Old 11-02-2018, 01:09 PM   #1
Marvelous3
Who engineered this?
Marvelous3's Avatar
Default retro turbo solid motor mounts for 240's
Has anyone used these? Obviously they'll vibrate more than factory rubber but how bad are they? Similar to poly mounts?
http://www.retroturbo.com/?product=v...0#!prettyPhoto
Old 11-02-2018, 01:57 PM   #2
Stiggy Pop
Stiggy Pop's Avatar
it's got some rubber in there...
my dashboard is a 3k rpm tuning fork with Yoshi heavy rubber mounts. I actually got much less frequency vibes with poly mounts.
'79 242
943 pickup
Old 11-02-2018, 07:21 PM   #3
classicswede
Volvo upgrades
With the extra hard poly mounts I only get any vibration at idle, and yes the dash does vibrate but that car spends so little time at idle its of no bother
Old 11-02-2018, 09:52 PM   #4
I would think the rubber bushng would help enough that you'd be fine. I was just looking through my parts and found my blue poly RSI motor mounts. I think they are good for display only.
1982 242 turbo. 340k miles. MVP coilovers and 3" exhaust. Flowed 405 with a V15. Cossie turbine housing with upgraded compressor housing. 90+, IPD remote oil filter. Some other goodness, too. Been lots of fun over 25 years. Restored in 2k. Now ready for a 2nd restoration.
Old 11-02-2018, 09:53 PM   #5
2turbotoys
Have you seen me?
2turbotoys's Avatar
I thought I would see hockey pucks with holes drilled thru them in this thread when I saw "old school" lol
1978 242, 5.3 L33
1979 242, MS, R brakes
2006 V50 T5 AWD @ 17 PSI
Old 11-04-2018, 10:40 AM   #6
Hank Scorpio
Chubfest 2009 Survivor
Hank Scorpio's Avatar
I’m using the same companies mounts for whiteblock to 240 and they are really well made. If you wanted to ditch the OEM redblock mounting all together, these would probably be a great choice.
Old 11-19-2018, 03:49 AM   #7
wujek
wujek's Avatar
I have these in my 740 an I'm quite happy. Gas response is really nice and vibrations - not so big to not get used to.
my '88 744+
WANTED:
-red floor mats for 7/9
wujek is offline   Reply With Quote
Old 11-19-2018, 11:51 PM   #8
MDVLN
Kapitän Klugscheißer
MDVLN's Avatar
They're made by these guys by the way http://anderssonsteelspeed.se/
Retro turbo helps them fill orders etc (oddly enough with the current USD (assumed) exchange rate it's also cheaper to get them from there, prior to shipping charges anyway)
Old 11-20-2018, 12:06 AM   #9
John V, outside agitator
$50 less direct today..Go direct.
Sleezattle WA, USA
--> CALL (206) 431-9696<----
www.rallyrace.net/jvab
www.rallyanarchy.com
Vive le Prole-le-ralliat
— Don Marquis
Old 11-20-2018, 10:06 AM   #10
Mudbutt
I just installed these in my ‘88 240 (8v, solid torque rods, t5 w/ one piece driveshaft, spherical bearings, poly front) There’s slightly more dash rattle at idle but they seem smoother on decel and cruising. This is relative to the hard plastic Yoshifab mounts I was using. The andersson speed and steel mounts are really well made and fit perfectly. I bought them from RetroTurbo on a Wednesday and had them the following Monday. Anderssen Speed makes tons of cool mounts for engine and trans swaps.
Mudbutt is offline   Reply With Quote
Old 11-20-2018, 03:27 PM   #11
Marvelous3
Marvelous3's Avatar
My interest was mostly looking at a way to remedy the drivers side in sheer motor mount on a 240 without having to resort to some fugly ratchet strap.
Old 11-20-2018, 07:03 PM   #12
Vincent Gagnon
Vincent Gagnon's Avatar
Member of TBCCS
Old 11-21-2018, 08:23 AM   #13
Marvelous3
Marvelous3's Avatar
^yeah, I dont think I'm going to do all that.
Old 11-21-2018, 10:23 AM   #14
Stiggy Pop
Stiggy Pop's Avatar
not much room for a big snakey header on the pass side with the big boxed out rally setup.
Old 11-21-2018, 12:32 PM   #15
MDVLN
MDVLN's Avatar
You can certainly try - They are going to tell you to buy through a distributor/reseller if you want to ship outside of Sweden as they will not invoice/quote separately, and do not have any other shipping options available in their checkout.
Old 11-22-2018, 12:22 AM   #16
RvolvoR
You can probably also get them for a bit less from LMR. I am using the ASS whiteblock mounts in my 242.
Old 11-22-2018, 12:35 AM   #17
Call them and cuss 'em out..Lata djävlar...
Simple as pie.
They are 1,2 km from Postkontoeret på Stogatan...1200meters..
Shirley they can post things like anybody else.
https://www.google.com/maps/dir/Ande...371327!1m0!3e0
Old 11-22-2018, 11:43 AM   #18
DET17
Reformed SAABaholic
FWIW I reached out to Anderssen via email, and while their suggested distribution was thru LMR, they were happy to sell direct to me. Great folks, all they needed was an electronic funds transfer and they were "good to go". I ended up buying my set fit checked used from MikeJr. or I would have bought direct from Anderssen Speed.
Old 11-22-2018, 04:15 PM   #19
miguels244
I can automate that.
miguels244's Avatar
What happened to the hockey pucks and a chain?
I think people think I think things that I don't think.
But at the very least, when your rhetoric matches up so neatly with the actions of a deeply deranged individual, it should give you some reason to rethink what you're saying, and how you're saying it.
As gun owner and firearms enthusiast, I will not sacrifice our sons, daughters, fathers, mothers, friends and lovers on the bloody Altar the NRA has built.
It's time to sane up.
miguels244 is online now   Reply With Quote
Old 11-24-2018, 03:45 PM   #20
GeneralBurrito
GeneralBurrito's Avatar
The motor mounts look nice, but I'm more interested in their coilovers.
Old 11-24-2018, 03:52 PM   #21
Cwazywazy
Single jingle
Cwazywazy's Avatar
What's wrong with some heavier duty rubber mounts? I put a Land Rover mount in my passenger side and a diesel mount on the drivers. I've been perfectly happy with it. Not like poly/solid mounts are gonna make you faster.
I don't know what I have
Old 11-25-2018, 08:26 PM   #22
Vincent Gagnon
Well, it's just a street car...
The alternator is a bit of a pain in the ass to access, but that's about it.
Old 11-27-2018, 01:05 AM   #23
Shifted
Banned
These work nice.
Shifted is offline   Reply With Quote
