Old 03-03-2009, 01:32 PM   #76
Jerd
Jerd's Avatar
I ask because i read that smog technicians physically test to make sure the EGR is functional.
"The technician's inspection is visual, and does not include the testing for proper operation of any emissions component. The technician is required to simply locate the components visually and insure they appear properly connected.
This is true for all emissions components except the EGR valve and "Check Engine" light. The EGR valve will be inspected for functionality anytime a vehicle undergoes the "Basic" version of California's smog test, as opposed to the "Enhanced" smog test (which utilizes a Dynomometer). The "Check Engine" light is inspected on all vehicles which are equipped with one.
The smog technician visual and functionally inspect the EGR system through the use of a vacuum pump with pressure gauge, and then has him or her enter this information into the smog machine. So actually, the smog machine has no knowledge of the EGR system failure other then the technician's input."
Old 03-05-2009, 05:12 AM   #77
davidmacq
Bored Member
davidmacq's Avatar
I want to buy some of these chips. Just now hearing about them!
davidmacq is offline   Reply With Quote
Old 03-05-2009, 08:25 AM   #78
thelostartof
unbalanced chemical
thelostartof's Avatar
the for sale thread just got bumped ... so DO IT
Old 03-07-2009, 04:52 AM   #79
klr142
Turbo, what?
klr142's Avatar
Just did a couple of 16.9s with them. Over 2/3 tank of gas, full interior aside from floormats basically. With the clutch fan on as well as the A/C/P/S belt on. Last year, with ~100 less lbs, no accessory belt aside from the alternator, and no clutch fan I did a high 16.6. If I lightened the car to that extent and ran the reduced driveline loss setup I'd be at between 16.3 and 16.5. Head's never been off the car, only a B cam, advanced 2 degrees, in an AUTOMATIC 240.
Old 03-07-2009, 05:31 AM   #80
JR-66
How much does it weight? I did measure mine years ago, bone stock(no ac, all manual) 240 4-door, B200E(k-jet), M47, virgos, spare tire, original tools, full tank, scale showed 1330kg(2932lbs) without driver.
Put the numbers in some trap speed calculator and it shows pretty accurate hp numbers. http://www.tunercalcs.com/hp-from-qu...rap-speed.html
Turbopower
JR-66 is offline   Reply With Quote
Old 03-07-2009, 01:08 PM   #81
klr142
Turbo, what?
klr142's Avatar
Well, I haven't weighed it in a good while, but you have to remember to include your weight when you do that sort of thing... You aren't just moving the car, you're in there too. That being said, I know our combined weight is more than 3000lbs, and using that number it still gives me 122whp. I've never dynoed over 109whp corrected, 112 uncorrected, and that was about 4whp over what I did the same day with the clutch fan, PS/AC belts still on. With a "weight" of 3100lbs, which is more accurate, that calculator says 126whp. It's generous, IMO.
Old 03-07-2009, 04:43 PM   #82
JR-66
Adding drivers weight is so obvious that I left it out... There are loads of calculators out there, can't remember what was the one guy recommend, he said that it is the most accurate one. And use trap speed only, tire spin or bad launch wont effect trap speed much(assuming you don't burn your rubbers all the way to the finish line...).
Old 03-08-2009, 11:36 AM   #83
YellowT5-r
YellowT5-r's Avatar
I don't think my AMM likes 15 PSI very much...
See my above posts for details on the car. Only significant change is that I took 1/2 turn of pre-load out of my waste gate actuator to see if my previous 1 PSI spike was causing trouble - no joy.
WOT hard launch, still getting what feels like a fuel cut at right around 5k.
Also third to second gear kick-down pulls, the boost comes right up to 15PSI (really really fast, but with 0 spike) and I get the same fuel cut feeling, but this time it's as soon as the car hits 15PSI, regardless of RPM.
In the plus column: I'm not getting any audible ping during any of these exercises and the car pulls, revs and spools MUCH faster and smoother than it did on the stock ECU and EZK. It just seems like I'm getting near the fuzzy edge of the stock AMM and green tops. This is great news since a 3" AMM and brown tops are only a boneyard run away!
In the meantime, I'll start by dropping my boost to 14 PSI and working from there.
