Old 07-06-2022, 02:27 PM   #26
122power
dude
122power's Avatar
I was told a good rule if thumb was to gap the 2nd ring .010 larger that the top ring.
Save the Volvo's.
Ring,ring,ring
"Hello"
"Do you work on Volvo ...
*Click - bzzzzzz*
Old 07-06-2022, 02:29 PM   #27
Originally Posted by Alex Buchka View Post
I don't have any evidence for or against the efficacy of what this guy is writing but holy cow that page is absolutely packed with conjecture. Nary a verifiable or cited statement in sight. As a professional skeptic I get real nervous when someone unequivocally states "THIS IS HOW IT IS" and only backs it up with anecdotal or circumstantial evidence.
I can dig up my old mk2 VW service manuals, they have a similar break-in procedure. Basically warm up the engine, then go drive it up a hill with varying degrees of load and rpm sweeps.
I wouldn't trust someone on the internet with a site like that, for many reasons...
Oops - I meant I was amused by the tone/old internet feel of the site. Don't know how much I'd trust what this guy says.
Engine break-in seems a lot like when audiophiles talk about cable burn-in and the like.
I appreciated the 00's flashback, thanks!
Old 07-06-2022, 04:06 PM   #28
Called the manufacture and they recommended the lightest oil possible... or to put the rings in dry
I was given the same recommendation by a machine shop that built all kinds of high performance engines as far as breaking in the moly rings on a 365 Cadillac engine I had them do the machine work on,install the pistons/rings dry. I was too chicken. I very lightly oiled the skirts of the pistons.
Old 07-06-2022, 06:16 PM   #29
Kjets On a Plane
Kjets On a Plane's Avatar
+1
So thinking of re-ringing and glaze breaking but not for boost, purely for skinny rod hooptie hipermiling & coating the pistons, but not going as far as a proper torque plate align hone or full rebuild on an engine that’s ‘fine’ (in the sense that it doesn’t use oil or have a bunch of blowby huffing out the crankcase vent tube, noise or low oil pressure , anyway, but who knows? ) …
If it were possible to get the used engine running tip top same cam & all on known engine management, what’s best break in practices for a driver?
The Volvo factory dyno seems to just load it up in 4th and simulate driving up a hill/pre heated or warm lean burning engine for a few minutes as did the break in engine dyno room when I had Larsen & King do an engine sometime back?
Thoughts? I’m too chicken & maybe too unscientifically superstitious? & defer to my betters / the factory on this…
…having seen a bunch of what you describe (someone starts the thing cold & nice & rich and idles it on thick snot oil with plenty of fuel) winding up with an engine they had spent a bunch of $$$ and time R&Ring / disturbing or deviating from bone stock that has a bunch of blowby & hating life / not really having anything that is in essence a whole lot better the worn out motor (some seals, cleaner & new bearings/shiny bits )…I don’t wanna wind up like that ‘why’d I begin this journey considering the results & resources invested’ sorta deal?
How PSI a stock can support?
Always Be Crushing!
Old 07-06-2022, 07:06 PM   #30
From JE Pistons/Engine Builder Magazine: How to Break-In Your Piston Rings, The Right Way!
Old 07-07-2022, 08:49 AM   #31
Stiggy Pop
Stiggy Pop's Avatar
The machine shop recommended .006" per inch and said I'd be good to go so we're rolling with it (I think they set it as such while I was debating an answer actually).
Block is assembled and ready for pickup! It has been there since December 4th so I'm excited... maybe I'll have my head back from them in August?
'79 242
943 pickup
Old 07-07-2022, 11:58 AM   #32
sbabbs
sbabbs's Avatar
Ohh found the other part to those wisco's from RSI. I had the 16v turbo ones.
THIS IS HOW IT IS WISCRACKO SAYS TO DO IT!!!!!!!!!!!! Butt what do they know, they only sell the crud. I am sure your machine shop did you right. Mine had these papers and went from these instructions when he put mine together....
Only Harry will find out, it's what he does.. He has the still never run motor now.
1990 745 B230FT Getrag JohnV flywheel 240mm clutch 13c A-cam 3.54 G80 555K
1995 940 White racing wagoon. 13c.
Old 07-07-2022, 12:45 PM   #33
THIS IS HOW WISCRACKO SAYS TO DO IT!!!!!!!!!!!! Butt what do they know, they only sell the crud.
That's a good chart!
Now in text form:
  • Dirt, ATV, PWC, Snow: Top Ring: 0.0040" 2nd Ring: 0.0050"
  • High-Performance Street/Strip: Top Ring: 0.0045" 2nd Ring: 0.0055"
  • Moderate Street Turbo/Nitrous: Top Ring: 0.0050" 2nd Ring: 0.0055"
  • Late Model Stock (WTF is this even?): Top Ring: 0.0050" 2nd Ring: 0.0055"
  • Circle track, Drag Race NA: Top Ring: 0.0055" 2nd Ring: 0.0060"
  • Blown/Turbo Race: Top Ring: 0.0065" 2nd Ring: 0.0070"
  • Nitrous Race: Top Ring: 0.0070" 2nd Ring: 0.0075"
Old 07-07-2022, 07:48 PM   #34
Stiggy Pop
Stiggy Pop's Avatar
maybe the bottom end will eat itself before the head this time
Old 07-08-2022, 10:58 AM   #35
Forever the optimist
Old 07-08-2022, 03:07 PM   #36
sbabbs
sbabbs's Avatar
Okay uploaded the pics of the ring gap data to tbricks server I guess I should upload that other one also so if imagur goes down it will always be on tbricks server forever one could hope. 16v turbo wiscos with longer rod and shorter skirt piston then stock with 2.5L crank.
