Old 05-15-2017, 12:54 PM   #1
DME
vague member
DME's Avatar
Default Rocker switch alternative
I'd like to run some accessories using the factory switch locations. I understand that the OE "blank" switches are unobtanium, and I don't like the idea of having a bunch of REAR DEMIST switches. Is there an aftermarket or Volvo alternative from another model that fits in the factory blanks?
Gracias
DME is offline   Reply With Quote
Old 05-15-2017, 01:00 PM   #2
oldschoolvolvo
oldschoolvolvo's Avatar
The later 240 A/C switch can work too...just find one that has the white marking rubbed off so it's just a "blue-lighted" switch.
-Mike
1998 V70 T5
Old 05-15-2017, 01:04 PM   #3
cleanflametrap
cleanflametrap's Avatar
Gracias
Check out the rockers offered at waytekwire.com as an alternative if you can't find another drop in (snap in) substitute. These folks cater to the custom vehicle wiring market. School buses, and ambulances come to mind.
-Art
Old 05-15-2017, 01:28 PM   #4
The blank switches appear to available still for $44.
Old 05-15-2017, 01:39 PM   #5
57plymouth
57plymouth's Avatar
I have a few of these spare if you are interested. PM me.
Old 05-15-2017, 01:39 PM   #6
TempleUWS6
TempleUWS6's Avatar
I've got one that fits the bill if you want to PM me.
'90 245 DD
'90 244
'91 940t sedan
'02 Trans Am WS6-Konis+Stranos, full exhaust, 353rwhp/373rwtq, Fikse FM5
'76 BMW R75/6
TempleUWS6 is offline   Reply With Quote
Old 05-15-2017, 01:44 PM   #7
Cwazywazy
Cwazywazy's Avatar
Yeah, I think a worn AC switch is about as blank as you can get cheaply. Or you could just make stickers.
Old 05-15-2017, 02:37 PM   #8
PCH
I've installed smaller aftermarket switches into blanks (not a Volvo in the pictures but works the same)
Old 05-16-2017, 02:20 AM   #9
John242Ti
manofewords
John242Ti's Avatar
If I remember correctly, a lot of big rigs and construction equipment use them as well. They're usually the ones like the 1973-80 switches, so the whole switch is a certain color. Alternatively, search for "Mera rocker switch" and they may come up. Mera is the brand name of most of the switches used in the late 140's and the 240's, etc.
-J
1982 242Ti - black, M46. 1985 245Ti - blue, M46. 1989 745Ti - red, Aw71.
Formerly Blue245Ti, 245GT-Turbo, and, originally 242GT-Ti.
Old 05-16-2017, 07:32 PM   #10
nel621
Late model seat heater,ac, and fog light switch. Then get the custom stickers from someone on this board. I forget his name.
Old 05-17-2017, 11:52 AM   #11
Kenunot
A little solvent will take the triangle clean off a hazard switch. Discovered quite on accident.
Sale Thread Feedback Thread
Kenunot is offline   Reply With Quote
Old 05-17-2017, 05:39 PM   #12
Dan
TQ>HP
Dan's Avatar
I've done this as well, found some small rocker switches with LEDs in them, just dremeled a hole in faceplate and installed.
I paid couple bucks each for them, I do keep a spare or two for when they go bad, but so far so good, couple of years
Old 05-17-2017, 07:07 PM   #13
HiSPL
HiSPL's Avatar
Yeah somebody was making little stickers for volvo switches that looked awesome. They had all sorts of icons and labels
Beets taste like buttfeet.
Old 05-17-2017, 07:08 PM   #14
James10952001
Volvo used crappy ink all over the place, it's pretty easy to clean it off the switches, especially when you don't want to. You can get transparent waterslide film on which you can print anything you want using an ordinary laser printer. I use the stuff to make decals for my RC airplanes.
James10952001 is offline   Reply With Quote
Old 05-18-2017, 11:39 PM   #15
Jake_NZ
Jake_NZ's Avatar
~90's DAF truck switches look to be an almost match - just slightly more roundy looking and grey colour instead of black.
They nearly fit in - just would need a sand on the sides I think.
'89 Volvo 245 GLT & '83 Volvo 244 GLT
Jake_NZ is offline   Reply With Quote
Old 05-18-2017, 11:59 PM   #16
I have a nice late snowflake AC switch and rare early style narrow lit amber rocker switch for $30 shipped.
