Old 06-30-2015, 09:58 PM   #76
AndrewNance
Amateur hour!
AndrewNance's Avatar
I'm really satisfied with the height of those 750# springs. Mine settled lower than I expected which is great because I was expecting them to be higher than I wanted. You're gonna need to cut those bumpstops down for sure. Or get some short ones.
'71 142
'80 245
Feedback
Old 07-01-2015, 10:07 AM   #77
HUB
Needs more cowbell
HUB's Avatar
Originally Posted by Tuff240 View Post
You missed painting the bottom of your block. I use an extra oil pan to cover up the bottom of the block so I can rotate it on the stand and make sure I paint everything as good as possible.
Painted everything that needed to be painted on the block. Areas that have gaskets going over it will just have a clean surface with maybe a little sealant (not the head).
HUB is offline   Reply With Quote
Old 07-02-2015, 12:22 PM   #78
HUB
Needs more cowbell
HUB's Avatar
I will good sir. Thanks for he help. What dims and weight did you use for the rear?
Thanks,
Old 07-02-2015, 12:33 PM   #79
cwdodson88
He was meaning the little ears at the front of the block and the mounting ears at the back of the block for the inspection plate...
The Build Thread
SVEA - PUSHROD TURBO!
cwdodson88 is online now   Reply With Quote
Old 07-02-2015, 08:01 PM   #80
HUB
Needs more cowbell
HUB's Avatar
Gotcha. My bad. I'll touch it up later this weekend.
Old 07-02-2015, 08:12 PM   #81
AndrewNance
Amateur hour!
Thanks,
I used a 3"x10" 250#. I ended up taking the factory lower spring seats and welding them right to the axle tubes on the 8.8. It's just about right also. Just need to do some final adjusting of the rear end to get it to sit level in the back.
Old 07-03-2015, 10:56 AM   #82
HUB
Needs more cowbell
HUB's Avatar
Okay. Haven't decided what to do for the rear with a stock rear end. Do even know the stock dims for the springs currently in the car. Appreciate the help!
By the way, I want hump your 142. Lol. Would love to have one. Nice car!
Old 07-03-2015, 11:14 AM   #83
AndrewNance
Amateur hour!
122 rear springs are 4.5" so they're kind of a weird size. Actually I think wagons are different so I don't know much about that. Unless you plan to haul a bunch of weight you won't want to go above 250# for a street car.
Old 07-04-2015, 03:07 PM   #84
HUB
Needs more cowbell
HUB's Avatar
Default Reassembling of B18 Engine
Got more put together yesterday. Still waiting on the head to be done. May go with ARP head studs.
Thanks,
Old 07-04-2015, 03:17 PM   #85
AndrewNance
Amateur hour!
What cam did you go with? Personally I wouldn't bother with ARP studs. B20 head bolts aren't TTY and you almost can't blow a b20 head gasket. The money is better spent elsewhere I think.
Old 07-04-2015, 03:30 PM   #86
HUB
Needs more cowbell
HUB's Avatar
I need new bolts. Would cost about 70 bucks for OEM and I can get ARP for 5 bucks more with my discount. Figured I might as well.
Went with a standard C grind.
Old 07-07-2015, 05:23 PM   #87
HUB
Needs more cowbell
HUB's Avatar
Default Prepping of Engine Bay- Getting ready for paint
Started working on the engine bay to get it ready for paint.
Thanks,
Old 07-07-2015, 05:33 PM   #88
cwdodson88
Sweet! how do you like the fender mirrors? Looking at a set just like those for my wagon... vintage JDM swede
Old 07-07-2015, 05:38 PM   #89
HUB
Needs more cowbell
HUB's Avatar
They aren't very practical, but they're very cool. Makes the car standout.
Old 07-07-2015, 05:40 PM   #90
cwdodson88
As if a yellow 122 wagon doesnt stand out enough
Old 07-07-2015, 05:41 PM   #91
Tuff240
240 Ninja
Tuff240's Avatar
Engine bays are my favorite. Popping the hood should be like opening a jewelry box.
-Patrick
Old 07-08-2015, 12:53 PM   #92
Reuvers
Reuvers's Avatar
did you do all of the bay with a wirebrush on a drill? or..?
Reuvers is offline   Reply With Quote
Old 07-08-2015, 01:17 PM   #93
HUB
Needs more cowbell
HUB's Avatar
Not done, but i used a sander, angle grinder, drill, etc. Anything that would get paint off. Lol.
Old 07-12-2015, 05:57 PM   #94
HUB
Needs more cowbell
HUB's Avatar
Default Cleaning and Disassembling M41 Trans
Started working on cleaning the gearbox today and taking it apart to replace seals.
Before
After
Will do more this week.
Old 07-14-2015, 09:16 PM   #95
farina43537
Beautiful stuff baby!!
farina43537 is offline   Reply With Quote
Old 07-15-2015, 06:11 PM   #96
HUB
Needs more cowbell
HUB's Avatar
Default B18 Head back from Machine Shop
Picked up the head today. Will need to clean it and paint it.
Thanks,
Old 07-18-2015, 05:53 AM   #97
HUB
Needs more cowbell
HUB's Avatar
Default Car Sent to Body Shop- Painting the Engine Bay
Car was towed to the body shop to have the engine bay done.
Thanks,
Old 07-19-2015, 10:06 AM   #98
Old Iron
I Roll
Old Iron's Avatar
This looked incredible before you started on it, can't wait to see when you get done with it!
Turbobricked
Old 07-19-2015, 01:14 PM   #99
HUB
Needs more cowbell
HUB's Avatar
Lmao. Thank you I guess? It looked good from a distance. Want to make it reliable enough to drive it daily.
Old 07-19-2015, 02:31 PM   #100
Old Iron
I Roll
Old Iron's Avatar
Why laugh! Bull****, every Amazon I find within 200 miles is visual rusty from the outside! This is a gem compared to what I can get my hands on!
