Old 07-18-2018, 02:05 PM   #51
Mr. Butters
Mr. Butters's Avatar
I did do the cut and weld on the front spring hats, though after extensive trimming i found 235s were just too big. I think there is something in between 205s and 235s that would be perfect, though budget was my main consideration. Plus time before being ready for the Gambler 500 off road relay!
Mr. Butters is offline   Reply With Quote
Old 07-18-2018, 03:01 PM   #52
MSGGrunt
Coil overs on the front make it easier, though not less expensive, to avoid taller tires from hitting the spring buckets.
1969 Triumph TR6
1986 BMW E30 325E, Auto, 2-door coupe.
1987 Volvo 240 Wagon Auto
1989 BMW E30 325iX 5-speed
1990 Volvo DL 240 Auto
1991 Volvo 240 Auto
1992 Volvo 240 GL Auto
1993 Volvo 245 5-speed.
2015 Volvo XC60 Platinum
MSGGrunt is offline   Reply With Quote
Old 07-18-2018, 03:07 PM   #53
MSGGrunt
On the rear use adjustable spring perches with Moog heavy duty coil springs part number CC217. This will net you anywhere from 2 to 3 inches of lift. The limiting factor on how much lift you can go with is predominately the steering geometry in the front end and the ability to align the car properly with stock lower control arms. As you go higher in the rear the pinion angle needs to be addressed with adjustable control arms and the side to side location of the axle can be corrected with an adjustable Panhard bar, both available from IPD. I have each and they are very high quality.
With this set-up I can fit 27" tall tires.
File Type: jpg Rear_Perch_SpringAssembly_1024x1024.jpg (21.0 KB, 432 views)
Old 07-18-2018, 03:13 PM   #54
MSGGrunt
The tires are 27x8.50R14 Kenda Klever All Terrain 6 ply
I paid $396.00 for 4 tires.
Old 07-18-2018, 03:18 PM   #55
MSGGrunt
I was going to run this set-up on my wagon, but that car ended up being too rusty and a less than desirable candidate. I am now thinking my higher mileage 240 sedan would be a prime candidate for a turbo swap out of a squirter block 940 with the suspension components and larger tires just for something with a different stance.
Keep us posted on your progress.
Old 07-18-2018, 03:23 PM   #56
MSGGrunt
I need rear shocks, can you post the brand and maybe part number of the ones you used?
Old 09-09-2018, 10:09 PM   #57
Volvosaur
Volvosaur's Avatar
any update?
Volvosaur is offline   Reply With Quote
Old 09-14-2018, 10:09 PM   #58
Wilford Brimley
LOCAL ONLY
Wilford Brimley's Avatar
I'd half suggest buying a jeep, and going further off road, but that's not what you're after.
ftfy
94 940T "Deb" build under way http://forums.turbobricks.com/showthread.php?t=354303
B5.5 passat wagon, low af sexier than most wagons here.
Old 09-20-2018, 01:42 PM   #59
Thor
Thor's Avatar
How does this work with Ben's adjustable rear perches?
I'm in the process of getting a bit of ground clearance as well for rallyX
Edit: never mind a quick look at his site got me the answer I was looking for.
1991 240 M-47 daily driver
Build thread: 91 240
Feed back: Here
Thor is offline   Reply With Quote
Old 10-09-2018, 07:54 PM   #60
80series
Originally Posted by Mr. Butters View Post
Got the spring cups raised 2", cherokee springs under the rear, S10 shocks on the rear and a set of 235/75r15s on it this weekend. Trimmed the front lip of both the front and rear fenders. Lots of rubbing on the stock mudflaps so they are coming off with more trimming to see how that works. May also add Jeep XJ front levelers in the rear to raise it up a little further. Found the front frame is so out of shape that the IPD skid plate won't remotely fit. Fun regardless!
Any negatives to raising the spring cups versus just extending the strut bodies? Have you noticed any ill effects of doing this? I could get away with just raising the cups i think running the 27" mud tires i have.
80series is offline   Reply With Quote
Old 10-11-2018, 07:24 AM   #61
D.E
tvåförti
D.E's Avatar
In for this. Mine are too short after putting in overloads.
'88 Volvo 245 - B230F, LH2.4, A-cam, 4-2-1 header, de-cat, M47
'83 Volvo 244 - B23A, M46, 48k miles
'64 Ford 17M, '59 Plymouth Custom Suburban, '76 Ford Granada 2.8
D.E is offline   Reply With Quote
Old 10-19-2018, 10:00 PM   #62
80series
Im running KYB Excel-G part number 344082. Im using wagon overloads and a 1" spacer, they seem like a good fit. I just had to drill out the metal bushings in the shock bushings a little.
Old 10-19-2018, 10:03 PM   #63
Probably a better plan they tend to bend when lengthened by adding on a with stock wall thickness tube section.
Old 10-19-2018, 11:10 PM   #64
80series
Gotcha. I had planned on sleeving the strut tube with some schedule 40 pipe. I feel like this would be much stronger than just butt welding in more of the same thin tube. Not sure which way to go now. Does moving the spring cup net any lift?
Old 10-19-2018, 11:15 PM   #65
In that it would move the spring itself up, and lengthen the assembly yes.
Old 10-19-2018, 11:25 PM   #66
Jack
junkman
Jack's Avatar
they do fine offroad stock
better idea is to slap some volvo badges on a 80s Cherokee. They already look the same
I love you even more Jack.
Old 10-20-2018, 05:13 AM   #67
D.E
tvåförti
D.E's Avatar
Quick! Someone tell me how these are going to kill me before I put them on my car.
Old 10-20-2018, 09:01 AM   #68
80series
I meant just cutting the spring cup and moving it up versus adding in length to the tube. I didn't know if "preloading" the spring any would lift the vehicle any. Im guessing probably not...
Old 10-20-2018, 11:53 AM   #69
You haven't already died a fiery pus filled death boiling the oil in those cartridges welding them up?
Old 10-20-2018, 12:04 PM   #70
D.E
tvåförti
D.E's Avatar
Nah, I welded in the non-explodey end.
Old 10-20-2018, 09:16 PM   #71
80series
Ended up cutting my strut tubes and sleeving them with 2" schedule 40 pipe. Very tight fit, but i feel this will be very strong. I'll finish up reassembly in the morning. Cant wait to get this thing on the road!
Old 10-21-2018, 09:52 AM   #72
D.E
tvåförti
D.E's Avatar
Car rides like stock now. Fixed all bumpiness.
Old 11-01-2018, 05:52 PM   #73
80series
Did you do anything to your panhard bar, or just let it ride as is?
Old 11-23-2018, 11:19 PM   #74
80series
Originally Posted by andysbeta View Post
I made a feeble attempt at one, but it doesn't matter good luck with yours.
Mine is about 2 1/2" higher than stock, 28 x 8.50 R14's on it.
where did you find that size tire? what brand are they? Any pics of the skidplate you made? Thanks in advance!
Old 11-24-2018, 01:50 PM   #75
Canadan
Canadan's Avatar
A bit late but for the rear, check out 32322 Monromatic shocks off a ford expedition. They are supposed to have the same collapsed length as stock but 4 inch more extension.
Canadan is offline   Reply With Quote
