Old 11-26-2018, 10:01 PM   #1
A tough rowing ho
Default She's dead Jim, 8.8 swap?
The 3.91 1030 put up a good fight, I'm thinking one of the carrier bearings let loose, I didn't feel like pulling the axles to find out. Especially since I've got a hankering to do the 8.8 swap and be done with it. It looks like they made an LSD 4.10 for the Exploder, I think this would fit my goals ok. Anyone solve the parking brake hookup?
2018-11-26_09-02-41 by John Skiba, on Flickr
Also my wheels are 5x4.5 like the exploder axle already has before I get any "use a toyoda axle" from the rally crew.
1980 Richelieu red JDM flares franken-242DL now with 8.8, 1989 silver 780 sienna rear spring nivomat delete.
Old 11-27-2018, 01:51 AM   #2
John V, outside agitator
Go Toyota 8"..Its better, the LSDs are better, no shortening one side tube which is a serious precision job.., just machining the flanges and a new bolt circle
Sleezattle WA, USA
--> CALL (206) 431-9696<----
www.rallyrace.net/jvab
www.rallyanarchy.com
Vive le Prole-le-ralliat
— Don Marquis
Old 11-27-2018, 01:55 AM   #3
Use a Toyota axle.
Old 11-27-2018, 04:50 AM   #4
cosbySweater
cosbySweater's Avatar
I did the 8.8 swap in a day. It's not bad to do, shortened the tube myself. All in all I have 120 bucks into the swap. Over 20k very hard miles on it with no issues at all. I guess it comes down to whatever is easiest for you to get
1990 Volvo 245, Efan conversion, tcam, Aw71 FOR SALE
1982 Ford Fairmont Futura. 3sge Beams, j160 6speed, full aje suspension and tubular arms everywhere
1995 Porsche 993
2013 VW Passat TDI
Old 11-27-2018, 07:17 AM   #5
A tough rowing ho
There's 1) 92 4runner, most likely with drum brakes and no pickups between the 2 yards here, there are 47) explorers, wonder which one I should go with?
Old 11-27-2018, 08:08 AM   #6
57plymouth
57plymouth's Avatar
John, can you give more insight into this swap? I have been considering the 8.8 swap for a while, but if there is a Toyota axle that fits better I would like to know more about it. What year and model fits into a 245?
Sven, the 1991 245
Old 11-27-2018, 09:04 AM   #7
Broke4speed
Broke4speed's Avatar
Well OBVIOUSLY you need to go with the Toyota axle, because it's far better than anything you can get 100 different aftermarket variations for from Jegs or Summit. The best part is that if you break it, you get to spend weeks scouring junkyards for beat up old Toyotas!
/s
When I build something, I try to get away from using parts that are essentially one-offs now that they're getting old and hard to find. Replaceability has to be key, IMO. ESPECIALLY when you can get any axle you want, off the shelf, with free shipping, for pennies.
1984 B6304S/AW30-40 w/Poi-Shift.
Old 11-27-2018, 09:15 AM   #8
240wagonguy
Welding the axle back together is not a "serious precision" job, just clamp it together with some angle iron and put the axle shaft in. Stock cars run 3* camber on solid axles, so if you keep your straight axle under 200 MPH you'll be fine.
Old 11-27-2018, 01:13 PM   #9
cosbySweater
8.8. set it and forget it
Old 11-27-2018, 01:19 PM   #10
JohnMc
JohnMc's Avatar
I'm mildly intrigued by the hooning potential of an e-locker Toyota axle in a high-HP Volvo.
But really, you could stick a selectable locker in an 8.8 as well. And a locker probably isn't what you want in a street vehicle anyhow.
It's... just sort of fun in my 4Runner on slick wet streets in 2HI.
'63 PV Rat Rod
'93 245 16VT Classic #1141
Old 11-27-2018, 01:27 PM   #11
A tough rowing ho
Sounds to me that you're ignoring the warning sticker for the e-locker.
Old 11-27-2018, 01:30 PM   #12
JohnMc
JohnMc's Avatar
I had to do a 5-minute 'mod' to allow it to be used outside of 4LO. Remove driver's side footwell kick panel, find a wire, clip it, ground it. Voila, locker available in all 3 xfer case modes. Slideways action in big tall SUV ability: unlocked.
