Old 09-21-2015, 02:45 PM   #226
Old Iron
I Roll
Old Iron's Avatar
Originally Posted by harribert View Post
Five years on and still no turbo? THIS THREAD TITLE IS MISLEADING.
Ohh shoot, you caught me!! Progress is a slow thing! Working my way to it!
Originally Posted by smokeyfan1000 View Post
Is that a OE Volvo bolt or the bolt that came with the aftermarket(?) WP?
You did use a 1/4" drive rachet...right? (not a 3/8 drive rachet)
Yes is was a Volvo bolt that came with the Volvo OE water pump kit!
Turbobricked
Old 09-21-2015, 03:30 PM   #227
smokeyfan1000
Guest
Did you use a 1/4" drive rachet? It looks like you used a 3/8 " drive rachet and far overtightened the bolt to me.
Old 09-21-2015, 03:35 PM   #228
smokeyfan1000
Guest
Yes is was a Volvo bolt that came with the Volvo OE water pump kit![/QUOTE]
Always use a 1/4" drive on those small bolts like the cam cover ,WP are.
Old 09-21-2015, 08:35 PM   #229
Old Iron
I Roll
Old Iron's Avatar
Pretty sure I used the 1/4". Thankfully nothing is leaking, if it was going to, it would have happened already!
I will determine wether I want to pull the pump off again and put a new bolt in the coming months. Next up is ball joints! I have a pair of NIB Meyle, but I am starting to wonder if why I bought them 2 yrs ago without doing any research on them. Is Meyle as good or better then OE, or am I better off not messing with them and finding better replacements?
IPD list them as OE?
Old 11-19-2015, 08:33 PM   #230
Old Iron
I Roll
Old Iron's Avatar
Ok, so this car has always had a functioning over drive system and has never had an issue with the shifter getting locked up. It's an automatic, and the shifter components are all still unbroken, unlike all the other car that have the black plastic broken in half which allows them to shift without using the shift overlock button or have the car in to shift the car. While all the components are still functioning the last two times I have driven the car in them last few weeks the car is not shifting into park unless I force it? Is this a common issue you guys have seen, whats the cause if everything looks intact under the shifter cover?
Old 11-19-2015, 08:52 PM   #231
nel621
worn shifter bushings?
Old 11-19-2015, 09:00 PM   #232
nel621
Have you hacked up your dash yet and installed the digital display radio?// is it?
Old 11-19-2015, 09:19 PM   #233
Old Iron
I Roll
Old Iron's Avatar
Now that you mention it when the car had gotten rear ended the engine mounts broke and caused the same issue, I simply put in new Volvo replacements and that issue was solved, maybe it finally gave.
No, definitely not! I won't be hacking up my minty crack free dash anytime soon, though the amp on the radio has failed for a second time and the radio is no longer functional, so after market radio sounds nice!
Old 11-19-2015, 11:06 PM   #234
nel621
Look under the car and make sure everything is in place, no bushings wanting to walk out. Put the front on jack stands and have your lovely assistant move the selector while you observe what is happening.
Old 11-19-2015, 11:09 PM   #235
Old Iron
I Roll
Old Iron's Avatar
That sounds like a good starting point! Will absolutely start with that this weekend!
Old 10-08-2017, 03:10 PM   #236
Old Iron
I Roll
Old Iron's Avatar
This darn photobucket garabage really destroyed this thread!
Old 10-08-2017, 03:13 PM   #237
BillyMaysHere
BillyMaysHere's Avatar
There's a plugin for that
I am actually the gentlest and kindest of souls, you know that...I wish peace and happiness to everybody
Was a sandals-and-socks elbow-patch-cardigan-wearing bearded college-professor 10mph-under-the-limit-in-the-fast-lane typical Volvo buyer from 1993 really caring about some sort of limited edition numbering?
BillyMaysHere is offline   Reply With Quote
Old 10-08-2017, 04:20 PM   #238
Cwazywazy
Cwazywazy's Avatar
https://chrome.google.com/webstore/d...bifiaedg?hl=en
Need Chrome, but there's probably plugins for other browsers.
I don't know what I have
Old 09-29-2018, 06:51 PM   #239
Old Iron
I Roll
Old Iron's Avatar
I don't know how, but my Photo bucket photos have magically started working again for the first ten pages of this thread???
It has been a really long time since I really did anything of substance on this forum or in this thread. Old Iron is still as much a part of my life as ever. This car has been with me at every moment in my adult life, including my recent divorce and custody proceedings over the last two years.
I have used this car for normal driving a lot in the last year, in June it was side swiped by an inexperienced driver and awaiting repair. Which brings me to my next saga in this story. This fender bender has initiated a major refurbishment for the car, including a strip down for rust repair and paint. I want it done right.
It has been a journey finding a shop willing to do the complete job. Some shops don't want to work on the car at all, others want to paint the car without doing rust repair and others will paint but don't want to paint jambs, etc. it has been a true headache.
My daughter already loves this car and enjoys trips with me. This struggle is real, finding a good shop, but I am in it for the long haul.
Old 09-29-2018, 06:53 PM   #240
Old Iron
I Roll
Old Iron's Avatar
Default saga.... cont.
The paint on the passenger side has that degenerative degradation which has gotten worse over the 11 years I have owned the car no matter how much I waxed... cared for it!
Old 09-29-2018, 06:54 PM   #241
Old Iron
I Roll
Old Iron's Avatar
Default See hazy paint
I also bent the hood on the way to the second body shop.
File Type: jpg Woops - Have two extra hoods thankfully.jpg (195.8 KB, 5 views)
Old 09-29-2018, 07:00 PM   #242
Old Iron
I Roll
Old Iron's Avatar
This is its current state.
Old 10-02-2018, 09:14 PM   #243
Old Iron
I Roll
Old Iron's Avatar
I guess I need to figure out how to rotate photos in the turbobrick upload window.
Old 10-06-2018, 02:02 PM   #244
nel621
How the heck you manage to bend the hood?
Old 10-07-2018, 04:28 PM   #245
Old Iron
I Roll
Old Iron's Avatar
It flew open. The shop said they could repair it, I have couple hoods just Incase it’s better to start with a straighter, different color hood, rather then a bent up one!
