Old 02-17-2012, 06:29 PM   #26
I disagree, car tire ain't going nowheres.
Old 02-17-2012, 06:43 PM   #27
rallybrick
Yeah, car tire ain't goin' anywheres on an all-steel front 145 on a smooth track.
Notice how many of the Swedish VOC gravel 240's lack them OR use the low-profile scoop without the cutout for the pickup. (And note that their roads are like smooth freeways compared to SW US rally roads):
http://www.volvooriginal.com/bildbanken/bildbanken.htm
Anyway, back to your normally-scheduled thread about trail-crawling 240's.
rallybrick is offline   Reply With Quote
Old 02-17-2012, 06:55 PM   #28
You're right it's unpossible.
Old 02-17-2012, 08:47 PM   #29
PetrolHead
PetrolHead's Avatar
Thanks for the responses guys. This is exactly what I had in mind. I'd really like to see the particulars of it. 240 Apocalypse edition. I'd appreciate any other inputs guys, thanks again. RallyBrick, I'll shoot ya a PM.
PetrolHead is offline   Reply With Quote
Old 02-17-2012, 09:34 PM   #30
crandandall
Turbobricks Low Life
crandandall's Avatar
Iirc that guy was using ipd overlads in the rear and some sort of spacers all around.
crandandall is offline   Reply With Quote
Old 02-17-2012, 10:50 PM   #31
Carl S
Carl S's Avatar
27 x 8.5 R 14 General Grabber AT2's
Only modification needed is slight fender lip rolling in the rear. Barely kisses the front spring perches.
The tires alone provide about a 1.5" lift.
Carl.
Work
Play
89 240
Carl S is offline   Reply With Quote
Old 02-19-2012, 08:34 PM   #32
atrokz
super cage design genius
atrokz's Avatar
For a car that is 2" lower with 2" less suspension travel stock, and a weak rear subframe to boot?
Small wonder
Uh, being lower, and planning on going even lower, is the reason I want to protect the pan. And at any rate, plenty of 7/9 cars racing off-road over in Sweden, so yes, it IS surprising there's no aftermarket one available.
And who cares what car is ">" than another. That's a silly thing to say. I like my 7, just like I like 2's, 1's, 8's, & 9's.
'06 BMW E91 3.0 DD
91 945 SE - Modded the turbobrick way
98 BMW E36 2.8 - Wife's car
92 245 DL WAS NOT TO BE -RETURNED FOR ZERO SPACE
91 745T RIP
94 850 NA RIP
95 850R GONE
Rob Ford was Canadas greatest president
atrokz is offline   Reply With Quote
Old 02-21-2012, 06:27 PM   #33
PetrolHead
PetrolHead's Avatar
I think I'm going to try the gradual approach and see how it goes. Since my springs are chopped, I need new ones regardless. I'll probably try some XJ springs on the rear, Diesel springs on the front, and a set of 27 x 8.5 R 14 General Grabber AT2's. Anyone have a source on some Diesel springs?
Old 02-21-2012, 08:04 PM   #34
andysbeta
thrsh
andysbeta's Avatar
Location: Mancos, CO (no longer the Central Valley Smog Bank)
If you can get ahold of the GT springs, via FCP groton they are a reproduction spring and will raise the front up a good 1" or so. I can't access the site right now due to a slow hellish connection otherwise I'd provide a link.
andysbeta is offline   Reply With Quote
Old 02-21-2012, 08:31 PM   #35
PetrolHead
PetrolHead's Avatar
I looked on FCP for those springs and couldn't find them...they all have the same description. If you happen to find a link, that would rock.
Old 02-21-2012, 08:52 PM   #36
PetrolHead
PetrolHead's Avatar
FCP claims to have front diesel springs. I wonder which would result in more lift, Diesel or GT springs?
