Old 11-26-2018, 12:49 PM   #1
LeedomtoFreedom
LeedomtoFreedom's Avatar
Default Where to buy larger valves
This is for a 530 head, trying to get larger valves for my machinist to put in.
Been blowing dust off old threads and found KLracing to be a good source, I was just curious what else is out there.
Also not sure what valve sizes I'll use, probably the maximum it'll fit without issues.
Also a lot of aftermarket valves are stainless steel, where the stock valves are sodium filled. Is this going to be an issue with b0ost?
81 264 - Driveway ornament
90 245 - becoming 16v
Old 11-26-2018, 01:17 PM   #2
stevE85
Formerly 1983_242
stevE85's Avatar
message gsellstr on here
1983 242: 11:1CR B23/M46/3:73's 121WHP DD'er
1982 244-Build Thread Here
stevE85 is offline   Reply With Quote
Old 11-26-2018, 01:18 PM   #3
planetman
planetman's Avatar
Or
http://forums.turbobricks.com/showthread.php?t=338237
Eric
Torrance, CA 90502
Old 11-26-2018, 01:21 PM   #4
Stiggy Pop
Stiggy Pop's Avatar
Ferrea will make valves to spec if you're looking to spend some money.
'79 242
943 pickup
Old 11-26-2018, 01:24 PM   #5
freevolvos
freevolvos's Avatar
Stainless.will.not be a.problem
Old 11-26-2018, 02:12 PM   #6
LeedomtoFreedom
Also do you machine the valve seats present in the head, or do you have to replace with larger seats depending on the size of the valve. I'm not 100% on the process of installing larger valves but is there enough meat on the stock seats to be machined for larger valves or is that not how it works.
Old 11-26-2018, 02:13 PM   #7
culberro
culberro's Avatar
46/38 is the largest valve you can fit on a stock valve seat insert.
Old 11-26-2018, 02:26 PM   #8
thelostartof
unbalanced chemical
thelostartof's Avatar
Best to get new seats installed to match and work with the valves. I just had a set of valves and springs from the GB installed on a head for my 740 and just got the head back from the machine shop last week. I would recommend you wait for the next GB and get in on that as the machinist commented on how well everything fit together.
Old 11-26-2018, 04:23 PM   #9
gsellstr
gsellstr's Avatar
Good intel Mike, heard the same from a handful of people, including my machinist that used some previously available stuff.
I can't vouch for the KL stuff, but I have had issues with stainless exhaust valves that were not made correctly by one of the bigger names in the past, which is why I started doing the group buys from REV. A QUALITY stainless is fine for intake and exhaust unless you plan to push it really hard, then you may need to step up to Inconel or sodium filled. Inconel isn't spendy like custom sodium filled will be.
The stainless from planetman would be a good start, or if you want to wait for the next GB, probably late spring next year (I do these based on demand so I can at least meet the minimum to get a better price), then you can jump in on there as well. Price for a set thru the latest GB was $352 delivered to your door for stainless 46mm intakes, Inconel 38mm exhaust.
As Mike mentioned as well, if you're going larger valves, do the job right and install larger seats. Shouldn't cost more than maybe $100 for parts and labor, but it allows you to get the most from the larger valves.
RIP
Nick Fengler "fengler" 8/6/18
74 144 B20
90 745Ti
Old 11-27-2018, 12:09 AM   #10
Tentshedtrev
Tentshedtrev's Avatar
Good info here!. I'll be sitting here wringing my hands until the spring lol
Life is too short to stay redblock..
1990 740 SE, Eaton m90 + Holset he351, twincharged b230F drift car
1983 242 turbo t5 whiteblock swap (in progress) (He351, MS3x, WC T5)
1983 244 (on blocks, currently parts storage)
1990 245 Mitsubishi 4D56 turbo diesel km132 transmission, water/meth
1983 245 m46 b230f Stahl header Toyota 4age ITBs MS2extra
Tentshedtrev is offline   Reply With Quote
Old 11-27-2018, 01:14 AM   #11
gsellstr
gsellstr's Avatar
If I can get 5 people with cash available before spring, I can get them coming sooner, but that doesn't happen too often anymore.
Old 11-27-2018, 08:13 AM   #12
thelostartof
unbalanced chemical
It better not, I need another set of valves and springs for my spare 531 but I do not have the $ to spend so wait please. Ha
Old 11-27-2018, 01:32 PM   #13
LeedomtoFreedom
I'm still deciding on my plans for this car. I'm talking to someone on the board about 16v which would defeat the need for larger valves. Thinking I might bite the bullet but not entirely sure.
I did talk to my machinist who said he could help with the valves, but one of my drag buddies said the 16v might be a better investment, or just put a new headgasket and slap it together again.
