![]() I bought wiseco piston 96.5 mm and i have conrod from maxpeedingrods but with The stand piston there is no clearace and with The wiseco piston The is 1 cm ?
![]() Do i have The wrong rods?
![]() Assuming the rods are the same width, you’ll need some aluminum or brass/bronze spacers made to take up the space. Pretty common issue with piston steered rods and aftermarket pistons if the rod width ain’t specified when ordering.
#4 |
Dann sind wir Helden
![]() How does the other end fit on the crankshaft?
"i will destroy all of you!" -Sheldon Plankton Booty Scooty https://youtu.be/i4oAOZ8nbq4 |
#5 |
#6 |
The MP
![]() What is the side clearance between the big end of the rod and the crank? Use a feeler gauge.
#7 |
#8 |
![]() Join Date: Oct 2004
![]() Looks like the Wiseco's are designed for crank steered rods, OE are piston steered. Check the fit of the new rods on the crank, should have around .010" or so side clearance.
RIP Doug Williams "Mr. Doug" 4/15/2009 Pete Fluitman "fivehundred" 7/14/2013 Mick Starkey "TrickMick" 1/10/14 Mark Baldwin "blue850t5" 7/19/18 Nick Fengler "fengler" 8/6/18 Thomas Fritz "stealthfti" 10/11/18 74 144 B20 http://forums.turbobricks.com/showthread.php?t=224983 90 745Ti http://forums.turbobricks.com/showthread.php?t=334698 If you need Superpro bushings PM me for price and availability! |
#9 |
![]() Quick question: is the pin height the same on both pistons (distance from the center of pin hole to the top of the piston?)
The pistons will work as is, you just need some spacers made for the small end of the rod. Or get some stock length rods that are crank steered. |
#10 |
![]() What is the width of the connecting rod BIG END...25mm or 29,75?
John Vanlandingham/JVAB Imports Sleezattle WA, USA --> CALL (206) 431-9696<---- www.rallyrace.net/jvab www.rallyanarchy.com Vive le Prole-le-ralliat "When a man tells you that he got rich through hard work, ask him: 'Whose?'" — Don Marquis |
#11 |
#12 |
#13 |
#14 |
![]() I’d contact MaXpeeding as I’ve got their rods fitted to my Wiseco 16v pistons and they fit fine.