Old 02-21-2012, 10:07 PM   #37
swiggy
Diesel. I have GT springs on the front of mine and they are a bit stiffer, but don't really raise the ride height. Maybe a few millimetres, but it really ain't much. Diesel will give you an inch or so lift
79 poo brown 245 - B23E/M46 swap. 405 head, K cam @ 4 deg adv. Bil HDs, dual sways, 2.5" exhaust etc. 5% tint, loud stereo and some sketchy wiring
82 yellow 244 - Slow as **** but nice and clean, gfs car
swiggy is offline   Reply With Quote
Old 02-22-2012, 01:08 AM   #38
klr142
Turbo, what?
klr142's Avatar
This. See if you can have FCP measure the wire thickness of the springs, though. From the factory, SOME of the diesel springs were 14.2mm and the GTs that had the stiffer front springs also had 14.2mm wire thickness springs, but they were a shorter overall height. I've also had some springs that were removed from diesel cars but they are only 13.9mm thick. That being said, the springs on my stock 1987 244DL are 14.0/14.1mm thick! Maybe they are just the same 13.9mm springs but have really thick paint.
All that jazz aside, I recently purchased some "used" black springs with tags on them that say made in Sweden and I am wondering if they are these "diesel/heavy duty" springs made by Scan-Tech that FCP is selling in the link above. They're 14.6mm in the front and the rears are 14.2mm(larger diameter than even the stiffer, lowering springs I have from TME and Lesjofars!).
Old 07-07-2012, 03:38 PM   #39
odinthewanderer
hmmm... i bought those "diesel" "gt" "hd" springs... whatever you want to call them.... same as in the link FCP's SKU is 302606....
next to the stock ones... they are shorter and fewer coils but thicker wire....
they also are narrow enough diameter that the retainer hat (or whatever it is properly called) does not want to seat... and there is a lot of wiggle room on the bottom....
say made in sweden on them... with a SKU of 302606
to my knowledge all springs should interchange and the strut assemblies used the same perches....
i wonder what the deal is.... of course these things are always noticed on the weekend...
here is the thread on the
http://turbobricks.com/forums/showth...51#post4236551
ask me what kind of stupid i am today?
92 240 wagon, aw70, (tool box, prepping to be driver) new mexico clean!
92 745tic mild stuff done(7s and 9s are not 240s, pulling engine to build for the 77, ask for parts, body is clean) for sale?
92 245 modified (sold)
77 244 dl (almost done with resto... SOOON)
91 245 m47, rust bucket winter beater (driver, now parts)
90 234 aw70, side swiped winter beater (driver)
72 ford highboy, farm rig
95 chevy g20, family pet pig.
odinthewanderer is offline   Reply With Quote
Old 07-07-2012, 04:02 PM   #40
I'd go for a coilover setup with long springs (14"). If you run out of droop length you could lengthen the housings and use 700 series inserts. Last time i checked those had 8" of travel
www.BEIGEPOWER.com
Kaplhenke Racing Facebook
The only safe bet is Ben.©
Old 07-07-2012, 05:24 PM   #41
odinthewanderer
oh and on the bfgs.... i was set on getting them...
then i was actually at the counter to pay for them....
discount tires had a 100 off for 4 tires, and i got them to match tireracks prices with shipping..... and i still could not justify paying for the bfgs.... when the car will still mostly see normal roads with some gravel and some dirt....
this is also supposed to be my wifes commuter.... so the tire need to be decent on the highway...
soooo... i ended up with YOKOHAMA Y356 supervans, which should look amazingly period on the 77...
they are light truck tires and come in 1600 1720 and 1850 lb load rating flavors.... and are all 25.7-25.8 and weigh out at 23-24 lbs while the bfg was far heavier at 31
i have not actually driven the car yet with them since the car is still apart... but i will let you guys know how it goes... NO, not really an "off road tire" but they should be decent on dirt and pretty stout. seemed like a nice all rounder till the season gets sloppy and it is time for snows... not convinced they will be all that great in mud lol
if i lived out in the boonies with only dirt paths i probably would have flopped the extra cash for the bfg ats
http://www.tirerack.com/tires/tires....3566&tab=Specs
and here they are on the "gt option" wheels
Old 07-07-2012, 08:06 PM   #42
bigbret
Campin in your backyard.
bigbret's Avatar
I am running on the front coil-over sleeves 2.5" ID springs 10" length #325 rate. This raised the front of the wagon about 1.75 over stock height. This is with the perch at the lowest setting.
