Old 08-18-2019, 11:19 AM   #851
doleary
John sent you a pm, when your all set with the kit i would love to get it.
doleary is offline   Reply With Quote
Old 08-20-2019, 08:39 PM   #852
doleary
I assume by your lack of response (John V) that this is no longer available, if something changes please let me know.
Old 08-20-2019, 08:53 PM   #853
white855T
Originally Posted by doleary View Post
i assume by your lack of response (john v) that this is no longer available, if something changes please let me know.
--> call (206) 431-9696<----
Old 08-21-2019, 04:56 AM   #854
doleary
Thanks for the tip, I'll give it a try
Old 08-31-2019, 04:50 AM   #855
TurboDutch
I'd also like to have it can I go after you doleary?
TurboDutch is offline   Reply With Quote
Old 02-16-2020, 08:17 PM   #856
B-RAD
I’d like to get on the list for this as well. I sent a pm as well as called but voicemail was full.
B-RAD is offline   Reply With Quote
Old 06-12-2020, 05:18 PM   #857
TurboDutch
Can anyone give some details about the squirters? I would like to buy them and convert my B21 to squirter block.
Old 06-12-2020, 08:42 PM   #858
bobxyz
bobxyz's Avatar
Web search for: BMW Oil Spraying Nozzle 11111739907
Old 06-13-2020, 05:57 AM   #859
TurboDutch
Yeah thanks I also found it last night on page 6 or 7 sometin.
furthermore we needs;
- BMW Oil Spraying Nozzle 11111739907
- Tap metric fine M8x1,0
- 200mm long 7mm diameter drill.
- Spot facer with 7mm pilot
- Some loctite thread sealer.
did I miss anything?
http://forums.turbobricks.com/showpo...&postcount=566
Above link for proper discription of use
Old 06-14-2020, 04:00 PM   #860
bobxyz
bobxyz's Avatar
^^^ post 566 is the same one I have bookmarked for latest instructions. Post 639 shows a recent, or maybe latest?, kit.
If you look at the squirter parts carefully, you'll find that there's a tiny little spring and ball valve in the squirter bolt. I assume this cuts off the squirters until there's good oil pressure.
A couple suggestions:
- find a picture, or temporarily install the crank, to figure out which side of each cylinder to machine. One side has good crank clearance to the squirter, the other side looks very tight (maybe unusable?). The side varies by cyl.
- I found it better to drill the initial hole with a 1/8", or maybe a 3/16" drill. It was much easier to see where the hole was going to align it on the center of the oil galley. Enlarging it with the final drill was then quick and accurate.
Old 06-14-2020, 04:38 PM   #861
TurboDutch
Before drilling you normally always punch a center point so you can accurately drill the hole.
I was thinking to have a surfacing tool with 7mm pilot so that you only need to drill once instead of several different sizes.
