Old 05-20-2011, 07:46 AM   #1
MadDog_945
Våga Vägra 8V
MadDog_945's Avatar
Default Building a TwinScroll Header
Hi.. since i have enough cash to buy a TigWelder with integrated Plasmacutter , im now in the position to buy some mandrelbends..
What do i need to have? How many Elbows 45° , 90° how many metres? :D
What diameter, wallthickness? Is there a masterplan of guiding the runners for a special turbo position?
ordering will be done here
http://server3.gs-shop.de/200/cgi-bi...nbieterID=4423
Thx so far ppl
Old 05-20-2011, 08:23 AM   #2
MadDog_945
Våga Vägra 8V
MadDog_945's Avatar
Uh !! And do i need two wastegate for both pairs or is it possible to use one?
Old 05-20-2011, 09:29 AM   #3
nathaninwa
The Beloved Oarnge Juice
nathaninwa's Avatar
I'm gettin ready for a hella busy weekend with the ipd car show......but ill pm you later about this. I know others will have great ideas for you.....compile them all and get your Tig'on! If you end up using the same material I do, I'm sure I could make a paper template of my cut jig for the collector and mail it flat to you. The collector is almost the hardest part....besides piping your primarys to tight so you can't get in there and weld it out! Sometimes I have to cut a primary out....bench weld and reinstall. Twin scrolls are fun.
962j 815/692@27psi
THIS IS FORSALE V
Old 05-20-2011, 06:14 PM   #4
dheming
dheming's Avatar
Not sure what material you're planning on using, but there's a pretty decent thread about a guy building some simple turbo headers from 304SS here: http://weldingweb.com/showthread.php?t=45112
'67 Amazon 220 - B18D M40 - Modernizing in Progress
'92 Silverado - 350 5spd
"Why is it that there's never enough time to do it right, but there's always enough time to do it again?"
dheming is offline   Reply With Quote
Old 05-20-2011, 11:15 PM   #5
55superbeetle
Not trying to take away from this forum but Honda-tech.com has a very good fabrication forum if you want to get ideas and help. I learned how to make manifolds from that forum and some of the fabricators that post are second to none.
http://www.honda-tech.com/forumdisplay.php?f=53
1.5" 304 schedule 10 should be all you need and its way cheaper to buy 90's and cut them. To get the full effect two gates are needed.
Heres a divided manifold I made for my friends k20 powered bug,
55superbeetle is offline   Reply With Quote
Old 05-20-2011, 11:37 PM   #6
smokeyfan1000
Guest
Was reading an turbo article in Hot Rod(or Car Craft/Popular Hot Rodding forget which) and it was said it helps to pair up the firing order sequence cylinders in pairs. Better spool time was the claim. The OEM Volvo n/a cast iron mani even does this.
Old 05-23-2011, 07:05 AM   #7
MadDog_945
Våga Vägra 8V
MadDog_945's Avatar
Whoa.. sexy
Do you dump the wastegate to atmosphere or do i miss the ju`nction behind the downpipe?
Old 05-23-2011, 11:30 AM   #8
Captain Bondo
Exklusiv Zubehör Klub
Captain Bondo's Avatar
Only buy 90 degree weld els. 45 degree weld els are about the same price as 90 degree ones (in other words, they're twice as expensive. Just cut a 90 degree el in half).
1.5" schedule 10 stainless is pretty much the standard. It's 0.109" thick. No real master plan, other than that on a twin scroll you'll want to pair 1-4 and 2-3 together.
Twin scroll collectors are quite easy, because you only have to fit 2 runners together.
Trying to run a single wastegate on a twin scroll manifold gets ugly, fast. You need to keep the plumbing divided right up to the gate, otherwise you lose a lot of the advantage of going to a divided setup.
I would run twin 38mm Tial MVS gates, they're fairly cheap, and quite small and easy to package.
Couple examples of divided manifolds i've made over the years:
Sched 10 stainless, being set up for twin gates:
16ga 1.625" set up for single gate (not reccomended):
-Kenny
Old 11-02-2012, 04:53 AM   #9
MadDog_945
Våga Vägra 8V
MadDog_945's Avatar
Ok,
I have found a new dealer for stainless fittings.. but they only have 33,7mm 40mm or 42,4mm all with 2mm wall
is 2mm too thin? 2,54mm is 0.100" and what diameter would be best?
