Old 11-19-2018, 03:44 PM   #26
kingkong
kingkong's Avatar
Before I take the gearbox down (what a ****in pain in the ass) could somebody confirm the part numbers on clutch disc and pressure plate please?
Again, does it need to be bedded in or not?
kingkong is offline   Reply With Quote
Old 11-19-2018, 03:49 PM   #27
culberro
culberro's Avatar
WAY too much grease on the hub. You just need a little bit on the inside of the spline area, it's doing nothing sitting on the face of the hub like that. The extra grease could have gotten onto the pressure plate, causing the disc to slip.
Old 11-19-2018, 08:43 PM   #28
sbabbs
sbabbs's Avatar
I second that too much grease for sure. Once your disc starts spinning all that goes out towards the clutch surface. I put a dab of never seize on the input shaft where the throw out bearing moves back and forth. That is all I do. That never spins.
https://re-volvparts.com/store/home/...ine-volvo.html
850R Clutch Kit 272218 Genuine Volvo
Old 11-20-2018, 04:26 AM   #29
kingkong
kingkong's Avatar
Didn't think that much grease could cause so much slip.
I guess it's disassembly time i guess. Shyte. Thank you guys.
