Old 09-19-2015, 10:03 PM   #176
HUB
Needs more cowbell
HUB's Avatar
Originally Posted by NONHOG View Post
You DO NOT mess around. Nice progress pace you have going here. Envious!
Thank you. Appreciate the kind words. Would move along faster, but funds restrict that. Haha.
HUB is offline   Reply With Quote
Old 09-19-2015, 10:38 PM   #177
cwdodson88
Awesome! good stuff, all you need now is another passenger side axle.
The Build Thread
SVEA - PUSHROD TURBO!
Old 09-20-2015, 08:23 PM   #178
HUB
Needs more cowbell
HUB's Avatar
Default Disassembling of Ford 8.8 Rear End
Taking the rear end apart continued.
Thanks,
Old 09-21-2015, 01:10 PM   #179
cwdodson88
since the 122 front suspension is almost identical to the mustangII, doing something like so
http://static.summitracing.com/globa...t-19010999.pdf up front, and then fabbing up something in the way of a shock mount and I was thinking off the point where rear bolts of the front crossmember are.
Old 09-23-2015, 05:15 AM   #180
HUB
Needs more cowbell
HUB's Avatar
Default Picked up another short Axle for Ford 8.8 Rear End
Got the other short axle the other day. Going to try to clean up the rear end tonight.
Thanks,
Old 09-23-2015, 10:41 AM   #181
cwdodson88
NICE! Geeze I need to finish my house projects and get a move on my rear end and trans projects.
Old 09-23-2015, 10:48 AM   #182
HUB
Needs more cowbell
HUB's Avatar
Yes you do. I'm anxious to see an update on yours.
Old 09-23-2015, 01:20 PM   #183
cwdodson88
well the wife is giving me a deadline of having our current house list ready by November 1st... and I still have a pretty long chore list. But hopefully, I'll get into a place with a garage.. The wife only has 3 wants for the house: mature trees, open staircase, 2-3 car garage.
Old 09-23-2015, 08:07 PM   #184
HUB
Needs more cowbell
HUB's Avatar
Lol. I need a shop with the amount of work I want to do. At least her wants seem small.
Old 09-23-2015, 08:08 PM   #185
HUB
Needs more cowbell
HUB's Avatar
Started getting the surface rust off. Will need to pickup a few cutting wheels tomorrow. Would of done more, but got back to late from work.
Thanks,
Old 09-23-2015, 09:09 PM   #186
Old Iron
I Roll
Old Iron's Avatar
Love that your always working on this thing, I like seeing all these Amazon's in the project threads everyday, I am looking forward to getting mine ready for the spring time and this thread is helping the push!!
Turbobricked
Old 09-23-2015, 09:57 PM   #187
HUB
Needs more cowbell
HUB's Avatar
Thank you. Will watch for your build thread and look forward to following it.
Thanks,
Old 09-24-2015, 08:05 PM   #188
HUB
Needs more cowbell
HUB's Avatar
Not much to report tonight. Continue to work on the rear end. Ran out of cutting wheels again. Probable going to POR15 the rear and all the bolt on stuff will be powder coated.
Thanks,
Old 09-27-2015, 09:07 AM   #189
HUB
Needs more cowbell
HUB's Avatar
Not much work done the car yesterday. Spent some time cleaning up a little (hard to keep a small area clean when you have 30 lbs of $***in a 5 lb bag) and picked up a used parts washer for 40 bucks. Lol.
Thanks,
Old 09-27-2015, 03:20 PM   #190
HUB
Needs more cowbell
HUB's Avatar
Default Prepping Ford 8.8 Rear End
I would say this is the best I'm going to get it with my current tools. Will see what the guy fabricating it can do.
Thanks,
Old 10-10-2015, 11:05 AM   #191
HUB
Needs more cowbell
HUB's Avatar
Picked up the steering gear box this morning. Should start putting it together in the next few days. Had to get all new bearings and they had to press them in.
Old 10-18-2015, 07:13 AM   #192
HUB
Needs more cowbell
HUB's Avatar
Default Dropping off Ford 8.8 Rear End
Rear ends dropped off to be worked on.
Thanks,
Old 10-18-2015, 12:50 PM   #193
HUB
Needs more cowbell
HUB's Avatar
Default Rebuilding of Steering Gear Box
Started rebuilding the steering box. It will probably still leak. Lol.
Thanks,
Old 10-18-2015, 03:01 PM   #194
evolvo67
evolvo67's Avatar
I did a little reading on 8.8" Ford rear ends. One source mentioned that the axle tubes are only held in with two rosette welds at the center section, which I think I see in the above pic. It occurred to me that maybe those welds could be drilled out and the tube removed, shortened the correct amount and reinserted. It was also suggested to cast iron weld the axle tube to the center section so it wouldn't break the rosettes under hard acceleration. Just sayin'!
Old 10-18-2015, 03:03 PM   #195
AndrewNance
Amateur hour!
AndrewNance's Avatar
I think that's about the normal way it's done. I'm pretty sure mine was done that way before I bought it.
'71 142
'80 245
Feedback
Old 10-18-2015, 10:10 PM   #196
HUB
Needs more cowbell
HUB's Avatar
There is a part of the tube were the old bracket used to go on that has a very small soft spot. He wants to cut it there to fix that and won't have to grind the old brackets off. Then he will reinforce both tubes.
Old 10-19-2015, 09:50 PM   #197
HUB
Needs more cowbell
HUB's Avatar
Default Ford 8.8 Rear End being Modified
Rear end is coming along nicely so far.
Thanks,
Old 10-25-2015, 05:57 PM   #198
HUB
Needs more cowbell
HUB's Avatar
Default Steering Box Installed- Ford 8.8 Rear End back from being Modified
Not much to report. Only get to work on the car on weekends now.
Got the steering box installed and got the rear end back from fabricating.
Thanks,
Old 10-26-2015, 11:09 AM   #199
cwdodson88
Thats SWEET! I'm getting ready to start my winter projects, one of which is an 8.8 and a T5. Any idea how far they cut 8.8 that down?
Old 10-26-2015, 11:40 AM   #200
HUB
Needs more cowbell
HUB's Avatar
Took 3 inches out.
