Old 11-22-2018, 04:32 PM   #1
Crallen
Default Whiteblock Bellhousing Bolt Pattern - Lotus Esprit T5 Swap
Hey all,
New to here but nor to volvos! I'm currently putting a t5 engine in my 80's Lotus Esprit for awesome 80's turboness! I'm using an Audi transaxle gearbox so making an adaptor plate to fit between the two - I have the audi bellhousing bolt pattern but cant find one for the whiteblock anywhere
Does anyone have the dimensions of the bellhousing bolts or even better some CAD!!??
Cheers, Crallen
Crallen is offline   Reply With Quote
Old 11-22-2018, 04:43 PM   #2
John V, outside agitator
Originally Posted by Crallen View Post
Hey all,
Cheers, Crallen
Rotsa ruck...
Once question: what you doing with the turbo off the original motor..Got a piccie of it..
Where ya at?
You doing a Cortina in other worlds?
Sleezattle WA, USA
--> CALL (206) 431-9696<----
www.rallyrace.net/jvab
www.rallyanarchy.com
Vive le Prole-le-ralliat
— Don Marquis
Old 11-22-2018, 04:45 PM   #3
Crallen
Original motor isnt turbo- hence the T5 conversion.
Built a big spec cortina a few years ago, lotus is the replacement project!
Old 11-22-2018, 05:30 PM   #4
Buggah. Always looking for bits off the last couple of years Turbo Espirits turbocharger..
Mainly the turbine housing...
Well again rotsa ruck with finding anything detailed round here.
Old 11-23-2018, 01:02 AM   #5
Canuck
Frozen Garage Hell
Canuck's Avatar
I've got it at work. If I get a minute, I'll send it along.
- Craig
1966 Canadian (B5234T, C4 up front, Supra out back and a nut in the middle) http://forums.turbobricks.com/showthread.php?t=328003
1981 242 (B230FT, LH 2.4...and a few other things)
YouTube channel covering Canadian build https://www.youtube.com/channel/UCsx...n3CiBQFd4rMyXw
Old 11-23-2018, 03:47 PM   #6
Crallen
Awesome thanks, that would be such a help! have you made an adaptor from the data?
Old 11-25-2018, 12:10 AM   #7
Canuck
Frozen Garage Hell
Canuck's Avatar
Message sent
Old 11-25-2018, 12:24 AM   #8
89_740Turbo
89_740Turbo's Avatar
pics of the lotus? love them
1989 744Ti
1988 744Ti
1986 744GLE (RIP)
My Feedback Thread - http://forums.turbobricks.com/showthread.php?t=342247
Old 11-27-2018, 05:10 PM   #9
Crallen
Anyone else have any dims? I need the block to bellhousing bolt pattern if anyone has?
whats the best photo hosting site to put some pics in?
Old 11-27-2018, 05:28 PM   #10
Cool project wish you well with it.
Old 11-27-2018, 05:33 PM   #11
JohnMc
JohnMc's Avatar
I remember someone swapping an Audi engine into something Volvo-ish. When it got down to the first test drive, he discovered the Audi engine spun 'backward' - so he had one slow forward gear and a whole bunch of really fast reverse gears.
Something to double check before you get too far?
'63 PV Rat Rod
'93 245 16VT Classic #1141
Old 11-27-2018, 07:25 PM   #12
Canuck
Frozen Garage Hell
Canuck's Avatar
I just sent you this.
You can pull dims from the DXF.
Old 11-27-2018, 11:56 PM   #13
DET17
Reformed SAABaholic
Reminds me of that Burt Reynolds "Stuntman" movie..... they had a Chevy Stepside pickup doing aorund 80mph in reverse! RIP Burt...... "Smokey & the Bandit" pretty much saved the muscle car from it's grave in '77.
Old 11-28-2018, 02:37 AM   #14
Dan
Watching the World burn
Dan's Avatar
Gawd, can you imagine the thoughts going through his head when he figured that out...
Old 11-28-2018, 04:53 AM   #15
mocambique-amazone
I purchased a VW thing a long time ago because of the same fault.
The thing till 1973 are with reduction boxes. The gearbox is the same as from a beetle, the crown of differential is on the oposite side. they bought a gearbox of a beetle and voila: 4 times rewards and on forward.
And they didn't found the fault.
One evening and I did own a very good thing
would like to see the lotus too, Kay