YellowT5-r is offline   Reply With Quote
Old 03-08-2009, 02:24 PM   #84
klr142
Turbo, what?
klr142's Avatar
Yes, and the results of that? It only takes a couple of seconds to turn the boost down and re-sample...
Old 03-16-2009, 10:00 AM   #85
gsellstr
gsellstr's Avatar
Ok, figure this might help to settle some nerves here in Cali.
Took the wagon in for a smog yesterday, complete with 012 and 65# Delphi's. Passed at just a hair over the average emissions on HC, CO was just under average, NOx was a touch over, though that's with a generic cat that takes a little while to warm up.
RIP
Nick Fengler "fengler" 8/6/18
74 144 B20
90 745Ti
Old 03-16-2009, 12:05 PM   #86
thelostartof
unbalanced chemical
So it passed?
Old 03-16-2009, 12:22 PM   #87
Ruben
Ruben's Avatar
Originally Posted by gsellstr View Post
ok, figure this might help to settle some nerves here in cali.
Took the wagon in for a smog yesterday, complete with 012 and 65# delphi's. passed at just a hair over the average emissions on hc, co was just under average, nox was a touch over, though that's with a generic cat that takes a little while to warm up.
:-p
A dirty mind is a joy forever
Drove:
'87 Escort 1.3:'90 mini Jumbo:'87 360GLT:'87 744T:'92 240 Polar:'84 744T:'95 854T5:'90 744GLE 16v:'87 340 1.7:'79 343DL :'84 340L:'91 240DL lpg:'89 360 GL:'94 944TDIC M90:'85 360 GL:'90 745 GL:'89 744 GL:'86 745 TIC:'94 Nissan Sunny 2.0D:'92 Peugeot 205D:'88 360:'85 340GL:'86 360GL:'84 242TIC: '85 244 TI:'89 Dai racer:'95 460: '85 360GLS:'83 340 DL: '97 944IC: '91 AX Cup:'93 Diehatsu:'98 Polo D:'87 360GL
Drive:
Citroen C15D
Ruben is offline   Reply With Quote
Old 03-16-2009, 12:25 PM   #88
gsellstr
gsellstr's Avatar
Yup, passed quite easily, at roughly half the limits, with the 012, 65# Delphi's, and IPD Turbo cam at 3*.
Now, if I didn't have a 'friend' at the shop it wouldn't have passed on the visual due to the 'excessive' downpipe.
Old 03-16-2009, 01:11 PM   #89
L8 APEKS
Yayayaya, hohohooo!!!
L8 APEKS's Avatar
There's no way that guesstimating is accurate down to 4 whp. Get to a scale and a dyno!
Sean Williams
'94 850 Turbo Wagon (daily) :: 14.0 @ 98.5
B5234|AW50|TLAO tune|3" exhaust|NA cams|65mm tb|38mm BOV|E40 blend
'75 244GL (project) :: 8.4 @ 85.6
B230FT|AW71|1031|gutted|TLAO chips|welded 3.73|19T|3" exhaust|IPD cam|E62 blend|55 lb inj. (@ 4 bar)
CLICK HERE for the 244 BUILD THREAD!
BRAND NEW Mitsubishi 18T and 19T turbo conversions for sale...from $450...CLICK HERE or PM for details!
L8 APEKS is offline   Reply With Quote
Old 03-24-2009, 06:58 PM   #90
L8 APEKS
L8 APEKS's Avatar
FINAL UPDATE:
Bog/flat spot went away after a full tank of gas (400 miles or so). The car is running high 14's now, at 11 psi, on 91 octane...total daily driver trim and I can punk RSX Type S' and the like with my boost turned DOWN! In short...AWESOME. Noticeable improvement over the last set of aftermarket chips I had...so i can only assume that going from stock chips to these is going to be night and day.
These chips = WIN!
Old 03-30-2009, 03:52 PM   #91
orie
Doctor Who
orie's Avatar
Appologies to Mike, i FINALLY got to installing the chips this weekend. Life just doesn't have enough time in it. Now, to business:
I've had the chips (fuel and ignition) in for about 100 miles so far. Specs:
1990 745Ti, stock everything (at this point). Yes, i will be boosting up, as soon as my suspension is handled.
Just to confirm: T cam, LH2.4 pink label, 13c @9psi (ok, up a little bit)
I took it on a test drive right after installing the chips, and right off the bat, three things happened.
