Old 05-11-2017, 02:41 PM   #1
Cwazywazy
Single jingle
Cwazywazy's Avatar
Default New harness woes
Put in a new LH2.2 EZK conversion harness from Dave Barton and I got it running today. Just doesn't run right. Temp gauge and speedo are broken as well. Firing on all spark plugs, dunno about injectors yet but wiggling the connectors made no difference.
Smooths out at higher rpm but under ~2-3k it runs like that.
I don't know what I have
Old 05-11-2017, 02:58 PM   #2
Check the injector connectors for any pins that didn't lock into their insulators.
Old 05-11-2017, 03:01 PM   #3
Misfires.
Old 05-11-2017, 03:31 PM   #4
A tough rowing ho
Sometimes the connectors in the wire end of the injector connection get pushed out of the holders, peel back the rubber thing at the wire connection and take a look. You can try disconnecting injectors to isolate your problem, the one that doesn't make any difference to it running is the culprit.
Old 05-11-2017, 03:40 PM   #5
Cwazywazy
Single jingle
Cwazywazy's Avatar
Bingo. I guess I forgot to check the injector plugs when I installed it. Runs great now. Gauges still inop, but I'll figure those out later.
Another question, the EZK has a boost switch dealie on top of it. What's it for? Safety switch in case of overboost?
Old 05-12-2017, 07:22 PM   #6
Cwazywazy
Single jingle
Cwazywazy's Avatar
Been working out the kinks, AC is fixed now and it runs great. But I'm still working on fixing the tach. It's not connected at the 4 pin next to the ECU and I can't find where the red/white wire goes?
Old 05-14-2017, 02:46 PM   #7
Cwazywazy
Single jingle
Cwazywazy's Avatar
Tach is fixed, now the only problem is the temp gauge. I have no idea what's wrong with it, the yellow wire has a good connection with the sender. I think I can see it moving a tiny bit when the engine gets warm.
Old 05-14-2017, 11:18 PM   #8
LC4CARL
Aero challenged
LC4CARL's Avatar
Nice!
Life begins at 10PSI.
Old 05-14-2017, 11:29 PM   #9
Cwazywazy
Single jingle
Cwazywazy's Avatar
Oh yeah, yesterday it developed this feature where if you turn on the AC the fuse blows and the engine dies. Really nice when it happens in an intersection.
Old 05-15-2017, 12:40 AM   #10
LC4CARL
Aero challenged
LC4CARL's Avatar
That sux. Nice effort so far. You'll get it.
Old 05-18-2017, 10:57 AM   #11
Cwazywazy
Single jingle
Cwazywazy's Avatar
Temp gauge started working on its own and the AC hasn't blown a fuse since I wiggled all the under dash wiring.
Of course now the new issue is low-ish boost.. (About 9-10psi max.)
Old 05-18-2017, 11:07 AM   #12
KeizerBrickGuy
Sh*t pot stirrer
KeizerBrickGuy's Avatar
Nice work! Making good headway on the gremlins.
-Stephen
#mclovethesenuts
-My car: White 1991 244, 308k miles. B230F LH2.4, AW70, R134a retro, Coronas
-Wife's car: White 1990 244DL, T cam, 190k miles.B230F LH2.4, AW70 w/aux cooler, Virgos, tow hitch
-PSM 2002 Subaru WRX wagon: EJ205, 5MT, 120k miles, Perrin TBE
-1997 Subaru Legacy Brighton: EJ22, 5MT, 236k miles
Old 05-18-2017, 11:10 AM   #13
Centsableone
SNAFU - BOHICA
Centsableone's Avatar
Keep on truckin'! Your patience will win in the end. I guess when you rewire completely you have to troubleshoot a lot of places. GL!
1983 245T, 1986 244, 1990 745T, 1990 245, 1982 4- speed 245D,
Currently: 1992 244
Sale and Purchase Feedback
Centsableone is offline   Reply With Quote
Old 05-18-2017, 11:15 AM   #14
Doesn't sound like a problem to me.
Old 05-18-2017, 02:36 PM   #15
Cwazywazy
Single jingle
Cwazywazy's Avatar
Still fast, but it needs to be faster. Absolutely has to.
Efan keeps the needle dead in the middle with the AC on in ~95f, so that works well.
Old 05-18-2017, 02:38 PM   #16
Unhook the wastegate.
Old 05-18-2017, 02:39 PM   #17
Cwazywazy
Single jingle
Cwazywazy's Avatar
Will do. Last time I had this issue the WG was falling off but it passed my wiggle test yesterday.
Old 05-18-2017, 02:40 PM   #18
Old 05-18-2017, 05:55 PM   #19
Cwazywazy
Single jingle
Cwazywazy's Avatar
Problemo solved-o.
Rip in the IAC hose.
Old 06-08-2017, 07:56 PM   #20
Cwazywazy
Single jingle
Cwazywazy's Avatar
My temp gauge is still inop. No idea. Wire from the sender to the firewall connector has no resistance and I even replaced the sender. It worked a couple times randomly after replacing the harness and it always worked before. I even took the old bullet connector from the old harness and crimped it in place of the new one. Nothing.
Old 06-08-2017, 10:48 PM   #21
Just run a new wire direct from sender to the firewall plug. Use a test wire at first!
Old 06-08-2017, 11:21 PM   #22
JohnLane
Ground sender lead to verify that the gauge immediately runs to the red with key on.
If not check at firewall connector. Easy enough to replace that yellow wire if needed.
As for the fuse blowing issue that got 'resolved' by shaking wiring under the dash... I'd revisit that.
Old 06-08-2017, 11:32 PM   #23
Cwazywazy
Single jingle
Cwazywazy's Avatar
Allright, I'll investigate more tomorrow. The fuse blowing thing is the AC. Jiggling the AC wire at the firewall seems to have made it gone away. I moved the coil to another fuse so if the AC blows it again the car won't die. AC itself needs some work as well, it sucks right now. Even the sloppy R134 convert I did to the other 240 blows colder.
Old 06-09-2017, 05:36 PM   #24
Cwazywazy
Single jingle
Cwazywazy's Avatar
Gauge fixed. Turned out to be the connector at the firewall on the dash side.
