Old 11-30-2018, 10:24 AM   #1
Moomaneast
Default 740 Gl b230 engine swap advice
Hey guys I'm new here and I'm winding if you can help
I've got a 1990 740 gl with the 2l na engine, I've also bought a1995 940 2.3 turbo
I want to put the b230 in the 740 along with the m90 gearbox from it.
Just some advise would be helpful, I read something about using the flywheel from the m47 in the m90 and using the transmission mount from the 940, do I also need to use the prop Shaft?
The engine I'm hoping will bolt in, I know Ill need the 940 ecu.
Is there anything else I should know about or is it pretty mush as simple as that, I've never done an engine swap before so I'm reliying on you guys to help. I'm going to be completely documenting it so others can see after how to do it.
Thanks guys, Tom
Moomaneast is offline   Reply With Quote
Old 11-30-2018, 10:30 AM   #2
white855T
Does you car have bosch fuel injection or regina fuel injection? If it doesn't have bosch fuel injection, computers won't swap over.
Buyer/Seller Feedback
Old 11-30-2018, 10:35 AM   #3
Moomaneast
How to I find out, does it matter If I'm using the whole ecu from the 940?
Old 11-30-2018, 10:49 AM   #4
Moomaneast
Just checked its the b200f so it is bosch
B200F: 2.0 L inline-4, naturally aspirated, Bosch LH-Jetronic 111 hp (83 kW)
Old 11-30-2018, 01:56 PM   #5
mocambique-amazone
Where are you located?
Does the 740 have ABS?
Does the 940 have a thicker key? (Immobiliser)
You will need:
Both computers, the EZK (ICU) and the ECU
Intercooler
All pipes for Intercooler
Battery tray
Wash water canister
Part of wiring loom(to extand the MAF plug)I would swap the full engine loom. Very easy if you know how to do.
Exhaust full
Crossmember gearbox
Drive shaft complete
Airbox
With ABS more complicated
Have a search to member Brotkasten here. He has done similar (F + t)
Good luck, will be a good car. Kay
Old 12-01-2018, 11:42 AM   #6
white855T
If it's bosch, computers will swap over. Just swap the engine and trans and you should be good. Use the prop shafts from donor car. Everything is bolt in.
Old 12-03-2018, 07:53 AM   #7
Brotkasten
Jonas
Brotkasten's Avatar
Well I've done the +T, he wants to go the engine swap way (probably easier lol)
Wo kommst du denn her mocambique-amazone? Dein Fahrzeug klingt sehr interessant...
Why would you want to change the flywheel? I thought you've got a matching B230FT and M90 gearbox? They will work the same way in the 940 as they did in the 740.
First step would be too identify if the 740 is LH2.2 or LH2.4. If it's LH2.4 you can leave the harness in place and just extend the MAF wiring (For LH2.2 I'm not sure! Use the search function). You also need ballast resistors for the original turbo injectors. I personally used injectors with Part #.: 0280155831 @ 329.8 cc per min they get really close to the original turbo ones and don't need a resistor pack.
91' 940 B230FB+T M90
Old 12-06-2018, 08:06 AM   #8
Acke
The dual-mass flywheel can get tired, and starts bottoming out under load. Especially with higher boost than stock. It also restricts the available clutch/pressure plate options compared to a solid flywheel. The SRE -712 (dual mass) is usually more expensive and harder to find than e.g. SRE -763 (solid 228mm).
Old 12-06-2018, 01:47 PM   #9
classicswede
Volvo upgrades
The dual mass wants to go in the bin
You can use the dished M47 flywheel along with a sachs clutch for the late D24 with M90 or
Use a TTV flywheel combined with a 850R clutch and is a better option if you have the budget for it
The gearbox support beam and prop will swap over
ECU's will plug in.
