#76 |
Making Volvo Parts Fit
![]() Join Date: May 2008
![]() Working on comparing the 91 LH, EZK, Regina & Rex wiring diagrams - using Stiggy's spreadsheet as my base document (many, many thanks, Mike jr)
Once I start, I will photograph in tedious detail every step ![]() There are several differences compared to the 940 base he was going from, so I noted all the changes in yellow. In some cases the wiring is the same, that were different for him ![]() ![]()
![]() ![]() ![]() ![]() ![]() My XR July2013 - 446AWHP @ 8K rpm C30 AWD conversion 740 pickup thread Feedback Thread Last edited by lookforjoe; 06-26-2022 at 10:33 PM.. |
#77 |
![]() Flywheel reference info.
Rex = 44/2 (fig A). EZK116 = 60/1 (fig B) ![]() |
#78 |
![]() Keep forgetting to include a parts list. I'll edit it for part numbers. Adding TRB reference links where relevant to discussion/research. I'm including all the items that are involved - some may be useable as is/with mods (e.g. Regina fuel rail)
Bosch coil VO 1346071. Bosch 0221118351 Bosch coil wire VO 3531277 Power stage & heat sink VO 3501921 shielded wire Knock sensor (same) CPS (same) VO 271949 3547847. Bougicord 146404 60/1 Flywheel VO 6842012 6842013 (don't know which of the two is correct, both list 700/900 F/T model range) EZK 116 ECU EV1 Injectors ...357, (greens) 0280150804 VO 3517283 Injector ballast or; EV6 Injectors: (reds) 0280155759 VO 9454556 30lb LPT. (whites) 0280155766 VO 9454557 33.3lb HPT. (blues) 0280155830 VO 9186060 34lb HPT FPR 3517064 3 bar. Bosch 0280160294 LH fuel rail MAF. VO 3517020. 8251497 Bosch 0280212016 O2 sensor VO 3501753 Bosch 13957 IACV VO 1389618 Bosch 0280140516 ECT (same?). VO 1346030 TPS (same?). VO 3517068 Bosch 0280120301 0280120325 LH2.4 ECU Last edited by lookforjoe; 07-21-2022 at 10:45 PM.. |
Thread Tools | |
Display Modes | |
