Old 05-14-2017, 11:13 AM   #1
whitey5150
Default vacuum line question
I have a b230ft swapped volvo 240 with lh2.4 it has a Garrett t25. the recirculation valve there is a little one way valve. My problem is that it holds vacuum all the time so the valve stays open so boost is crap. How is it supposed to function? I had to make a small hole in the vacuum line after the valve so it wouldn't hold vacuum under boost but that's not proper.
edit: it also stalls or stumbles if you go from boost to brakes, normally it doesnt stall but you boost hard and try to come to a complete stop immediately or like do a burnout and just stop it will stall.
whitey5150 is offline   Reply With Quote
Old 05-15-2017, 10:51 AM   #2
EivlEvo
Where do you have the line hooked up?
