Old 12-23-2014, 10:04 PM   #1
bigbret
Campin in your backyard.
bigbret's Avatar
Default NGK plug wires? Any good?
Lookin at Rock auto for plug wires for my new 86 244. Anyone have any experience with Ngk? I like there plugs. $33 for the set is not bad.
Bret
bigbret is offline   Reply With Quote
Old 12-23-2014, 11:39 PM   #2
84B23F
84B23F's Avatar
Negative, but 7mm wire is 7mm wire.Amazon sells them at similar price, btw.
NGK is a company with good products, btw.
>86 244.
I have no idea what Volvo suggested...is 7mm correct?
Old 12-24-2014, 12:02 AM   #3
AndrewNance
Amateur hour!
AndrewNance's Avatar
The Kingsborne wires aren't much more than that. Also crazychopstick will make you a set of 8mm Taylor wires.
'71 142
'80 245
Feedback
Old 12-24-2014, 01:14 AM   #4
bigbret
bigbret's Avatar
I gotta put this ride through cali smog. Soo it has to be wrapped up soon.
Old 12-24-2014, 01:23 AM   #5
PromiseRing
We don't even like Volvos
So what's the deal with the size of wires? Larger wires=lower resistance? I'm in the market for new wires.
Current
-93' 244 m47-iPd sways, 13c, iPd cam, 2.5”
straight pipe
-93' 245 m47-iPd sways, B-cam
-90' 744 AW70:( stock as a rock
Past
-80' 242gt m46-
-88' 245 m47-Welded diff, gutted, 13g
spill it MClovin and WTF happens to your glasses you piece of ****..
Feedback Thread
Old 12-24-2014, 01:38 AM   #6
84B23F
84B23F's Avatar
Originally Posted by 93Volvo240 View Post
So what's the deal with the size of wires?.
Sparkplug wires have changed in last forty years....ideally, one wants lower resistance wires with "maximum amount of radio frequency interference (RFI) suppression."
There is nothing wrong with those NGK wires, as based upon Rockauto's literature, They are an "iInductance (mag) wire, and they have RFI suppression, but NGK's site suggest they are for 1988 thru 1993 Volvos.
For 1986-244, they suggest: 1976 thru 1987 Volvos
NGK Ignition Wire Set
SKU: #EUC036
ITEM : # NGK54354
BRAND : NGK
Old 12-24-2014, 01:46 AM   #7
lummert
lummert's Avatar
NGK wires use spiral wound wire, similar to OE Volvo wires made by Bougicord.
Old 12-24-2014, 01:02 PM   #8
PromiseRing
Can I still get wires from the aspirator? It says he hasn't been on here in about 6 months.
Old 12-24-2014, 04:36 PM   #9
gsellstr
Vintage anti-ricer
gsellstr's Avatar
I don't think Aspirator is making them.
Bret...seriously, hit up Kingsborne. Nice wire, legit, and cheap, plus you'll have them asap since they are actually made here in Cali. Dunno given the holidays, but every time I've ordered from them, with custom stuff even, it's been 3 days til I had them at my door. Think my wireset for the wagon was $48 delivered, with a MSD Blaster end on the coil wire and firebraid over the 8mm wireset. Basic wires were a good bit less. Boots are nice on them as well, though I haven't tried the metal boots as of yet.
Kingsborne is the place that was making the IPD stuff for quite a few years, dunno if they still are or not.
RIP
74 144 B20
90 745Ti
Old 12-24-2014, 04:43 PM   #10
Xeroni
MPG?
Xeroni's Avatar
Napa sells a really nice set for pretty cheap if you need something that most stores have in stock.
1990 765T; sent off
1989 744T; parted out
1985 245; The Battlewagon;+t, B21/AW71L, back at it again with the megasquirt
1999 V70XC, token whiteblock noisemaker
1998 Lexus GS400, slammed & loud, for sale
2014 Ford Fiesta ST, reliable autocross beast
Xeroni is offline   Reply With Quote
Old 12-24-2014, 05:36 PM   #11
OldGrandpaTune
The Road Warrior
OldGrandpaTune's Avatar
I use NGK exclusively on everything. Never had an issue. Fit is great.
Perry
"Every man...should periodically be compelled to listen to opinions which are infuriating to him. To hear nothing but what is pleasing to one is to make a pillow of the mind."
St. John Ervine
OldGrandpaTune is offline   Reply With Quote
Old 12-24-2014, 07:01 PM   #12
AndrewNance
Amateur hour!
Also this. I've been using these on my 945 for a while with good results.
Old 12-24-2014, 07:03 PM   #13
SwedishBee
Drill em deep
SwedishBee's Avatar
crazychopstick
Nuff said
Originally Posted by CrazyChopStick View Post
I bought an 850.
SwedishBee is offline   Reply With Quote
Old 12-24-2014, 07:38 PM   #14
PromiseRing
Originally Posted by SwedishBee View Post
crazychopstick
Nuff said
He makes wires?
Old 12-24-2014, 08:14 PM   #15
theknave
theknave's Avatar
Agree. I'm also sure perfectly fine plug wires have been thrown in the trash many a time.
'86 240 DL, M46 - Primer grey, yellow, silver and flat black.
'90 240 DL, AW70 - Rotting, with its guts out, on the cadaver table... the AW70 is nice tho, with a recent full fluid flush via tt 500, and an all new Yukon set of bearings (Timken) and seals at the rearend, new SKF bearings and seals at the axles.
theknave is offline   Reply With Quote
Old 12-24-2014, 09:09 PM   #16
centason
Wine enemas for all
centason's Avatar
I run 7mm Denso wires on my 93. Completely stock. No issue for many miles.
Member: TBCCS
Death to all who stand in the way of obtaining the freedom of working people!
Just remember this guys. Im related to cocaine.
they were pushing sloppy poo up a steep hill with a pointy stick.
You sons of bitches are the biggest thread de-railers in forum history.
Any forums history.
