Old 08-18-2009, 01:36 PM   #201
thelostartof
unbalanced chemical
thelostartof's Avatar
We have never done it, let the air escape as you will see it bubble up pretty good on leaks
Old 09-01-2009, 10:09 PM   #202
740Weapon
Traitor
740Weapon's Avatar
Thumbs up
Mike asked me to post a review of his chips so here it is:
For years it has been my opinion that there are exactly two things actually ‘wrong’ with LH: The fuel enrichment when coming into boost and the rev-limiter. Mike has a chip set that addresses those two things so I finally bought a pair about a month ago: 6800 RPM fuel chip and a matched ignition chip.
Car made about 230 WHP based on the trap speed using the standard bolt ons: 19t turbo, e-bay IC, IPD cam, 2.5” exhaust, and brown top injectors w/ stock AMM and LH.
I won’t focus on the quarter-mile results or butt-dyno because I have not raced yet with these chips. I do expect some improvement in ET and consistency.
I instead would like to focus on the massively improved drivability of my car.
The boost onset enrichment is much better than stock. The only time the car hesitates even for a split second is if I do terrible things like downshift to second gear from cruise at 70 mph, grab instant boost at 6000 RPM, and pull to 6800 RPM before slamming into 3rd to pass the douchebag Audi in front of me doing 70 in the fast lane. So basically, I no longer have to concern myself with the knocksense light when grabbing low gears to spool the turbo instantly in traffic. Previously with the stock LH I had to roll the throttle just right or the ping at boost onset was emotionally crippling.
Having an extra 500 RPM has also vastly improved vehicle drivability. Previously having to shift at 6200 RPM with a power peak of like 6000 RPM and that wide 2-3 RPM gap was a massive annoyance. I was constantly bumping off the limiter accidentally causing the car to fall on its face. This has ruined many a drag run and made for some embarrassing passing maneuvers. Now with the extra 500 RPM there is no chance of that crap.
Between 6200 and 6800 the power starts to fall off naturally as I move past the power band of the cam, exhaust, head etc. (a good thing!) This means my eyes can stay on the road instead of on my tach. My time window for shifting has changed from impossible to a reasonable fraction of a second. And when I fall into the next gear I’m a few RPM higher and more in the power band.
Also, watching the tach bury deep into the red is incredibly entertaining for me and the sounds the motor makes at those RPM freaks out bystanders to no end.
So in summary, these chips have vastly improved the drivability and fun factor of my 940 turbo. I recommend them to anyone anywhere ever.
-Dana
'90 744 16 Valve. 16.317@85.55. Sold.
'92 244. Sold. http://pbase.com/740weapon
Old 09-03-2009, 02:12 PM   #203
Ursan
Bored Member
Ursan's Avatar
Okay, followup.
I'm pretty much eliminated an air leak, if there is one, it's very small.
The car runs damn good, except for the idle. If I set it to stock & let the ECU via IAC & TPS handle it, it idles very low & lopey. So much so that if I snap the throttle it hesitates ever so briefly. If I adjust it to stock control, is that something that I should leave alone to let the ECU learn?
So, I try to adjust the idle but it's either too high or too low.
Also, I want to replace the stock ign coil. I get an occasional miss that I've deduced to be the coil. What is a decent performance fairly drop in replacement? I've heard the Crane PS-60 is good, anything I need to do to install it? Does it match the stock cables okay?
I'm also (still) waiting on an adjustable cam gear from RSI, what's a good starting point for cam advance on this? I was thinking somewhere between 2° & 5°. Thoughts?
TIA.
how psi a stock can support?
I admit I'm stupid...
Old 09-03-2009, 02:38 PM   #204
740Weapon
Traitor
740Weapon's Avatar
Okay, followup.
That really has to be a hardware setup issue. I had a cold O2 sensor cause a similar problem in the past. if that helps.
Old 09-03-2009, 02:44 PM   #205
Ursan
Bored Member
Ursan's Avatar
hmmmmm! that's sparks of possibilities because I can adjust the idle one day (hot) & have it too fast the next (cold).
Old 09-04-2009, 05:33 PM   #206
maxman142001
I like turtles
maxman142001's Avatar
im getting the same idle issue with my RSI cam...not sure if its the K cam exhaust or something else...I might try a new O2 Sensor and see if that helps
as nothing is impossible with God, even turbo's fixing themselves
-2011 VW GTi
maxman142001 is offline   Reply With Quote
Old 09-06-2009, 04:51 PM   #207
DanielRogers
Originally Posted by maxman142001 View Post
Also allow all 9 series ECU's to run stupid big injectors. Im running 60lb with a 4 Bar FPR. Mike is running 75lb with a 4 Bar as well and both setups are very streetable.
is this still just with a 3" maf? no need to go bigger?
93 940T - 20G / IPD springs / Bilstein's / K-cam / 3" / upper strut brace / chips
Originally Posted by adrianpike View Post
i will shoot you through the internet.
DanielRogers is offline   Reply With Quote
Old 09-06-2009, 05:17 PM   #208
thelostartof
unbalanced chemical
3" amm yes, Bigger might help adjust fuel maps depending on your setup but for now my car is just fine with the 3" amm and 75lb injectors
Old 09-08-2009, 02:48 PM   #209
Jerd
Jerd's Avatar
I use to have an idle that was all over the place and sometimes it would idle super low. Turns out it was my tps got one from pick-n-pull at pocket sized fee and slapped it on. I now have a steady idle and it sticks at ~700
Old 09-08-2009, 02:52 PM   #210
DNAsEqUeNcE
†John3:16
DNAsEqUeNcE's Avatar
We'll be runnin 75 lbs with a 3" amm.
