Old 04-15-2018, 09:15 PM   #701
Tfrasca
Tfrasca's Avatar
That's a clean spot for the surge tank. Really nice.
Old 04-22-2018, 05:03 AM   #702
HUB
Needs more cowbell
HUB's Avatar
Good Morning Everyone,
Have continued to work on the fuel setup the last few days. I used copper/ nickel hard line for most of it (-6). Ran out of fittings, so I have a flex black line for one part. Will work on fixing that later. If I can find another solution, then it will be rocking that.
Still need to make a return back into the tank. This is the part I'm not looking forward to. Will try to see if can use the filler neck.
Will put some sound deadening material in to help with any loud noises coming from the pumps (thank you Tfrasca for the advice on this).
Thanks,
HUB is offline   Reply With Quote
Old 04-22-2018, 05:35 PM   #703
HUB
Needs more cowbell
HUB's Avatar
Good Evening,
Got the J-pipe back today to test the fitment. Everything seemed to come together nicely with no major issues. Will send it back out tomorrow to have finished.
Thanks,
Old 04-23-2018, 10:03 AM   #704
cwdodson88
Very nice! It’s coming along nicely. How long till the baby?
The Build Thread
SVEA - PUSHROD TURBO!
Old 04-23-2018, 10:30 AM   #705
stick70
All the gauges
stick70's Avatar
Looks good dude!
Old 04-23-2018, 07:20 PM   #706
HUB
Needs more cowbell
HUB's Avatar
Thanks. Trying to get a lot of stuff done before the baby arrives. Baby is due end of May.
Old 04-25-2018, 01:37 PM   #707
cwdodson88
Better get at it!
Old 04-28-2018, 02:42 PM   #708
HUB
Needs more cowbell
HUB's Avatar
Better get at it!
I'm trying. Most of the big ticket items have been taken care of.
Thanks,
Old 04-28-2018, 02:46 PM   #709
HUB
Needs more cowbell
HUB's Avatar
Good Afternoon,
Continued to work on the fuel setup this afternoon. If there is such thing as a favorite line, this is it. Haha. Yes, I'm a loser. Need to make one more and add a few adel clamps and some aircraft hardware
Thanks,
Old 05-04-2018, 10:51 PM   #710
HUB
Needs more cowbell
HUB's Avatar
Good Evening,
J-pipe back from welding.
Thanks,
Old 05-05-2018, 05:49 AM   #711
Dammit
+8cm
I’d never have thought of a pre-turbo waste-gate. Cunning.
Dammit is offline   Reply With Quote
Old 05-05-2018, 06:27 PM   #712
Tfrasca
Tfrasca's Avatar
Can you still remove the particle board on the tank? Not a big deal, just annoying if you have to mess with your fuel level sender. Having made general maintenance items very difficult on my car, I am starting to notice things like that.
Old 05-05-2018, 06:48 PM   #713
HUB
Needs more cowbell
HUB's Avatar
Yes it can. It’s shorter on the one side to allow that. Hard to tell with the pictures.
Thanks,
Old 05-19-2018, 04:50 PM   #714
HUB
Needs more cowbell
HUB's Avatar
Good Afternoon,
Been doing some more work on the 122. Progress is slow, but still moving forward.
Plumbing done for the fuel setup.
Had the exhaust manifold milled and mounted everything today. Also put in the oil drain line (may change this setup later).
Thanks,
Old 05-28-2018, 11:19 AM   #715
HUB
Needs more cowbell
HUB's Avatar
Good Morning,
Started wiring up the fuel setup... Still not finished, but it's a work in progress.
Thanks,
Old 05-28-2018, 08:22 PM   #716
Vol242vo
Vol242vo's Avatar
Fuel setup is beautiful, love the extra attention to detail!
Derek - 1980 242
Old 05-29-2018, 05:26 AM   #717
DET17
Reformed SAABaholic
Looking good. In the pic showing your WG and UCA, I see locknuts facing the exhaust system..... those are not NYLOCK, are they? If YES, they won't survive long with the radiant heat applied. If NO, good thinking!
I almost made the NYLOCK mistake on my 70 Chevelle.... caught it before disaster.
Old 05-29-2018, 11:10 PM   #718
cwdodson88
Nylock nuts survive that spot surprisingly well. My j pipe, and around the world down pipe was as close if not closer and the new nylocks held up. Not saying it’s not better for peace of mind to use a knut or pinched metal lock nut, but I think it should be fine.
Looks great Hub. I can’t wait until it’s done.
Old 05-30-2018, 08:53 AM   #719
HUB
Needs more cowbell
HUB's Avatar
Thank you everyone. The exhaust will be wrapped and some shielding will be applied. I’ll keep an eye on it. If i see any issues, it’s easy to swap out out.
Thanks,
Old 05-30-2018, 09:56 PM   #720
Shadow Ninja
Banned
Wow! This project has taken a hell of s turn, looking good!
Shadow Ninja is offline   Reply With Quote
Old 06-09-2018, 02:19 PM   #721
HUB
Needs more cowbell
HUB's Avatar
Good Afternoon Everyone,
My apologies for not providing an update... My daughter was born and have been distracted with her.
However, I did start the process for the down pipe. It's currently been dropped off to be tig welded.
Thanks,
Old 07-21-2018, 10:50 AM   #722
HUB
Needs more cowbell
HUB's Avatar
Afternoon Everyone,
A few updates on the build.
Downpipe all welded. Will make a bracket later for it to mount to the BH.
Bought this to start the process of the intake manifold. Cut it up and went a different route.
Thanks,
Old 08-05-2018, 03:48 PM   #723
HUB
Needs more cowbell
HUB's Avatar
Afternoon Everyone,
Started painting a few things with POR 15 before bolting the front back on.
Since the intake manifold I purchased didn't work. Used part of it and going to use the YoshiFab one. Gives me a lot more room.
Also started working on the engine bay harness.
Thanks,
Old 08-05-2018, 07:36 PM   #724
Vol242vo
Vol242vo's Avatar
Just impeccable.
Old 08-07-2018, 11:05 AM   #725
stick70
All the gauges
stick70's Avatar
Super clean dude, I dig it.
