Old 05-16-2017, 03:55 AM   #1
FarAway
Default Volvo b230ft starting problem
Hi,
Another starting problem thread, but i have readed almost all thats related to this issue.
Car is 240, but i installed 740 91y 2.4lh engine.
Rebuilded the engine in winter so almost everything in the engine is brand new. So the car crank fine. Old engine has distributor with hall sensor but new one have RPM sensor and takes the signal there.
Changed distributor, cab, sparking plugs, sparking plug wires, junkyard power stage or ignition modul? and rpm sensor. Test another ignition coil, looked over grounds etc.
Rpm sensor shows only 178ohms but need to at least 240ohms. https://www.upload.ee/image/6999242/rpm.jpg
From the ignition coil comes out +12v when key on.
OBD shows only 1-2-3 code(engine coolent temp). Fuel relay to click and petrol pump to some noise when key on. Sparking plugs is wet.
Can i test rpm sensor differently or buy new one?
FarAway is offline   Reply With Quote
Old 05-16-2017, 04:22 AM   #2
thebornotaku
( ͡° ͜ʖ ͡°)
thebornotaku's Avatar
It sounds like you've already pinned it as a bad crank position sensor (or RPM sensor as you say), so I would at least start with replacing that.
Stick a magnet on your extension when you go to remove or install the bolt, so that you don't drop it.
1986 Volvo 244DL M47 "Turd Ferguson"
2009 Volkswagen Rabbit 2.5 "Snowbunny"
thebornotaku is offline   Reply With Quote
Old 05-16-2017, 04:18 PM   #3
Default A crank sensor thread
http://www.forums.turbobricks.com/sh...d.php?t=316065
http://www.forums.turbobricks.com/sh...d.php?t=322395
Old 05-16-2017, 05:08 PM   #4
Dirty Rooster
Crank position sensor is a right bugger and can look good but be faulty.
Cheap enough to replace with a known good one.
Also ... as always with LH2.4 ... the fuel pump relay in the relay tray.
Dirty Rooster is offline   Reply With Quote
Old 05-16-2017, 05:45 PM   #5
Janspeed
are you using the correct flywheel for LH2.4? if it i not a 60-2-flywheel (58 drilled holes in the edge) you will not be able to get the engine started.
If you do have the 60-2 flywheel , is it actually installed correctly? The flywheel needs to be installed in the correctly clocked position, there are 8 bolts so there are 8 positions in which the flywheel can be mounted... only 1 position is correct. If it is mounted in the wrong position the sparks and injection events will happen at the wrong times. so, even when you do have spark, fuel and compression the engine will not run.
Old 05-16-2017, 08:13 PM   #6
Dicktater
Stiff Member
Dicktater's Avatar
^ This, check and be sure.
Originally Posted by CaliMeatWagon View Post
I hope your treehouse gets cancer
I buy a few when foodstamps get here because I have an investment strategy.....
Originally Posted by volvo740b234/531 View Post
I smoke my weed and dream of an awesome life
Feedback >http://forums.turbobricks.com/showthread.php?t=197700
Dicktater is offline   Reply With Quote
Old 05-16-2017, 08:35 PM   #7
Click link in my signature. It goes over how to check for spark and then how to use ether.
Old 05-17-2017, 08:05 AM   #8
FarAway
Thank you all for answering.
Yes im using right flywheel with drilled holes in it. But im not sure if i installed it back right way. If i remove starter, can i see flywheel signs from there?
Ordered new rpm sensor and inspect the flywheel when i get new sensor from the shop.
Old 05-17-2017, 08:06 AM   #9
FarAway
Already readed that.
Old 05-17-2017, 10:51 AM   #10
I like the method of going to TDC , then turn crank 180 degrees, then the gap in the wheel should be 180 degrees away from the starter hole! It is much easier to pull the flywheel cover than a starter!
Old 06-01-2017, 07:25 AM   #11
FarAway
The flywheel is installed right now. New rpm sensor is in place too. Still no spark. What next?
Old 06-01-2017, 07:53 AM   #12
One hundred gift baskets
Did you convert the car from lh2.2 to lh2.4? Did you get both the ignition and fuel computers from the donor car?
1980 primer Franken-242DL, 1989 silver 780 bone stock.
Old 06-01-2017, 09:26 AM   #13
Backprobe the powerstage pin 5 grey wire with an LED test light to see if the EZK is sending a 5v square wave signal to the EZK.
Test light coil negative and check for blinking.
Edit:
Ok so what year 240 is this? The biggest mistake people make is connecting the ignition switch incorrectly so that the computers do NOT have power during cranking. Revisit your wiring!
