Old 11-06-2018, 07:53 PM   #1
ogamer777
ogamer777's Avatar
Default 240 non abs SS lines question
I snapped the end of a couple of the hard lines trying to remove them, so I was wondering if anyone has used complete stainless steel lines from the octopus to the calipers? I have the short ipd style lines already. Any tips?
84 242 DL M46 212k
82 244 GLT (15G) M46 237k+
81 264 GLE M46 105k
Feedback thread: http://forums.turbobricks.com/showthread.php?t=322924
Looking for some hard to find Volvo accessories for my 82 GLT. Especially rubber trunk mats.
Stuff I have already:
http://forums.turbobricks.com/showthread.php?t=331526
ogamer777 is offline   Reply With Quote
Old 11-06-2018, 08:49 PM   #2
Vincent Gagnon
Vincent Gagnon's Avatar
Make new hardlines?
Takes a few minutes, costs a few bucks, will last for a long time.
I am assuming you are talking about flexible braided stainless steel lines right?
Old 11-06-2018, 08:53 PM   #3
Go to the rallye spares depot and buy some more.
Old 11-06-2018, 09:43 PM   #4
ogamer777
ogamer777's Avatar
Never done it before. Was considering getting used lines from another car tho.
Originally Posted by Vincent Gagnon View Post
Make new hardlines?
Old 11-06-2018, 10:09 PM   #5
culberro
culberro's Avatar
It would be expensive, and would result in a softer brake pedal compared to the hardlines. The pedal softness is caused by the plastic inner sleeve expanding before it can be restrained by the woven metal outer.
Just replace the hardline. Either used, or grab some 10mm bubble flared sections in approximately the correct length from the autoparts store and bend them to fit.
Old 11-06-2018, 11:29 PM   #6
Vincent Gagnon
Meh, get yourself a simple kit in any part store (they are dirt cheap), the correct fittings and cut/flare them yourself, it's easy and there is 1000000000 "how to" video on the interwebz.
Just make sure to do the correct flare.
Old 11-07-2018, 01:16 AM   #7
ogamer777
ogamer777's Avatar
Thanks for the input. While I'm at it, is there a better fitting to use that isn't (assuming) brass? The reason the line broke was the 11mm nut rounded just by looking at it.
I'll need to know what diameter Hardline and which fittings to get specifically, as I have no idea.
Old 11-07-2018, 01:42 AM   #8
Vincent Gagnon
The line is 3/16 and can't remember the fitting threads and sizes and I don't have a line or calipers to look at right now. Somebody around here will probably have this info. Worst cast, just bring one line to the parts store and show it to the counter guy. I remember they are common stuff.
Old 11-07-2018, 01:46 AM   #9
There's your problem, the flare nuts are 10mm.
The lines are still available from Volvo.
https://forums.turbobricks.com/showthread.php?t=344513
If you want to make your own lines, it's 3/16" and the fittings are M10-1.0 thread bubble flare. Use Cunifer brake line. It's what Volvo used (and helped develop as a replacement for steel lines since it doesn't corrode) and is easy to bend.
Old 11-07-2018, 01:48 AM   #10
1989 Volvo 240
Old 11-07-2018, 09:47 AM   #11
ogamer777
ogamer777's Avatar
Damn. Guess I didn't try the 10mm enough times.
Thinking to go for just making my own, sounds like something I can handle. Thanks all.
Old 11-07-2018, 01:23 PM   #12
A tough rowing ho
The stock flare nuts on my 1980 were 11mm or 7/16"
Old 11-07-2018, 03:11 PM   #13
Old 11-07-2018, 03:54 PM   #14
Yeah, I don't know what I was thinking. They're 11mm. Not only that but I posted a link to wrong hard lines.
Old 11-07-2018, 04:35 PM   #15
ogamer777
ogamer777's Avatar
Okay so I wasn't going crazy lol.
So just to confirm what you said earlier was correct, 3/16 line and m10-1.0 thread bubble flare?
Funny thing is I think I have that wrench somewhere.
Old 11-07-2018, 04:40 PM   #16
That was the only thing I said in that post that was correct.
Old 11-07-2018, 07:58 PM   #17
white855T
Some just round off from old age. Always use a counter hold 14 mm flare nut wrench for the hose and the correct 11 mm flare nut wrench for hard line. I keep a bunch of the hard lines on hand because you just never know.
Buyer/Seller Feedback
Old 11-07-2018, 09:54 PM   #18
nel621
You are using flare nut wrenches,yes?
Old 11-07-2018, 10:07 PM   #19
ogamer777
ogamer777's Avatar
I was also using the 14mm wrench on the rubber hose side too. A few rounded but was able to get them loose with channel locks.
Wasn't using the correct flare nut wrench...lesson learned.
Old 11-07-2018, 10:14 PM   #20
Vincent Gagnon
This could also be your friend :
Old 11-08-2018, 02:18 AM   #21
ogamer777
ogamer777's Avatar
Tried that lol
Old 11-10-2018, 08:57 PM   #22
ogamer777
ogamer777's Avatar
I am having some trouble finding the correct M10-1.0 thread bubble flare parts...There are a bunch of different style and whatnot.
https://www.amazon.com/Nut-Bubble-Fl.../dp/B078Z7H11H ???
Old 11-10-2018, 10:29 PM   #23
http://store.fedhillusa.com/m13.aspx
They also have Cunifer brake line.
http://store.fedhillusa.com/316475mmbrakeline-2.aspx
Old 11-11-2018, 01:25 AM   #24
ogamer777
ogamer777's Avatar
Much obliged. Got them ordered.
Now, any tips for flaring tools? Or should i just go to harbour freight?
Old 11-11-2018, 12:22 PM   #25
Marvelous3
Who engineered this?
Marvelous3's Avatar
When I did the caddy brakes on the red wagon I rounded off a couple of lines. I ended up going to pull a part and getting new ones. Was much easier than trying to fabricate something.
