Old 04-25-2016, 09:46 PM   #1
bionicbanana
Default Rear Spring Advice
Looking for new rear springs for my 780 that has already had anti-nivomat conversion done.
I went to swap in new billy HDs today and the PO from years ago had made his own wooden spring seats (1/2" to 1" thick) on the bottom that obviously had been broken apart for god knows how long. Now the blue IPD rear springs will sit even lower, when my rear was already sagging badly before. They have lots of wiggle room with the trailing arm back in place and I'm almost certain they're un-cut. The original spring seats were still in there, and even doubled up on the driver's side...
I would love real stiff springs in the rear, and something just under stock height to fit eiker e1's comfortably, but I'm lost on what to get. I read somewhere about 240 overload springs for the rear may work with the pigtails cut, but would like some more opinions on it
Thanks
bionicbanana is offline   Reply With Quote
Old 04-25-2016, 10:00 PM   #2
lummert
lummert's Avatar
How about some rubber coil spring seat spacers?
Google: "rubber coil spring seat spacers" for some images.
Old 04-25-2016, 10:16 PM   #3
bionicbanana
Possibly, though I feel the springs are part of the sagging problem at this point being near ~10 years old and taken a bit of abuse. Even with the wooden seats that were in there, I'd want to increase the rear height by well over an inch to ride with the Eikers comfortably without rolling and destroying the rear fenders.
Old 04-26-2016, 12:20 PM   #4
bionicbanana
Well I'm thinking about getting some 5"x13" 325# and just trying those. The IPD's in there are 5"x10.5" but I'm not sure what the rate is
Old 04-26-2016, 08:59 PM   #5
mikep
The MP
mikep's Avatar
13" 225# will be plenty.
wouldn't MikeP need a girlfriend to qualify to be a cuck?
Old 04-26-2016, 09:32 PM   #6
Marvelous3
Who engineered this?
Marvelous3's Avatar
325 is way way too stiff. Especially on stock Billy's.
I have 200's in my sedan and they are plenty.
IPD's, depending on which version as apparently there are a few, were 115-125.
13" springs
http://www.summitracing.com/parts/ei...0200/overview/
11" springs if you want to go lower
Get some adjustable rear mounts and you have adjust the height easy peasy
http://www.kaplhenke.com/collections...ng-perch-mount
Old 04-26-2016, 09:42 PM   #7
John V, outside agitator
Banned
Probably even 200 in/lbs and for adjustment one could try
http://www.jegs.com/i/Allstar+Perfor...ty8aAqf28P8HAQ
JEGS Part Number: 049-ALL56119
Hidden Adjustable Spring Spacer
$41.99
Order Today Ships in 24hrs
Jus saying
Old 04-26-2016, 11:04 PM   #8
VQ
Not such a PRVert Anymore
VQ's Avatar
I've been running 5x11 275# springs in my 760 for years, they are 2" lower than stock. Ride is firm but not horrific, with Bilsteins hds fitted too.
hellastock
Speed Bumps? No Problem.
264 GLE RIP
88 740T wagon
1964 122s
88 760GLE
Old 04-30-2016, 02:49 PM   #9
bionicbanana
Went with 5x11 300#. They feel great with the new Bilsteins. Just as stiff as I wanted the rear.
Now to figure out why the front of my trailing arms are still creaking so much
