Old 10-16-2017, 10:52 AM   #1
districtmotors
districtmotors's Avatar
Default 1990 Volvo 245 Wet Driver Side Mat
Hi, I have a 1990 Volvo 245 and something odd has been happening after rain. I open up my driver side door and the thermoplastic floor mat is wet. (This morning in particular there was a 1/2 inch of water as it rained all weekend.)
I thought I remedied this when I had a new windshield installed a few weeks back but it doesn't appear to be the case. I double checked the windshield and it looks solid. It's also worth noting that in the past it felt wet right around where the hood release latch was but that was not the case today.
Any thoughts from the board?
M.J.
PAYMENT
If purchasing, my PayPal is mjlaperch@gmail.com. Please send as "Goods/Services" so I can print the label directly from PayPal. I typically ship USPS Priority Mail and include that in the fee. If the item is bigger it ships USPS Retail Ground.
MY FEEDBACK:
http://forums.turbobricks.com/showth...90#post5641690
districtmotors is offline   Reply With Quote
Old 10-16-2017, 11:02 AM   #2
esmth
dirty swede
Check if the rockers/cowl vents are clogged with leaves or other debris
1991 244 LH2.4 m46 302k? miles
Old 10-16-2017, 11:05 AM   #3
57plymouth
57plymouth's Avatar
Also check the wiper pivot seals
Sven, the 1991 245
Old 10-16-2017, 11:11 AM   #4
planetman
planetman's Avatar
To clear the rocker drains of debris open the drivers door and remove the plastic threshold cover, pull back the carpet to expose the inner rocker then pull the plastic plugs and you will probably see debris. Clear the debris with a vacuum cleaner with a small diameter hose, reinstall the plugs and test for leaks by pouring water into the fresh air intake in front of the windshield.
If you find debris on the drivers side you should probably check the passenger side too.
Since I have the luxury of compressed air, I also blow air into the fresh air intake to push additional debris down into the inner rocker.
Eric
Torrance, CA 90502
Old 10-16-2017, 11:30 AM   #5
BillyMaysHere
BillyMaysHere's Avatar
Old 10-16-2017, 11:39 AM   #6
districtmotors
Wow - all very helpful. Thank you so much.