Rear I have 14" #220 rate. With some rear coil-over hardware made by Jerd. Rears are at least 2" higher then stock. Rides great no body roll, corners excellent, best mod yet.
bigbret is offline   Reply With Quote
Old 07-08-2012, 01:16 PM   #43
odinthewanderer
pics! i demand pics!
Old 07-08-2012, 01:19 PM   #44
Brandon
Brandon's Avatar
This. I want to see what it looks like raised up and with those tires, i've had my eye on a set for a while.
Originally Posted by golgothan
Here is what you do to seal the deal, text her a picture of your nut sack stretched over a pine cone. I don't know why but girls totally dig it.
Brandon is offline   Reply With Quote
Old 07-08-2012, 02:50 PM   #45
JohnLane
Originally Posted by rallybrick View Post
That skid plate stops at the cross-member and does not protect the sump. If you're serious about going off-road, might be wiser to go with a bigger skidplate, but then you start dealing with heat issues (doesn't dissipate from the engine bay).
Ie (extends to the output shaft of the trans):
But then this is overkill and for going fast over rocky roads, not trail crawling. Per John Lane "Overkill is consistently more fun."
HDPE from McMaster-Carr is also a good solution. Slick, so it slides over rocks pretty well, it's light, and can be cut easily. Aluminum channel stock or L-brackets (readily available at Home Depot) work well to secure it in place and form it.
The skidplate in the rallycar is one intended for a VW Golf or Scirocco from a million years ago. Aluminum, strong and we built steel brackets so that we could bolt it to the car and to the crossmember. It has served well + adds strength.
Lots of room around the engine for heated air to get out..... Use enough radiator and fan to do the job.
Old 06-18-2018, 01:58 PM   #46
Mr. Butters
Mr. Butters's Avatar
Got the spring cups raised 2", cherokee springs under the rear, S10 shocks on the rear and a set of 235/75r15s on it this weekend. Trimmed the front lip of both the front and rear fenders. Lots of rubbing on the stock mudflaps so they are coming off with more trimming to see how that works. May also add Jeep XJ front levelers in the rear to raise it up a little further. Found the front frame is so out of shape that the IPD skid plate won't remotely fit. Fun regardless!
Mr. Butters is offline   Reply With Quote
Old 06-27-2018, 11:27 AM   #47
benski
Post
If you can score a locker rear end that would help in your quest for traction.
Old 07-03-2018, 01:48 PM   #48
Mr. Butters
235s are damn big. Switching to 205-225s for some more clearance to wheelwells! I will report after the Gambler 500 and more commuting.
Old 07-03-2018, 02:54 PM   #49
Khrrck
Professional Amateur
Didn't realize the 500 was next week. Would totally go in my stock wagon if I had a co-driver. Know anyone who's looking?
'87 240 budget wagon.
Old 07-03-2018, 05:41 PM   #50
GreatDaneShane
GreatDaneShane's Avatar
Chris in Austin (crazychopstick) lifted his 245 with spacers up front, jeep wrangler front springs and modified wrangler shocks out back.
If you could find someone to weld, you could raise the front even more by extending the strut tubes and putting a spacer in the bottom of the housing. Or, you could just cut and re-weld the lower front spring perch higher(2.5" is about as high as you want to go) This was done on mine up front with V8 Cherokee springs and dodge van shocks drilled out to fit the volvo hardware in the back.
GreatDaneShane is offline   Reply With Quote
