-2017, 06:05 PM   #23
roady61
Since this B21f MPG was only produced in 81 . Wiring diagrams for other years are somewhat different. The Volvo wiring diagrams site does not offer any for the 81 models. Volvo Tips site does have a few for 81 but I cant print or copy them thus far. Ill keep trying to copy them something . When I do I will post what I have. Thank You
Old 05-20-2017, 08:00 PM   #24
TestPoint
TestPoint's Avatar
I have the '81 electrical Greenbook. Not sure how to send 38mb to you but have the two ignition pages for the MPG saved as .pdf. PM me an off forum email and I will send them to you.
Ford V8 Conversion Manual -
TestPoint is online now   Reply With Quote
Old 05-21-2017, 01:49 AM   #25
Trace the circuit!
Learn to diagnose a "rpm sensor".
Find out where the voltage goes missing
