Old 11-18-2018, 07:23 PM   #1
towerymt
the real Towery
towerymt's Avatar
Default EV1 vs EV6 on 8v head - any reason to stick to narrow-angle-spray EV1 injectors?
I've just sent off two sets of injectors to be cleaned...one set of EV1 orange injectors from an 850 Turbo and one set of EV6 blue injectors from a later 70 series turbo.
I'm curious about thoughts, experience, and hopefully even documentation as to which spray pattern is preferred by the 'ol 8v head as seen on a B230F (+T).
EV1 appear to have a much narrower pattern than the EV6. Is the pattern of the EV6 meant for an oval shaped intake port? Does the EV1 spray pattern hitting the intake valve atomize just as well as the EV6?
Most of what I find when searching for injector information is about the difference in connectors, body width, flow rate, resistance, etc. I haven't come across anything definitive about spray pattern vs. port shape.
Old 11-18-2018, 08:12 PM   #2
thismachine13
I just remember someone posting that the “puddle” injectors were actually better for our engines than the “misting” injectors. When I get back to my laptop I’ll dig it out.
Old 11-18-2018, 10:01 PM   #3
lummert
lummert's Avatar
Been experimenting with Bosch 0 280 155 811 injectors from a supercharged Buick 3800 (363.1 cc/min-34.55 lbs/hr) on my 1988 765 Turbo with LH 2.2. So far they are working better at 2.7 Bar fuel pressure. They must be atomizing well enough because the exhaust is burning cleaner.
Old 11-18-2018, 10:03 PM   #4
thismachine13
Here’s the thread......it was the video on page 3 that I remembered. Lots of pissing and moaning in the thread then talk of port soak.
http://forums.turbobricks.com/showth...Fuel+injection
Basically pintle may be “better” for our 8v engines. All that said I just installed White injectors and a 3.8 bar FPR to go with my 19t until I get a wideband. I’m all driving like Ms Daisy scared I’m gonna go lean and pop my engine.
Last edited by thismachine13; 11-18-2018 at 10:43 PM.. Reason: Forgot to post the link
Old 11-18-2018, 10:46 PM   #5
thismachine13
......and the post with the video.
http://forums.turbobricks.com/showpo...6&postcount=52
Old 11-19-2018, 02:04 AM   #6
towerymt
the real Towery
towerymt's Avatar
Thanks. This is what I was looking for (from the thread linked above):
http://forums.turbobricks.com/showth...08#post5502208
(Also worth noting, I'm referring to narrow-angle-spray injectors as EV1 and wide-angle-spray injectors as EV6 even though that's probably not accurate all the time.)
Think I think I'll stick with the orange 850 turbo injectors after all. Anyone want five blue 0 280 155 830 injectors?
Old 11-19-2018, 01:36 PM   #7
lummert
lummert's Avatar
Bosch White Giants 0 280 155 811 (36 lbs/hr, 380 cc/min) Spray type: Conical 8-24 degrees.
Old 11-19-2018, 01:38 PM   #8
Lord_Athlon
Just damn
No one calls 36lb injectors Giants.
84 242 turbo msII
My build https://forums.tbforums.com/showthread.php?t=8675309
Old 11-19-2018, 02:01 PM   #9
www.BEIGEPOWER.com
Kaplhenke Racing Facebook
The only safe bet is Ben.©
Old 11-19-2018, 02:37 PM   #10
shoestring
shoestring's Avatar
I noticed absolutely no difference in these two injector styles. I did not, however, try tuning them on a dyno.
Old 11-19-2018, 02:44 PM   #11
lummert
lummert's Avatar
In GM LS engines at 4 Bar (58 psi) they are called 42lb White Giants (0 280 155 868).
Old 11-20-2018, 12:48 AM   #12
Wilford Brimley
LOCAL ONLY
Wilford Brimley's Avatar
Lol that's a small injector for a giant
B5.5 passat wagon, low af sexier than most wagons here.
Wilford Brimley is online now   Reply With Quote
Old 11-20-2018, 01:33 AM   #13
sbabbs
sbabbs's Avatar
I got the EV14's on my SE 550cc's 3 inch AMM. Only thing I noticed is the motor idles smoother.
Old 11-21-2018, 01:58 AM   #14
OttoB
I have tested these (link below) on crank dyno and B230F+16T. 0280158123 have two sprays in 24deg angle. No issues with idle, emissions or BSFC. https://www.bosch-motorsport-shop.co...-ev14-injector