Old 07-08-2022, 05:50 PM   #37
Stiggy Pop
Stiggy Pop's Avatar
picked up the short block today and had a long chat about break-in. The owner said when he's running in cams and rings he does it basically like this:
- they coat the cylinder walls, ringlands and skirts with marvel mystery oil for initial oiling.
- basics. make sure all running systems are good and there's no air pockets in the cooling system
- if he can he uses heating elements to pre-heat fluids, if you can prime the oil system great.
- start the engine and let it get some temperature in it at a high-idle type of rpm.
- raise the rpm and vary it, not overly slowly but with a little bit of snap to it to build cylinder pressure.
- circle track engines he'll do 2-3k, my engine he said maybe more like 2200.
- do that like 10 times then let it settle back in, maybe more around 1500rpm.
- he does it for 30-35 minutes on the engine dyno, said you don't need to spend that much time in the garage.
- street drive it, New England backroad driving like a sane person is the basic prescription. No more than a few pounds of boost.
- He said for the finish he put on my bores he'd drive like that for 1000-1500 miles before hammering down! This was a big surprise to me... I haven't driven 1500 miles in 4 years. His logic is he really wants to make sure the rings are settled before putting the pressure on them.
We talked a lot about oil. They used to use the Driven BR30 I've used until they noticed a difference in the oil and found it had gone from ~1200ppm zinc to ~2200ppm. They did a few engines on the dyno and didn't think they seated as well as they should have, one they had to tear down and refinish. He said that amount of zinc is great for the cam but not for the rings, he was also soured by Driven not publishing a TSB on it. They use Valvoline VR1 now which is more like 1000ppm and he's never had a problem with it.
I bought 8 quarts of BR30 now I'm not sure what I wanna use...
Old 07-08-2022, 06:02 PM   #38
2 qts BR30 + 2-3 qts wally world basic?
Old 07-08-2022, 06:47 PM   #39
Stiggy Pop
Stiggy Pop's Avatar
I'd probably keep oils in the same family but I did consider if you could cut it like that!
Old 07-08-2022, 07:12 PM   #40
Kjets On a Plane
The Volvo break in dyno rig it looked like they put the cars on rollers with preheated fluids and if manual trans spun it up gently in 4th to ~1200/1500rpm, turned the ignition key on within 15 seconds/checked the gauges & simulated driving uphill immediately over 1-5 mins to bed the rings in and changed the oil?
Obviously, we have more time than money & aren’t working at production speed and can torque plate hone or bed the rings in a little less ‘abruptly’ over slightly more time then just crank it up to speed on the rollers/build hot oil pressure and drive it at a simulated uphilll but can only allocate 1-5mins per car to break them in leaving the factory?
We can probably allocate 20 mins or an oil change or two?
The diesel heads use a 12v glow plug to cycle on and off for coolant or oil heat or fuel heat pretty effectively (veggie, bio or just cold weather, generally?).
Obviously, most of us can’t afford a laboratory engine dyno room to clean room standards (maybe time-share access to one at best? ) …
Old 07-09-2022, 10:09 AM   #41
Cwazywazy
Single jingle
Cwazywazy's Avatar
Life's wayyyy too short to drive 1500 miles with a turbo and not use it.
Congrats on getting the block back though.
I don't know what I have
Old 07-10-2022, 01:14 AM   #42
sbabbs
sbabbs's Avatar
Diamond honed and Plato brushed, 2nd pull sets the rings.. Once it's up to temp, it's ready to go!
Old 07-14-2022, 08:28 AM   #43
linuxman51
BRANDSCHUTZVORSCHRIFTEN!
linuxman51's Avatar
I've been a fan of using boost to help the rings seal. you don't have to hit it with the full cupboard, but you don't have to baby it at 3psi either. A comfortable 15 would be fine.
Megasquirt Tuning!
linuxman51 is online now   Reply With Quote
Old 07-14-2022, 12:07 PM   #44
Hope this thing is up and driving for my summer trip up to the Berkshires.
www.BEIGEPOWER.com
Kaplhenke Racing Facebook
The only safe bet is Ben.©
Old 07-15-2022, 09:48 PM   #45
mikep
The MP
mikep's Avatar
Marvel mystery oil is trash. Do not use it in an engine.
Originally Posted by megulon-7 View Post
You Oregon beavers keep your hands off our sweet Cali redwood and we won’t touch your Portland $8 doughnuts.
