Old 06-04-2015, 10:41 AM   #51
cwdodson88
you can get a hold of Mr.Borrie through this thread here
The Build Thread
SVEA - PUSHROD TURBO!
Old 06-04-2015, 11:10 AM   #52
HUB
Needs more cowbell
HUB's Avatar
Look like that's Nordic. They aren't selling them now.
HUB is offline   Reply With Quote
Old 06-04-2015, 11:28 AM   #53
cwdodson88
yeah, but send him a pm directly, he might still have a set that he wasn't able to sell. The market for 122 stuff is small and he did a pretty big run. Its worth a try.
Old 06-04-2015, 11:32 AM   #54
HUB
Needs more cowbell
HUB's Avatar
Yeah. I emailed him a few days ago. Worst he can say is no again. Lol. Looks like I'll be going custom.
Old 06-04-2015, 12:02 PM   #55
cwdodson88
The dynalite and superlite calipers fit our caliper mounts, the problem is rotors. There are a few people that have just put the dynalite calipers on stock rotors (this will be what I will most likely end up doing on the rear) but finding replacements are tough. you could remake the backing plate that attaches to the spindle and measure the offset and whip up a whole bracket. But in order to do this you will need to get calipers, and rotors. The reason that Dale did these was to be able to source an off the shelf rotor that didn't break the bank. My rotors can be replaced for 65.00 per pair, so that's a huge benefit.
Old 06-04-2015, 01:02 PM   #56
HUB
Needs more cowbell
HUB's Avatar
Agreed. That's why I order one side through wilwood to see what worked. He PM'ed me back and said he would do something in about a month. Don't know if I can wait that long so will most likely get something custom made.
Thanks again for all your help!
Old 06-04-2015, 01:14 PM   #57
cwdodson88
Basically, I had thought about doing a whole plate that mounted to the spindle. It was going to be 1/4" steel plate with it being just about doubled up at the caliper (so there is more meat to tap)
Old 06-04-2015, 02:03 PM   #58
HUB
Needs more cowbell
HUB's Avatar
That's a thought. I'll wait till the parts come in and can take a look at everything. That way I can make a better choice on what I want to do.
Thanks,
Old 06-05-2015, 10:13 AM   #59
Reuvers
Reuvers's Avatar
If i recal correctly, my front spring is kept in place by placing the aluminium sleeve with the lock nut halfway winded down on top of the spring.
The aluminium sleeve faals halfway into the spring, and the locknut sits on top of the spring. The locknut is then large enough to secure the top of the spring in the subframe
Would have to check for sure I did it this way when I get the car on a ramp.
Reuvers is offline   Reply With Quote
Old 06-05-2015, 11:06 AM   #60
HUB
Needs more cowbell
HUB's Avatar
Your fine. Didn't like how they sat. Ordered short springs rate for 700 (5x8). Will play with those next week.
Thanks,
Old 06-05-2015, 11:22 AM   #61
evolvo67
evolvo67's Avatar
I always thought front coilovers like this would be the way to go: http://www.ebay.com/itm/OPEN-BOX-SPE...-/161711181638 Where the upper end of the taper wound spring would fit in the stock position. Just need to make adapters for the lower mounts.
I think I'm the guy the OP is thinking of for moving the lower ball joint. I did it as an experiment to look at ride height. It was too low for me so I never drove it that way. But if you want to try, I cut the mounting pieces off two old BJ's and put them in the stock location, set the new BJ's on top of the lower control arm and installed appropriate length grade 8 bolts through both pieces. Lowered the car about 50mm, that is all!
evolvo67 is online now   Reply With Quote
Old 06-05-2015, 11:30 AM   #62
cwdodson88
the QA1 setups also come in stud-stud variants, so you might just be able to grab something bolt on and go. I had some part numbers somewhere... and Andrew tried something, but not exactly sure which ones.
Old 06-07-2015, 05:59 PM   #63
HUB
Needs more cowbell
HUB's Avatar
Default Dismantling of B18 Engine and reassembling of Front Suspension
Front end all done, just waiting on springs.
Got the block torn apart today and will take to the shop tomorrow.
Thanks,
Old 06-09-2015, 09:39 PM   #64
HUB
Needs more cowbell
HUB's Avatar
Default Reassembling of Front Suspension
Sent the coilovers back. They don't work. Ordered new springs. Much better.
Thanks,
Old 06-19-2015, 09:48 PM   #65
HUB
Needs more cowbell
HUB's Avatar
Default Reassembling of Front Suspension- Parts back from Powdercoating
Got parts back from powder coating and got the block back. Started painting the block tonight.
Thanks,
Old 06-20-2015, 08:11 AM   #66
HUB
Needs more cowbell
HUB's Avatar
Default B18 Block Painted (High Heat Ceramic)
Block painted and ready for rebuild.
Thanks,
Old 06-20-2015, 08:12 AM   #67
HUB
Needs more cowbell
HUB's Avatar
Delete post
Old 06-25-2015, 07:21 AM   #68
HUB
Needs more cowbell
HUB's Avatar
Default Powder Coating Parts- Reassembling of Front Suspension
Some more baking last night.
Thanks,
Old 06-25-2015, 09:40 AM   #69
amerbritcan
Hnnnnnng
amerbritcan's Avatar
This is all so nice looking.
1990 745tic
1984 244DL (parts)
Originally Posted by My Mom
Get a bike
Poopie scissors
Old 06-25-2015, 09:55 AM   #70
HUB
Needs more cowbell
HUB's Avatar
Thank you. Putting the engine back together this weekend.
Old 06-25-2015, 11:25 AM   #71
Reuvers
Reuvers's Avatar
engine looks great!
Old 06-25-2015, 02:43 PM   #72
matt b
Looks very clean, nice work! What springs did you end up going with ?
Old 06-25-2015, 02:59 PM   #73
HUB
Needs more cowbell
HUB's Avatar
Blue springs 5x8 at 750 for the front. Still looking for sprigs for the rear.
Old 06-30-2015, 09:24 PM   #74
HUB
Needs more cowbell
HUB's Avatar
Default Reassembling of B18 Engine
Well I started to to put the bottom end together last weekend.
Thanks,
Old 06-30-2015, 09:51 PM   #75
Tuff240
240 Ninja
Tuff240's Avatar
You missed painting the bottom of your block. I use an extra oil pan to cover up the bottom of the block so I can rotate it on the stand and make sure I paint everything as good as possible.
-Patrick
