Old 11-27-2018, 08:36 PM   #1
maxitoman007
maxitoman007's Avatar
Default Oil on outside of Ebay intercooler but no crack??
1987 740 turbo. I just recently noticed that the area around the inlet of my Ebay intercooler has become pretty dirty on the outside with what I believe is oil. The oil has also gotten on the rad sitting behind the intercooler even where it is above the intercooler (see pics and you'll get what I mean). I did a boost leak test and the intercooler held 20psi easily with no signs of leaking in the oily area (checked with soapy water). There is grime on the front and back of the intercooler in this area, however there is no oil on the end tank of the intercooler on that side. The grime begins at the fins of the intercooler (see pic). There is no grime on the backside of the rad. Any ideas? could it be coolant mixed with dirt I'm seeing that's seeping from the rad somewhere??
the shiny spots within the grime on the intercooler are where the soapy water from my spray bottle hit the area before the boost leak test.
maxitoman007 is offline   Reply With Quote
Old 11-28-2018, 10:10 AM   #2
freevolvos
freevolvos's Avatar
Looks like normal road grime if nothing is leaking I wouldn't worry, it (the grime) could even be something left on it from manufacturing or a shipping preservative like a oil or welding flux clean it and see if it returns
Old 11-28-2018, 10:35 AM   #3
Uncleknucklez
bruspeed
Uncleknucklez's Avatar
I think the hose clamp on that side should be checked, as well as the hot side connection. Looks like oil from the turbo being blown across the front of the IC to me.
1980 242 Turbo
2004 V70R
Old 11-28-2018, 11:52 AM   #4
LeedomtoFreedom
LeedomtoFreedom's Avatar
Is that license plate regulation size
81 264 - Sold
90 245 - coming BACK baby
Old 11-28-2018, 01:32 PM   #5
maxitoman007
That’s promising, don’t understand how it would have gotten on the left side only of the rad though. And not on it’s back side.
That was my first thought also. However I totally isolated the intercooler and it’s commections for a boost leak test and it all held pressure fine. Also if what you suggest is occurring I’d expect to see the grime on the end tank on that side however this is not the case.
Haha. Definitely not. Every brick needs character right?
Old 11-28-2018, 01:56 PM   #6
maxitoman007
Just occurred to me that maybe I sprayed something in that area that road grime clung to. Possibly during a boost leak test hence the location? Just an idea. Don’t know what I could have sprayed though. Also still doesn’t explain why it’s not on the end tank unless it was “smooth” enough for it to run off or something.
Old 11-28-2018, 07:40 PM   #7
GTJordan
Been here for too long
GTJordan's Avatar
Pressurize the system. Spray soapy water. Look for bubbles.
You're welcome
Old 11-28-2018, 08:34 PM   #8
You have a boost leak there, double up the hose clamps.
And thank GTJordan later.
Old 11-29-2018, 01:50 AM   #9
maxitoman007
You're welcome
I did just that and it held pressure up to 20 psi with no bubbles visible in that area from my extensive soapy water spraying...
Old 11-29-2018, 04:16 AM   #10
swedefiend
swedefiend's Avatar
Because the radiator has a similar pattern behind the intercooler, I'm pretty sure that you have a leak.
Old 11-29-2018, 11:15 AM   #11
PeaceEngineered
Sarcastic Optimist
PeaceEngineered's Avatar
Are you testing hot or cold? While I would not think it would get too hot, aluminum does have a way of hiding small issues when cold. Just a thought. That is all I have.
2013 Audi Q5
Sold- 2006 V70R
PeaceEngineered is offline   Reply With Quote
Old 11-29-2018, 05:12 PM   #12
maxitoman007
Could you elaborate on the kind of leak you are suggesting? A boost leak? Coolant leak? etc.
I was testing cold. Never thought of this, maybe boost leak testing at en even higher pressure could compensate for temperature fluctuations?
Old 11-29-2018, 06:00 PM   #13
swedefiend
swedefiend's Avatar
Looks like oil being sprayed in a similar pattern on both intercooler and radiator
Old 11-29-2018, 06:03 PM   #14
bobxyz
bobxyz's Avatar
As an alternate thought, do you have a clear path to your air filter, or does it draw mostly through the dirty corner of the intercooler? Does the grime wrap around the gaps between body and IC? What's the hood above look like?
Old 11-29-2018, 06:07 PM   #15
maxitoman007
That is a good thought although my intake sits low in the front passenger side and takes air in through a flap cut open in the bottom sheet metal in that area. No grime on the hood in that area.
Old 11-29-2018, 06:58 PM   #16
bobxyz
bobxyz's Avatar
If it's reassembled and running, wrap a clean white cloth around the intercooler inlet pipe covering the rubber inlet hose and go for a drive. From the grime pattern, it looks like it's roughly in a circle spraying from the end of the hose.
Old 11-29-2018, 07:20 PM   #17
The oily rag mod?
Where have I heard that before?
Old 11-30-2018, 01:05 AM   #18
maxitoman007
Ohhh that's clever. I'll give that a shot once its driving again. As for now I have a jankey wire tuck and some short circuits to fix...
Old 11-30-2018, 03:35 AM   #19
cosbySweater
cosbySweater's Avatar
It's fine. Ship it
1995 Porsche 993
2013 VW Passat TDI
Old 11-30-2018, 12:21 PM   #20
maxitoman007
Originally Posted by cosbySweater View Post
It's fine. Ship it
Ship it?
Old 11-30-2018, 08:00 PM   #21
swedefiend
swedefiend's Avatar
Originally Posted by maxitoman007 View Post
Ship it?
It's a figure of speech. Rock that ish until it starts leaking for real. Then worry about it.
Old 11-30-2018, 08:07 PM   #22
Tfrasca
Tfrasca's Avatar
Did you run that IC over before you installed it?
Old 12-01-2018, 02:34 AM   #23
maxitoman007
If you mean literally...definitely not. If you mean something else... I'm not sure what you mean haha.
Ah, here in Canada we say "send it". Guess its the same message.
