Old 11-28-2018, 11:53 AM   #26
Originally Posted by Stiggy Pop View Post
no way, all 240hp cars need giant truck axles.
Slap that boat anchor 9" in there and watch your ET's soar.
After getting back from your chiropractor's office from messing with that thing.
Old 11-28-2018, 11:57 AM   #27
Vincent Gagnon
Vincent Gagnon's Avatar
32mm is no giant axle.
Member of TBCCS
Old 11-28-2018, 12:01 PM   #28
Stiggy Pop
Stiggy Pop's Avatar
sure, the 200lb stick out back will be a good offset to the 70/30 weight distribution with a turbo cast iron v8! 2019: the year of the 4000lb 242.
'79 242
943 pickup
Old 11-28-2018, 12:02 PM   #29
Vincent Gagnon
Old 11-28-2018, 12:02 PM   #30
Gotta be there the day they set them in the junkyard though, because the Mexican guys pull the axles and grab those pumpkins right away.
Old 11-28-2018, 12:10 PM   #31
JohnMc
JohnMc's Avatar
I should get a shop hoist scale and see what the real difference is between the alu 5.3/CD009 and the redblock turbo/T5 combo.
Just roughly eyeballing the front suspension ride height, the V8 isn't heavier. Not all the parts are in it yet, though.
'63 PV Rat Rod
'93 245 16VT Classic #1141
Old 11-28-2018, 12:14 PM   #32
Vincent Gagnon
I know man!
There is some guys around here that are always right on them.
I remember two winters ago, some V6 4runner arrived at the PnP in the middle of the winter right after 30cm of snow.
The place opens at 9am and I was there around 9:30/45.
Well the bastard came before me, dug in the snow and removed the pumkin.
Fawk!
I have two complete assemblys now (one on the car and one spare).
...and of course, since I don't need any now, there is a million Toyta whatevers showing up in junkyards.
Old 11-28-2018, 12:17 PM   #33
^ Kudos!
You're a braver / more determined man than I am, a little rain chases me out of the junkyards.
Old 11-28-2018, 12:26 PM   #34
Stiggy Pop
Stiggy Pop's Avatar
^ Kudos!
if you can keep your fingers and toes from freezing I'll work in the snow over the rain any day.
Old 11-28-2018, 12:32 PM   #35
Vincent Gagnon
^ Kudos!
To be honest, it's not really a matter of choice.
This, all the way, I think I even prefer the winter to really warm summer days when you just end up covered with grease and sweat.
Old 11-28-2018, 12:49 PM   #36
linuxman51
BRANDSCHUTZVORSCHRIFTEN!
linuxman51's Avatar
Originally Posted by 240wagonguy View Post
Friend of mine makes the brackets for an 8.8 swap in both 240 and 740/940 chassis. Easier than scabbing them off the old axle.
post link dawg
Megasquirt Tuning!
Old 11-28-2018, 12:52 PM   #37
240wagonguy
Ah yes I forgot.
https://www.facebook.com/Giffins-Per...4053585318393/
Pinned post at top.
I'll have to mention to him again about posting a for sale thread here. I think fb is just easier tho.
Old 11-28-2018, 02:04 PM   #38
Here's looking at you kid
A $100 junkyard 1031 in the 373:1 flavor?
Not any junkyards round here, I haven't seen a 240 in 8 months. I also want at least the 3.91, 4.10 would be better for the diameter tires I'm using.
Edit: I've also broken a 1031 as well, need to be moving ahead not running in place.
"i will destroy all of you!"
-Sheldon Plankton
Booty Scooty
https://youtu.be/i4oAOZ8nbq4
Old 11-28-2018, 08:45 PM   #39
freevolvos
freevolvos's Avatar
Marmon herrington, rockwell or go big and go Mack
Old 11-28-2018, 09:15 PM   #40
2turbotoys
Have you seen me?
2turbotoys's Avatar
A Ford 9" isn't really that heavy, I got mine out of the truck myself (dam heavy for 1 guy) the axles weren't in it but the 3rd member was... how much do these other rears weigh?
1978 242, 5.3 L33
1979 242, MS, R brakes
2006 V50 T5 AWD @ 17 PSI
Old 11-28-2018, 09:25 PM   #41
Very close to 200# for the 9" @ 46# less for the 8.8 depending on rear brake type.
Old 11-28-2018, 10:10 PM   #42
2turbotoys
Have you seen me?
2turbotoys's Avatar
Ah. I didn't have brakes on it either, the Grenada brakes that were on it hit the scrap pile at the sellers house
Old 11-29-2018, 08:56 PM   #43
white855T
^ Kudos!
If I'm already stripping a 240 and starts to pour down, I just keep going. At least there isn't anyone to bother me when it's raining. I'm always ready with a rain coat/pants. When it gets cold I put on some thermals and I'm good to go.
Old 11-30-2018, 03:39 AM   #44
cosbySweater
cosbySweater's Avatar
If anyone of you want a 8.8 in your volvo. Let me know I have a jig for welding the mounts. I can source axles no problem. It isn't going to be dirt cheap. But I have the tooling and time for the next month to do it. Pm for deets
1995 Porsche 993
2013 VW Passat TDI
Old 12-03-2018, 10:57 AM   #45
Search of 1 yard that's open on Sundays only turned up 3.73lsd 8.8, there was a Toyota pickup with their 7.5" diff, there was also a 4runner with I think a 4.56 4 shaft that I looked real hard at until I went back and read Vinny's write up again. I'm going to try the other yard possibly today but I may be stuck with the 3.73.
Old 12-03-2018, 01:29 PM   #46
culberro
culberro's Avatar
http://car-part.com/
Let the internet do the searching for you....
Old 12-03-2018, 01:45 PM   #47
Nothing but rich man options, but there are some around as a last resort.
Old 12-03-2018, 09:24 PM   #48
Other pick and pull had what I wanted, swapped the extra short axle in the housing out the door for $177 including tax and $10 core charge that I'll get back if I bring old brokey in. D2 4.10 trac-lock. I gave up on the yoke, I'll either order one in or go back for it, I did get an extra rh brake hose. 165k on the axle, should I replace the guts of the lsd? That thing is ridiculously heavy in a wheelbarrow with 65lbs. of tools, the tire was rubbing on the wheelbarrow body.
Old 12-04-2018, 08:41 PM   #49
mikep
The MP
mikep's Avatar
That’s an 8”, not a 9”.
Let me guess, you could use a socket on all the nuts, right?
On a 9” you can’t get a socket on one bottom nut.
Old 12-04-2018, 09:00 PM   #50
2turbotoys
Have you seen me?
2turbotoys's Avatar
Nope, its a 9", and you cant use a socket on two of the bottom nuts on the 3rd member.