Old 09-10-2009, 11:22 PM   #211
maxman142001
I like turtles
hahaha bitches!!!
just pasted emissions with my current setup...no tweakin needed
copy of printout in the morning
Old 09-10-2009, 11:35 PM   #212
DNAsEqUeNcE
†John3:16
hahaha bitches!!!
Blessed!
Old 09-11-2009, 12:05 AM   #213
gsellstr
gsellstr's Avatar
Old news man. I passed with the 012/65#, fresh motor, IPD cam, etc. with FLYING colors. I think I posted that back a few pages.
RIP
Nick Fengler "fengler" 8/6/18
74 144 B20
90 745Ti
Old 09-11-2009, 12:39 PM   #214
sbabbs
sbabbs's Avatar
Yeah and I did a 12.7, get on it. I might have been slightly tweeked from the cocktails all day long beforehand so I'm thinking swap on this 960 throttle body with yoshifab adapter and go draggin again and shoot for a 12.5.
1995 940 White racing wagoon. T25 .64 a/r m90 to put in
Old 09-11-2009, 12:42 PM   #215
maxman142001
I like turtles
Now to fix the lines going to my charcol canister! I was happy that this thing pasted with 65lb injectors and a RSI cam
Old 09-11-2009, 12:46 PM   #216
sbabbs
sbabbs's Avatar
Looks like you failed the pressure test. Typical volvo driver...the agricultural dept of enviromental quality? See, fences where needed after all.
Did I forget to mention, I don't have to DEQ where I live... It's the old Jim Fisher estate. Straight pipes all around. Chillum. Did you see where Kettle came out with a new chip, Island Jerk they call it. Prison planet. I'm building a rocketship, volvo powered..
Old 09-11-2009, 12:55 PM   #217
thelostartof
unbalanced chemical
What is the current setup of your car? as in What go fast goodies are on it, and then what kind of boost are you running?
Also what did the time slip details look like? I am hoping to get back before the end of sept when I left for cali
Old 09-11-2009, 01:01 PM   #218
sbabbs
sbabbs's Avatar
Umm we'll lets see here.
89 744
93 B230ft 150k stock
84 162? turbo head with 8k RSI double valve springs.
RSI stage II tubo cam with biggest powerband in North America pulls to 7.5k.(They claim(They are RSI))
Dales underdrive two pulley front balancer pulley.
016 AMM in a real 3 inch tube...
75lb injectoids.
lightened lh2.4 dog dish flywheel
6 puck clutchnet ceramic disc rebuilt by local place.
Stock pressure plate.
overdrive 5 speedGetrag with RSI adapter
92 960 wagon 1041K 3.31 ratio moddified to lock up at any speed rear end.
16T turbo and ported 90 plus.
Big NPR intercooler.
I'm running about 20 pounds of boost on E85.
Stock exaust out the side with dodge truck resonator.
Soon I'll have the 960 throttle body with the yoshifab adapter.
Update, got the Yosifab 960 throttle body adapter on and working and it's even faster...
Also the car is stripped and gutted and scraped and molested.
The time slip is posted over there in that east never beat the west thread.
Currently running a custom tune to 7.5k on lh for e85 in the race car and I can do 45 in 5th and no luggin, but my 90 wagon I'm running your chips, and love them.
Old 09-11-2009, 03:02 PM   #219
gsellstr
gsellstr's Avatar
Crap, that ain't too far off my setup, aside from the slightly bigger turbo, bigger cam, more boost, and enough injector. Hopefully I'll be somewhat closer to your times once I get the fueling issue handled...
Probably won't beat my 13.9 for this year due to funds.
Old 09-11-2009, 11:35 PM   #220
klr142
Turbo, what?
klr142's Avatar
Let's go tomorrow night.
Damn, Simon. What?
Old 09-12-2009, 03:43 PM   #221
drruble
Originally Posted by gsellstr View Post
Ok, now you got me curious, what's a diapering flat spot??
Just razzing ya a little. Glad they're workin' out for ya!
Gary, it's in his Avatar....
drruble is offline   Reply With Quote
Old 09-12-2009, 04:34 PM   #222
Jerd
Jerd's Avatar
I really need to instal my brown tops buy some chips and go get some times.
Old 09-22-2009, 06:10 PM   #223
Krisverde
Krisverde's Avatar
Ok so I have driven about 100 miles since the chips. I can't give a huge feedback on them. BUT the car is just all around better with both chips. It feels smoother, it's alittle more responsive and it's fun to rev to 6800 rpm.
My setup is 15g @13 psi
Greentops
UD intercooler
B cam.
1989 Ford f150 5.0
1991 Ford f150
2013 Ford Focus ST
Krisverde is offline   Reply With Quote
Old 09-22-2009, 07:30 PM   #224
thelostartof
unbalanced chemical
and 3" turbo to tail exhaust sans cat with a 7+ year old flowmaster 40 series muffler
Old 09-23-2009, 07:31 PM   #225
chilli67
Question 89 780 t chippable?
went to my dealer for some q&a & found out my car has tcm with possible ezk 115 & definately
has a LH 2.2 leaving me with with what chance to chip it? what are my other mod options knowing this new info. toronto canada changing weather. time running out for working in
driveway. was planning on just chips, head work (inc ipd cam) & stronger bottom end with mbc & exhaust 2.5"
chilli67 is offline   Reply With Quote