#1, wow. I can feel a difference in the pull.. it's somewhat akin to the benefit i felt when i opened up the intake and installed the 90+ exhaust manifold on an otherwise stock '85. So, i have high hopes when I open the intake and exhaust on this baby.
#2, My cold acceleration hesitation is gone! Or at least, seems to be! No idea why, but i'll take it!
#3 Revving to 6500 is FUN.. but now i need a cam. BAD.
I just commuted the car 100 miles.. she cruised great, and i swear i can pull up hills at freeway speed with less boost. So i'm actually thinking i may gain some MPG out of this. We'll see on the next tank!
More feedback to come after i've had it in for a bit. Thanks Mike.. awesome!
Hefty, rear-wheel-drive, and comfortable, the 700- and 900-series wagons were essentially an evolution of the 265 philosophy. Fun, boxy, fast, boxy, and fun. More right angles than a box full of right angles.
BrickSpeed forums!
orie is offline   Reply With Quote
Old 04-06-2009, 11:40 PM   #92
thelostartof
unbalanced chemical
Bump, some have been asking about these chips so i just wanted the feedback thread back on top so they can see it
I do believe there might be one more person out there soon to post feedback as they did pick up a used set of chips
Old 04-07-2009, 12:01 AM   #93
linuxman51
BRANDSCHUTZVORSCHRIFTEN!
linuxman51's Avatar
might consider linking to it in your sig.
Megasquirt Tuning!
Old 04-07-2009, 12:33 AM   #94
thelostartof
unbalanced chemical
Oh snap, that almost makes sense, I shall do that once I get off this BB
Old 04-09-2009, 08:10 AM   #95
Ursan
Bored Member
Ursan's Avatar
I'm ordering mine up tonight or tomorrow depending on how fast paypal gets the transfer.
Damnedest thing though, when I pulled the EZK & ECU out to look at, the car is running better all of a sudden. Not that it was bad before, but better in the higher 3,500-5,200 range.
wierd. Oxidized connections? Same thing happened when I dis/reconnected the injector ballasts & scoured the engine grounds.
how psi a stock can support?
I admit I'm stupid...
Old 04-09-2009, 09:59 AM   #96
gsellstr
gsellstr's Avatar
Time for an update. Swapped out the 6500 chips for a set of 6800 chips. Same great driveability, but I haven't had a chance to wind it out in 2nd since they've learned yet (hooray for traffic). No real issues to speak of. Mileage is still right on par at about 18 in town, 20-22 on the highway, but I'm still having quite a bit of timing pulled due to issues on the car that I haven't figured out yet (not an issue on the chips by any means).
We also installed my old 6500 chips into another local's car over the weekend and he's happy as can be. I'll try and get him to post up, since he should have a few miles on it now.
Old 04-16-2009, 12:06 PM   #97
Ursan
Bored Member
Ursan's Avatar
Is there a FAQ/manual for these online I can check out?
Old 04-16-2009, 12:28 PM   #98
thelostartof
unbalanced chemical
There is a nice Chipping FAQ in the articles section.
and everyone that posted here, mind posting a bit more feedback since you have had the chips for more than long enough to have them learn and have some long term feedback on them like maybe changes in mpg?
Old 04-16-2009, 12:34 PM   #99
Ursan
Bored Member
Ursan's Avatar
I keep close tabs on my MPG( 16-17 city winter, 17-18 summer). I'll be installing mine as soon as they come in. I'll do a fillup just before & after a week of driving & post the results.
Everything in my car is stock except for a 7x5" cylinder air filter mounted behind the grill & a G-Valve set to 12PSI.
Old 04-16-2009, 12:34 PM   #100
gsellstr
gsellstr's Avatar
Haven't really noticed any change in mileage, though I've still got that wonderful 'knock retard' issue that my car has had for years. One of these days I'll swap the flexplate...
I jumped on it today on the freeway, got a clean pull with 10.8-11.3 AFR's, as the speedo quickly passed 80 in second. It's kinda funny winding it up to 6800...the tach kinda starts going haywire!
Otherwise I'm still getting around 18 in town, haven't done any real long trips to get highway mileage yet.
I'll bug Andrew to post up how he likes his...
