Old 01-09-2017, 08:03 PM   #26
Simi
Upsetti Spaghetti
Simi's Avatar
I'll take it out and report back
Simi is offline   Reply With Quote
Old 01-09-2017, 11:28 PM   #27
Harry Tuttle
It is hard for me to imagine how the symptoms you describe could be caused by the countergear/shaft. It is one chunk of steel and runs on one shaft. But things can break, and you are the guy who is looking at it, so I will breathlessly await your report.
I didn't see where you reported whether you found metal on the drain plug- did I miss that? It could tell you a lot.
Originally Posted by sbabbs
who cares, push start it if you have a man tranny.
Old 01-09-2017, 11:34 PM   #28
Simi
Upsetti Spaghetti
Simi's Avatar
Very small amount of fine shavings, no chunks.
Old 07-17-2017, 07:42 PM   #29
sbabbs
sbabbs's Avatar
Any updates on this?
1990 745 B230FT Getrag JohnV flywheel 240mm clutch 13c A-cam 3.54 G80 544K MILES
Old 07-17-2017, 08:09 PM   #30
James10952001
I broke an M46 once. I shifted into 2nd and there was a really nasty sounding thud and crunch, then it seemed to drive ok but it would grind going into 1st if the car was moving at all. Ended up driving it for a couple more years like that figuring it was already broken. Eventually did an autopsy and it turned out a snap ring that holds one of the gears had come apart and got ground up in the gears. The 1st gear synchro then acted as a thrust bearing and eventually fused to the gear. At least the gearboxes are still relatively easy to find, it's the overdrives that are rare and parts are unobtanium.
James10952001 is offline   Reply With Quote
