Old 11-28-2018, 07:34 PM   #76
t8fanning
8v are still cool, right?
t8fanning's Avatar
Originally Posted by blkaplan View Post
Tate is also living at high elevations. his old setup would have been much faster and probably adequate at sea level.
Elevation is definitely the issue. When I drove to Socal euro it made 30 psi all day down there and even overboosted. I had to drop wastegate duty by like 15% at high RPM. The car felt so much faster. Once I got back up to elevation boost dropped right back down and wouldn't make my target.
1982 242 Turbo.
Old 11-28-2018, 07:39 PM   #77
doucheNozzle
doucheNozzle's Avatar
Guess you know what you need to do.
'00 XC70 SE - Slow
'04 V70 T5A - Feels Fast
Old 11-28-2018, 10:33 PM   #78
RvolvoR
Definitely agree on the timing comments.
oh, elevation absolutely was the reason for his...but a 6258 isn't going to make anywhere near 600hp for damn sure. My coworker has a 7670 on his evo 8 with a 1.01 housing on it and is still at 25-26 psi to make 450whp on an engine with a much better flowing head...
Old 11-29-2018, 08:59 AM   #79
Mogly
280WHP Regina
Mogly's Avatar
But it'll sure get me to the 500hp even my s256will get me into the 500hp mark no issue.
If your friend has that turbo and is only doing what a stock evo turbo does y'all need the pros.
403whp, profile picture
Ford Colonge V6 in the works.
Mogly is offline   Reply With Quote
Old 11-29-2018, 09:01 AM   #80
Mogly
280WHP Regina
Mogly's Avatar
Why complain about my timing? maybe you outta go outside pop that laptop open and see what you are doing wrong.
Old 11-29-2018, 10:01 AM   #81
linuxman51
BRANDSCHUTZVORSCHRIFTEN!
linuxman51's Avatar
mog be like:
>advances timing<
still slow
>advances timing<
still slow
>advances timing<
>breaks engine<
"you guys are a bunch of *******s"
Megasquirt Tuning!
Old 11-29-2018, 10:10 AM   #82
JohnMc
JohnMc's Avatar
I know my 16V certainly felt faster with a bit more timing advance. Wheeeeeee!!!!
Then after a few K miles, the MLS would start pushing coolant at full boost.
'63 PV Rat Rod
'93 245 16VT Classic #1141
Old 11-29-2018, 10:41 AM   #83
Marvelous3
Who engineered this?
Marvelous3's Avatar
This is becoming my favorite thread of November.
Old 11-29-2018, 11:01 AM   #84
RvolvoR
you know how i know you don't know what you're talking about?
Old 11-29-2018, 11:03 AM   #85
Mogly
280WHP Regina
Mogly's Avatar
mog be like:
>advances timing<
still slow
>advances timing<
still slow
>advances timing<
>breaks engine<
Come on Howard, it's not an ls.
Old 11-29-2018, 11:04 AM   #86
Mogly
280WHP Regina
Mogly's Avatar
I can give two ****s what you think.
Old 11-29-2018, 11:11 AM   #87
JohnMc
JohnMc's Avatar
Are you suggesting it's harder to make HP with an LS?
Old 11-29-2018, 11:17 AM   #88
Mogly
280WHP Regina
Mogly's Avatar
Inside joke.
Hell no, LS engines be killing it.
Old 11-29-2018, 11:23 AM   #89
RvolvoR
uhhh...the record for a stock IX turbo...on a built bottom end...running e85...on a MIVEC motor (evo 9)...on 30 psi....is 440ish whp.
Ergo, calm down there, little buddy.
I think I've got it figured out...you don't realize that EFR numbering nomenclature isn't the same as Precision numbering.
Old 11-29-2018, 11:24 AM   #90
RvolvoR
Actually....I already knew you didn't know when you talked about running 38* of timing...
Old 11-29-2018, 11:26 AM   #91
cosbySweater
cosbySweater's Avatar
mog be like:
>advances timing<
still slow
>advances timing<
still slow
>advances timing<
>breaks engine<
1982 Ford Fairmont Futura. 3sge Beams, j160 6speed, full aje suspension and tubular arms everywhere
1995 Porsche 993
Old 11-29-2018, 12:20 PM   #92
Mogly
280WHP Regina
Mogly's Avatar
440whp, what's that in crank HP?
Yes I do. But both turbos I mention may not push 600hp, but they sure will gete close.
Why you being a little bitch about the timing?? I hope you realize that's on e100 low boost and midrange rpm, my final timing ° is 2x° at my final rpm maybe less under load.
Old 11-29-2018, 01:03 PM   #93
RvolvoR
You are literally talking right out of your leather Cheerio. Show me, oh wise one, where a td05 framed turbo has made more that 440awhp in an evo...
Also, an efr 6258 ran at the kind of boost you need for it to make 600whp will literally explode...the compressor wheel will be well beyond it’s over speed rating.
Also, talking about “midrange, part throttle, low boost” timing numbers is like saying you have a 9” flaccid unit, but it goes down to 4” rock hard.
Shoot...for that matter, I run 50* of timing on pump gas...at no boost...and barely any load...at 2% throttle.
Old 11-29-2018, 11:07 PM   #94
2turbotoys
Salaminizer
2turbotoys's Avatar
Lol
2006 V50 T5 AWD 16 PSI +
Old 11-30-2018, 11:05 AM   #95
linuxman51
linuxman51's Avatar
I just like the gratuitous use of "leather cheerio" and the amazing "shrinking unit" (musta been cold outside!)
Old 11-30-2018, 01:40 PM   #96
pretty much. It probably wont knock on e85 but you aint doing anything any favors at that number.
www.BEIGEPOWER.com
Kaplhenke Racing Facebook
The only safe bet is Ben.©
Old 11-30-2018, 03:54 PM   #97
RvolvoR
It’s short, but man is it thin.
Old 11-30-2018, 10:36 PM   #98
mikep
The MP
mikep's Avatar
i know a guy in alabama who tried real hard to blow up an evo.
Originally Posted by DaBossk View Post
dornald blormpf bad because he has spine xd
I think that's a bit of a stretch to put him in the phylum chordata.
Old 12-02-2018, 10:58 PM   #99
linuxman51
linuxman51's Avatar
wasn't me. mine had a 35r on it, not a stock turbo (also made 440 awhp)
Old 12-06-2018, 12:12 PM   #100
Andrewhans
Turbo LS ****poster
Andrewhans's Avatar
Originally Posted by dl242gt View Post
Andrewhans. You can use the formula on the home page here to calculate your hp to a reasonable educated guesstimate. http://www.turbobricks.com/resources...uartermiledyno
Have fun! I got 634.7hp for your car.
That's actually a really cool calculator! At race weight of 3320lb @ 138.5mph I came up with 740hp net. So it's doing a little better than I was expecting.
I've ran the numbers on the Wallace Racing Calculator and it's come up with 680hp at 3320lb race weight. Not sure were the calculation difference is but either way interesting numbers!
60' 1.66
1/8 6.53 @ 113.3mph
1/4 9.99 @ 140.4mph
20psi 11.5deg timing E85
3140lb no driver
3320lb with driver