Old 11-27-2018, 09:10 PM   #13
freevolvos
freevolvos's Avatar
12 bolt chevy!! Dana 60!! I also have a full floating 14 bolt you put it in there I will give it to you!! Be the first on your block with a 8 lug volvo
Old 11-27-2018, 09:47 PM   #14
300+hp on the shelf club
You could also go full bolt in with a 1031 that has one of those new fangled lsd in it. A 1031 is a bit stronger and may last a bit longer. Unless you are planning a lot of abusive stuff the 1031 seems to hold up to V8 power ok.
Old 11-27-2018, 10:25 PM   #15
Vincent Gagnon
Vincent Gagnon's Avatar
I did the toiletta swap.
It's fairly simple.
The good limited slip and a 4.56 final drive really changed the way the car behave.
1: Get a Toyota supra (1986.5 - 1992) limited slip.
2: Get any toyota 8 inch solid axle (Toyata Pickup, 4runner etc.)
You can know that it's an 8inch by looking at the third member.
You want the V6/Turbo:
3: Go to a machine shop with the axles, the brake discs you want to use and the wheels you want to use (I had stock Volvo 240 ****).
4: Tell him to turn the axles, drill new holes and make something that looks like this:
5: I used the stock Volvo calipers, a really smart kid named Eric Ewert made these and I'm pretty sure you can get them for dirt cheap (he just send me the cad and I had them made locally:
6: Get a solid pinion spacer and shim kit from Weir Performance.
7: Follow these steps to put the supra diff in the third member:
http://www.gearinstalls.com/supralsd.htm
8: Since my junk is just a street car, I simply cut the brakets from the Volvo axle and weld them on the Toiletta:
...and that's about it.
Old 11-27-2018, 10:35 PM   #16
cosbySweater
I love the fact those are dropouts. I have a Toyota axle and Supra diff laying in storage, never got around to using it. May use it one day on another project
Old 11-27-2018, 10:45 PM   #17
Vincent Gagnon
What I like the most about this is that if you take your time, you can get those parts for dirt cheap, you end up with a pretty solid good 4 pinions diff and you can get all those ratios for very little money:
https://www.rockauto.com/en/catalog/...d+pinion,10438
Old 11-27-2018, 11:51 PM   #18
2turbotoys
Salaminizer
2turbotoys's Avatar
What I like is how he said "Also my wheels are 5x4.5 like the exploder axle already has before I get any "use a toyoda axle" from the rally crew." and gets almost nothing in this thread except what he didn't want lol. Good toyota info though for those wanting that rear.
I was gonna do the 8.8 route, its a good one and I was sold on it, then I found a 9" with 240 brackets already installed for really cheap, so I got that. I don't know about the parking brake thing though, I'm using a manual trans..
2006 V50 T5 AWD 16 PSI +
Old 11-28-2018, 06:44 AM   #19
A tough rowing ho
From what I've been able to find the explorer parking brake cables go out to a bar that probably gets pulled by one single cable from the pedal mechanism. I was thinking of interfacing the Volvo cables at that point by drilling a couple holes in the bar, shortening the cables and using some of those u shaped cable clamps. I'll have to see what it looks like once I pull the 8.8. Thanks Vinny for the comprehensive write up but all that finagling and machining seems a lot more difficult that than welding up an axle tube. All for an axle 4 Wheeling magazine rates lower in strength than an 8.8. Jegs etc have C clip eliminator kits that take care of the 8.8 main weakness. I was sold on its strength watching the 901hp Dyno on other thread, I'll never make that kind of hp/tq with a redblock.
Old 11-28-2018, 09:18 AM   #20
240wagonguy
Friend of mine makes the brackets for an 8.8 swap in both 240 and 740/940 chassis. Easier than scabbing them off the old axle.
Old 11-28-2018, 09:38 AM   #21
Broke4speed
A buddy had an 8.8 in his 69 valiant/2JZ drag car. Ran high 8's, lifted the front wheels 12" on launch. Never broke a thing. The Toyota axle myth needs to die.
Old 11-28-2018, 10:52 AM   #22
cosbySweater
You don't really need c clip eliminators on a explorer 8.8 they have disk brakes and the caliper bracket captures the rotor
Old 11-28-2018, 11:39 AM   #23
A $100 junkyard 1031 in the 373:1 flavor?
Old 11-28-2018, 11:46 AM   #24
Vincent Gagnon
What myth?
This is a perfectly reasonable option because:
Old 11-28-2018, 11:48 AM   #25
Stiggy Pop
Stiggy Pop's Avatar
no way, all 240hp cars need giant truck axles.
'79 242
943 pickup
