Old 11-12-2017, 01:46 PM   #1
V70XC
Default TD04 Turbo blanket
Im trying to find a turbo blanket for a TD04, but I can't find one that isn't Subaru specific, which seems to end up being more expensive. I've checked PTP and a few other sites and found T3 T4 and T6 blankets, but found no answers as to if a T3 or a T4 blanket would fit on it.
V70XC is offline   Reply With Quote
Old 11-27-2018, 08:36 PM   #2
thismachine13
I have this same question. Buy a T3 sized blanket for my TD04?
Old 11-27-2018, 10:12 PM   #3
Wilford Brimley
Is posting from the grave
Wilford Brimley's Avatar
I d k man td04 turbine housings are pretty small
Old 11-27-2018, 10:28 PM   #4
thismachine13
This is the only image I can find of a T3 blanket on a td04 turbo. Not a terrible fit really.
Old 11-27-2018, 10:34 PM   #5
2turbotoys
Astro Zombie
2turbotoys's Avatar
Its actually a lot easier to install if its a bit loose, and doesn't hurt anything
1978 242, 5.3 L33
1979 242, MS, R brakes
2006 V50 T5 AWD @ 17 PSI
Old 11-27-2018, 10:37 PM   #6
thismachine13
Thanks brother. Sorted!
Old 11-27-2018, 10:42 PM   #7
2turbotoys
Astro Zombie
2turbotoys's Avatar
Old 11-28-2018, 10:15 PM   #8
hikerguy
hikerguy's Avatar
What are people looking for from these turbo blanket? We make high temperature blankets for power plants and industrial application. I don't see why we couldn't make custom. https://photos.app.goo.gl/W7Gm7bnKA6M957ii8
+1 million miles of white block sitting in the drive way
hikerguy is offline   Reply With Quote
Old 11-28-2018, 10:54 PM   #9
thismachine13
Myself I'm looking to keep underhood temps to a minimum.
Old 11-28-2018, 10:59 PM   #10
2turbotoys
Astro Zombie
2turbotoys's Avatar
I think he meant why are people looking for something that is common in his world, custom heat blankets for industrial machinery. Which is not common to most of the rest of us. Most people don't look towards custom industrial applications for their cars hikerguy, but good to know thats out there, thanks
Old 11-29-2018, 06:31 AM   #11
hikerguy
hikerguy's Avatar
No I'm honestly looking for characteristics. As an insulator I see that flange and down pipe and think why only the turbo. What type of closures are people looking for, springs, buckles, high temp Velcro, wired? Looking around at some online pictures I saw most of them were very thin, not alot of r value. What kind of life expectancy are people getting from this application, how often are they really being removed? Not trying to high Jack by any means, just curious
Old 11-29-2018, 11:05 AM   #12
gsellstr
gsellstr's Avatar
Typically they end up being thin just due to fitment and cost I suspect. Main benefits would be keeping the heat from the engine bay, also keeping the heat in the snail to help slightly with spool time. I'd expect either spring or buckle would suffice.
I looked into some options for the Garrett, everything was either cheap and didn't fit worth anything or VERY spendy. Even the supposed drop-on for my turbo didn't actually fit my turbo.
RIP
Nick Fengler "fengler" 8/6/18
74 144 B20
90 745Ti
Old 11-29-2018, 02:29 PM   #13
thismachine13
From what I’ve been able to read.....the cheap blankets do a good job of insulating the turbo to keep heat out of the engine bay. It’s also seems that the cheaper blankets are almost a one time use. A lot of the reviews I’ve read are from them coming apart upon removal.
Old 11-29-2018, 02:38 PM   #14
LeedomtoFreedom
LeedomtoFreedom's Avatar
This is the case with a lot of the exhaust insulating products. The cheap stuff just disintegrates when you remove it and spreads these awful glass fiber type of sh*t that clings onto clothes and pokes you constantly. Ask me how I know.
81 264 - Sold
90 245 - coming BACK baby
Old 11-29-2018, 03:19 PM   #15
hikerguy
hikerguy's Avatar
Yeah glass cloth starts coming apart at 1000f. I saw alot that kevlar/nomex thread but that's not even rated to 500f. What kind of temps are most guys running up to? I used to work at a drag strip and most of them would try to keep egt's under 1300f but that's running 1/4s
Old 11-29-2018, 03:42 PM   #16
Martin L.
Kombinationskraftwagen
Martin L.'s Avatar
Judging by the color of the turbine housing, the temperature after a longer WOT drive is around 750°C/1400°F on some areas. TD04-16T
IDKFA
Martin L. is offline   Reply With Quote
