Old 11-20-2018, 07:48 PM   #1
Pro Sneaker Peddler
Default Rear R brake Calipers in 240 - Hard Lines
Hi all,
For those that have made this rear conversion before, is there an off-the-shelf solution available to get the rear brakes to work?
Thanks
Old 11-20-2018, 08:00 PM   #2
77volvo245
77volvo245's Avatar
buy a bubble flare tool
STSmachining
Old 11-20-2018, 08:19 PM   #3
Pro Sneaker Peddler
No thanks. I hate building brake lines. It also does not resolve the problem that there would need to be a female to female adapter anyway
Old 11-20-2018, 08:34 PM   #4
Pro Sneaker Peddler
I think I found what I need:
https://www.summitracing.com/parts/rnb-785-439/
That and a metric bubble flare assembly should do it, unless somebody else has a better suggestion.
Also considered a compression fitting to extend the hard line but this seems like the type of application where that solution may not be the best...
Old 11-20-2018, 08:37 PM   #5
culberro
culberro's Avatar
Buy 3/16" hardline with 10mm bubble flare on both ends from your local autoparts store?
The bubble coupler you posted will allow you to go full TB. if you want find a single line that'll work.
Or you can come by the shop and we can do it with AN fittings and hardlines....
Old 11-20-2018, 08:43 PM   #6
Pro Sneaker Peddler
I mean if you wanna do that be my guest. Car won't be moving for a few months though.
Old 11-20-2018, 09:38 PM   #7
Vincent Gagnon
Banned
Ok, I have to ask : Why do you hate building brake lines?
Old 11-20-2018, 10:42 PM   #8
2turbotoys
Salaminizer
2turbotoys's Avatar
https://www.stsmachininginc.com/prod...brake-s60r-kit
I got this, not sure why 77volvo245 didn't post that for ya lol, is that what you need? Maybe its because you said hard lines, This is better and easier.
The only other thing I did in the rear is remove those pressure reducing valves and install a $20 set of stainless lines (from FCP, it is the front brake line set) .
2006 V50 T5 AWD 16 PSI +
2turbotoys is online now   Reply With Quote
Old 11-20-2018, 11:34 PM   #9
Pro Sneaker Peddler
Thanks. I totally missed it on their site. Dammit Scott!
Old 11-20-2018, 11:58 PM   #10
2turbotoys
Salaminizer
2turbotoys's Avatar
Haha, no problem. I keep going over and over peoples sites in case I missed something useful, I missed it the first time around
Old 11-21-2018, 01:04 PM   #11
lummert
lummert's Avatar
I'ts possible to make a bubble flare using a double flare kit.
Old 11-21-2018, 02:09 PM   #12
What makes this better or easier? no reason for a flexible line at the caliper for solid axle apps.
www.BEIGEPOWER.com
Kaplhenke Racing Facebook
The only safe bet is Ben.©
Old 11-21-2018, 02:31 PM   #13
mikep
The MP
mikep's Avatar
Illegal in most if not all states, for good reason.
I not only find it to be child's play, I enjoy doing steel or copper/nickel lines well. There are female flare nuts. BTW.
I didn't look at all the particulars of your swap, I'm only here for the reported post.
That is correct. If you do it on the flat side instead of the flare side of the holding fixture it works very nicely.
One for those who want to get their hose on:
https://www.law.cornell.edu/cfr/text/49/571.106
(couldn't find the link to steel lines, got bored)
wouldn't MikeP need a girlfriend to qualify to be a cuck?
mikep is online now   Reply With Quote
Old 11-21-2018, 08:02 PM   #14
2turbotoys
Salaminizer
2turbotoys's Avatar
In my case, it was better because the brake line was about 40 years old. It was easier to bolt on new flexible lines than bend those old ones around.
I did buy a bubble flare tool and used to redo a couple cruddy front lines. It's pretty easy if you buy a good one, my second flare was perfect and the rest were also.
Old 11-21-2018, 09:14 PM   #15
John V, outside agitator
Banned
Wot da fuq?
Old 11-21-2018, 09:28 PM   #16
2turbotoys
Salaminizer
2turbotoys's Avatar
Idk, I must have missed something or someone is wasting our mods time.
Old 11-22-2018, 01:48 AM   #17
77volvo245
77volvo245's Avatar
True or have a new hardline made, the stock lines aren't long enough. Solid axles 740s have flex (soft) lines.
Old 11-22-2018, 11:39 AM   #18
DET17
Reformed SAABaholic
9 series as well.... all the 940s with live axles and the early 960s too. Perhaps the same rear binder kit will bolt up to the 1041 rear axle flanges as STS designed for the 1030/31 rears?
Old 11-22-2018, 12:51 PM   #19
RvolvoR
A 1041 is exactly the same aside from the locker carrier.
Old 11-22-2018, 01:05 PM   #20
Wot da fuq?
