Also took my passenger door panel off, to try and track down a rattle and also replace the floppy door handle. Found one of my favorite things in any old used car... repurposed aircooled VW parts!
Someone used half of an old VW exhaust clamp to help keep the door release rod from bowing outwards when you pull the inner door handle:
That's definitely going to stay!
I discovered the source of my rattle. Some spot welds have broken on the frame that sits at the bottom of the window. I don't have a welder here, so I mixed up some heavy duty epoxy, clamped it for 12 hours, and it seems to be doing OK. IF it doesn't hold, I'll replace the frame with one from a donor car. Has anyone ever removed that frame from a piece of glass, and gotten it to fit tight on the new piece of glass? I've tried it a few times on Karmann Ghia windows, and haven't ever fully succeeded at getting the frame to grip the glass tight enough to prevent it from falling off eventually.
Finally, I am trying an experiment...
I think that my rear speaker shelf would look better if it was all tan. Right now, it's got some 6x9s in the shelf, it's got some nearly white carpet that used to be tan once, some black rear window defrosters, and it's got those black seat belt covers. I am going to try and paint it all tan with SEM interior paint, and see how it looks.
All scuffed up and then washed with dish soap and left to dry. Tomorrow I'll paint.
This is the paint that IPD sells for tan 240 interiors. SEM 15173 Camel. I hope it matches pretty well!
I knew that the door panels were faded and would need some of that SEM paint too. But I had no idea they were so rotton!
These are both totally gone at the bottom. So I am going to keep an eye out for some workable door panels for sale. In the meantime, I am going to run these as-is. I'm not even sure if I want to bother trying to seal up the backside, because they're so gross and floppy. What have people used to seal the backsides of door panels like this?
One last thing, In my effort to lube and free the passenger side rear popout window, I discovered how the popout window hinge works. If you're curious, it's pretty damn basic:
It just fits into two slots and pivots there. And here's the backside of the mechanism:
I'd love to try and modify these someday, to get twice the amount of opening out of them or something. Similar to Spoon latches in an old VW bus:
I checked it out, and there's enough give in the hinge up front to make it possible. I'm just not sure how far is too far, before the window falls out of its front hinge when you go over a big bump! I'll find out someday.
