okoye
Well-known member
- Jul 27, 2009
- Connecticut
dog dish in my '94 960 turbo putting in a clutchnet disc and I want to know what specs I should tell the machine shop to resurface it to.
not sure what you mean...a surface finish spec?
I've had a flywheel resurfaced multiple times and there was never any spec discussion.
The Clutchnet disc will most likely be thicker than a stock Volvo disc. Make sure to take that into account also.
They take material off of both to keep the distance the same.babbs told me to get 2mm shims for the pressure plate so I went out and bought those. But I figure they're taking material out of the center but not the top?
It's much easier if you remove it. I've bent the shifter before trying to be lazy.
Get rid of the dogdish
