Old 08-31-2019, 09:38 AM   #1
iHateVolvoPeople
Default G80 swap question
Yup, another G80 thread.
I have a 1993 945T with a g80, should be 3.73s I believe. I also have a 93 245 M47 car with 3.31s (open). If I want the G80 in my 245, I cannot get away with just swapping the guts because the ring and pinion would be different due to the different ratios.
Do I need to swap the guts but leave the stock 3.31 ring and pinion, or do I need to pull the ring and pinion out of my 245 and install the 3.73 ring and pinion along with the G80 guts?
Anything driveline related absolutely terrifies me and Iíd almost rather pay a professional to do this work, but figured Iíd also ask here.
TIA
Feedback Thread
Current:
'93 244T M47
'95 Camry A140E, 254k
'99 Camry A140E, 256k
'04 TSX 6MT, 210k
Old 08-31-2019, 12:19 PM   #2
Jaypee_6680
If you’re happy running a 3.31 rear, then it’s as simple as removing the differential, fitting your 3.31 ring to the G80 diff, the re-install the diff.
John
Jaypee_6680 is offline   Reply With Quote
Old 08-31-2019, 01:09 PM   #3
iHateVolvoPeople
Originally Posted by Jaypee_6680 View Post
If youíre happy running a 3.31 rear, then itís as simple as removing the differential, fitting your 3.31 ring to the G80 diff, the re-install the diff.
John
I would prefer the 3.73 for some more oomph, but if itís easier to swap and keep the 3.31s, thatís what Iíll do.
Thank you.
Old 08-31-2019, 02:19 PM   #4
Vincent Gagnon
Vincent Gagnon's Avatar
John
What if the pinion frome one set and the ring gear from the other set are not evenly worn and the teeth meet at a weird angle?
Member of TBCCS
Old 08-31-2019, 02:36 PM   #5
iHateVolvoPeople
Then Iíll drive it for a week, empty the metal shavings, and refill with clean oil.
Old 08-31-2019, 09:25 PM   #6
Vincent Gagnon
And the lash will be spot on?
Old 09-01-2019, 12:58 AM   #7
iHateVolvoPeople
Obviously. Just like it is now on our 300k mile rear ends. Backlash is well within spec.
Old 09-01-2019, 01:24 AM   #8
Vincent Gagnon
Sweet.
Old 09-01-2019, 03:54 AM   #9
Jaypee_6680
https://www.240turbo.com/volvorearends.html
This should tell you all you need to know.
As long as you’re using a matching ring and pinion, and the backlash is within spec (it was when I did mine), then you’ll be fine.
To use the 3.73 you’d need to install the 3.73 pinion in your 240 casing. Chances are you’d need to re-shim to get your backlash in spec, which involves removing carrier bearings etc.
All can be done, but you’ll need new bearings and much more time.
If you’re happy with your 3.31 then you’ll probably get away with a straight swap.
I think others may have miss-read my first reply. For clarity, you must always use the matching ring and pinion sets, which can be done most easily with the 3.31 as you can bolt the 3.31 ring to the G80 diff.
John
Old 09-01-2019, 08:01 AM   #10
iHateVolvoPeople
As long as youíre using a matching ring and pinion, and the backlash is within spec (it was when I did mine), then youíll be fine.
To use the 3.73 youíd need to install the 3.73 pinion in your 240 casing. Chances are youíd need to re-shim to get your backlash in spec, which involves removing carrier bearings etc.
All can be done, but youíll need new bearings and much more time.
If youíre happy with your 3.31 then youíll probably get away with a straight swap.
John
Perfect, looks like Iíll be keeping the 3.31 for now due to time constraints. Thanks against John!
Old 09-01-2019, 11:25 AM   #11
Vincent Gagnon
Rings and pinions are machined as a set, they wear as a set, but I guess those machine shops are just being pernickety.
Never mind, carry on.
Old 09-01-2019, 02:46 PM   #12
Jaypee_6680
I think weíre both saying the same thing here!
Old 09-01-2019, 03:49 PM   #13
Reading comprehension problem? Twice in the same thread. Or, just trolling as usual?
Old 09-01-2019, 04:36 PM   #14
Vincent Gagnon
I think we’re both saying the same thing here!
Yep, just want to make sure.
Thanks for the insult.
How is this trolling?
Old 09-01-2019, 06:03 PM   #15
Just checking. His English seemed crystal clear to me, twice in the same thread. Your MO on here is trolling. I noticed how you removed the banned members from your signature. Nice. As if that wasn’t trolling. Caught yet again with your hand in the cookie jar.
Old 09-02-2019, 01:53 AM   #16
K9 240
K9 240's Avatar
[QUOTE=Jaypee_6680;5992068]If youíre happy running a 3.31 rear, then itís as simple as removing the differential, fitting your 3.31 ring to the G80 diff, the re-install the diff.
Almost !
You also need to remove the bearings to swap over the shims from your original diff to the G80 diff (each to the same side). You'll need new bearings to replace the one's you destroyed taking them off.
You can try leaving the shims as they are but chances are you'll end up doing it all again. At least the second time you do it it's a lot quicker!
Tim
K9 240 is online now   Reply With Quote
