Old 01-25-2016, 03:11 PM   #326
cwdodson88
the lines out of the bottom of the mc were a pain, I almost wanted to get 2 90* fittings to make routing more like stock.
Looks fantastic!
How did your pedal length come out? mine seems a bit shallow, and the clutch rod is going to need to be shortened.
The Build Thread
SVEA - PUSHROD TURBO!
Old 01-28-2016, 09:45 PM   #327
HUB
Needs more cowbell
HUB's Avatar
Looks fantastic!
Haven't hooked up the pedal or lines yet. Still need to work on a few other things before I do that.
HUB is offline   Reply With Quote
Old 01-28-2016, 10:00 PM   #328
HUB
Needs more cowbell
HUB's Avatar
Default Fuel Tank Installation and Tail Gate Lifter
Fuel tank in. Playing around with lifter support.
Thanks,
Old 01-29-2016, 02:41 PM   #329
cwdodson88
is the a reason you are running 2 shocks on the hatch?
Old 01-29-2016, 02:48 PM   #330
HUB
Needs more cowbell
HUB's Avatar
I didn't like the locking slider. Just have one lifter now and it handles the load fine. May get another... Still playing around with it.
Old 01-29-2016, 03:05 PM   #331
cwdodson88
Hmm, I guess I like that locking slider, works great for loading the wagon full of fence and deck building supplies
Old 01-29-2016, 03:17 PM   #332
HUB
Needs more cowbell
HUB's Avatar
Lol. I haven't been domesticated yet. It keeps it up though.
Old 01-29-2016, 03:24 PM   #333
carbonmike
carbonmike's Avatar
I can driving around with mine open with just a gas shock on the right side. No rattles or bouncing around.
carbonmike is offline   Reply With Quote
Old 01-29-2016, 03:35 PM   #334
cwdodson88
yeah, just dont try it on the free way with the hatch down, and tailgate open... Thats my favorite part about that slider lock, hatch window down and locked, tailgate open and you can still see the license plate.
Old 01-30-2016, 08:42 AM   #335
HUB
Needs more cowbell
HUB's Avatar
Default T5 Trans Arrives!!!
Well the T5 transmission came in yesterday. 1352-199.
Had a water fitting made up for the head by a co-worker. Turned out great. Old on the left and new on the right.
Thanks,
Old 01-30-2016, 01:19 PM   #336
cwdodson88
looking good! So driveshaft next? planning on 2 piece or 1?
Old 01-30-2016, 01:51 PM   #337
evolvo67
evolvo67's Avatar
Here's a little info on T-5's:
http://www.moderndriveline.com/Techn...t5_history.htm
Old 01-30-2016, 03:36 PM   #338
HUB
Needs more cowbell
HUB's Avatar
I plan to go with a custom 2 piece. I have heard of vibration issues with a 1 piece. Plus, I plan to bag the car.
Thanks,
Old 01-31-2016, 08:35 AM   #339
HUB
Needs more cowbell
HUB's Avatar
Default Setting up T5 Trans
Started working on the T5 yesterday.
Thanks,
Old 01-31-2016, 01:53 PM   #340
cwdodson88
mmm shiny!
Old 02-03-2016, 09:00 AM   #341
canyoneagle
Striving for mediocrity
canyoneagle's Avatar
Damn nice project you have here. Subbed.
I wish to have the time/money to do something like this one day soon
canyoneagle is offline   Reply With Quote
Old 02-03-2016, 11:52 PM   #342
carbonmike
carbonmike's Avatar
Realized I forgot to order a body rubber seal that goes around the neck... So now I'm trying to track that down.
Were you able to find the neck gasket? If so where?
Old 02-06-2016, 10:04 AM   #343
HUB
Needs more cowbell
HUB's Avatar
I ordered it off ebay. Had help from others.
http://www.ebay.com/itm/121854164195...%3AMEBIDX%3AIT
Old 02-09-2016, 10:01 PM   #344
HUB
Needs more cowbell
HUB's Avatar
Not much to report. Getting parts ordered and ready for this weekend.
Finishing wrapping the header.
Got everything to run a remote oil filter and cooler.
Got the new clutch in.
Thanks,
Old 02-10-2016, 04:27 PM   #345
cwdodson88
what clutch did you end up with?
Old 02-10-2016, 09:16 PM   #346
HUB
Needs more cowbell
HUB's Avatar
Yoshifab 8.5" clutch. Figured it was fine for a stock B18.
Old 02-14-2016, 01:41 PM   #347
HUB
Needs more cowbell
HUB's Avatar
Default T5 Installation
Well we started working on putting in the T5 yesterday and today. Will have to come up with and idea for the cross member... Will maybe steal Andrew's idea
The dogs came to "help" too.
Also started playing around with the remote oil filter and cooler setup.
Thanks,
Old 02-14-2016, 02:28 PM   #348
GTJordan
Been here for too long
GTJordan's Avatar
On most cars, modern at least, the starter motor grounds through the bellhousing. If the oldies are the same, you may need to clean off the mating surface between the bellhousing, starter and the block?
Jordan
Old 02-15-2016, 03:12 AM   #349
mocambique-amazone
Hello Hub (?)
If I look right, the bellhousing is a cable type one, a pull type one, the clutch bearing release arm (sorry not my native language) is a hydraulik one, a push type one. Please check again, best regards Kay
And Jordan, I'm the same opinin, the ground cable needs uncovered metall :-)
Old 02-15-2016, 03:31 AM   #350
The clutch slave cylinder fits in the same hole in the bell housing as the cable.