Old 11-02-2012, 08:06 AM   #10
Triebwerk
Wanted to build a turbo header for my Audi, but it was to much of a project. Anyhow, I checked the internet and also wrote with Nathan.
For the material 304l (1.4307) a lot of people are using.
321 (1.4541) seems to be even better but more expensive.
http://www.schoch-edelstahl.de/produ...-bauart-3.html
Got an offer from a company in Austria. 11€ for one 90° bend 1.4541 in 38 x 2,5mm.
regards Mathias
[Austria]
Triebwerk is offline   Reply With Quote
Old 11-02-2012, 08:17 AM   #11
linuxman51
BRANDSCHUTZVORSCHRIFTEN!
linuxman51's Avatar
that guy looks familiar.
Megasquirt Tuning!
Old 11-02-2012, 09:11 AM   #12
MadDog_945
Våga Vägra 8V
MadDog_945's Avatar
Thats way too expensive dont you think? My offer was 2,17€+VAT for a 40mm/2mm bend V2A
Old 11-03-2012, 12:39 AM   #13
Oldmandan
I've seen people use one large wastegate, with a divider in the tube. The divider protrudes past the v-band into the wastegate
http://www.turborangerforums.com/vbi...yimg&imgid=144
http://www.turborangerforums.com/vbi...yimg&imgid=143
Oldmandan is offline   Reply With Quote
Old 11-03-2012, 01:15 AM   #14
nathaninwa
nathaninwa's Avatar
Thats what I did on my Ebay header I bought for my 2j.
Old 11-03-2012, 06:47 PM   #15
Captain Bondo
Ok,
2mm wall would be ok. You would want the 40mm or 42,4mm diameter.
If you're going to the effort of building a twin scroll manifold, I would use 2 wastegates if you have the space. The single with a divider is ok, but 2 wastegates is the ideal.
Old 11-06-2012, 09:38 AM   #16
MadDog_945
Våga Vägra 8V
MadDog_945's Avatar
Thx
As flange material? 8 oder 10mm ?
/edit
yeah and for sure i will go the dualWG way.. when do, do it right ;)
So im looking for a good but affordable one... the TIALs are way too expensive.. thy are 320dollars here in germany each... thats the price i pay for a car :D
38mm woulkd be enough right ? hard to find in good china quality with V-Band
Old 11-06-2012, 11:02 AM   #17
Roger-Dee
is DeeWorks.ca
Roger-Dee's Avatar
I like my MVS they are nice and tight, easy to get on and off. Keep an eye open on the used market, I bought my second that way and saved close to 50% off the original price. I've seen a bunch of external gate act funky, I wanted something reliable for those 25+ psi run where you don't have a second to watch the boost gauge.
94 944T - 16v turbo - 12,14@122
Lm7 5.3, S475, Ms3Pro, 4l80e - 10,36 @ 134 / 6,70 @ 107
www.deeworks.ca
Need T5 Adapter? T5 Speedometer Plug? Gm Torque Converter Adapter? Freeze plug retainer? HE351 solenoid plug? Pm me!
Roger-Dee is offline   Reply With Quote
Old 08-23-2013, 03:42 AM   #18
MadDog_945
Våga Vägra 8V
MadDog_945's Avatar
Hey guys.. here are my first tries to fab a TwinScroll.. pretty newbish ;) But you'll first have to figure out how to merge oval to round.. this is really stealing my nerves
Old 08-26-2014, 05:23 AM   #19
MadDog_945
Våga Vägra 8V
MadDog_945's Avatar
So.. long time no progress in here...
Right now im trying to figure out how to cut the collector pipes.. which machine, what angle and so on.. bandsaw doesnt work for this job.. im turning a spacerdisc for my miter saw to fit a 10" Grinderdisc in it.. looks like this:
How would you weld the doubles to the scrollisolator?
Old 08-26-2014, 01:36 PM   #20
culberro
culberro's Avatar
Some tips on the welding: less heat. If your not back purging with argon you will want to keep the heat down so it won't "sugar" on the backside. Welds should be shinny.
Also, before welding on the header, practice on some spare tubing. Cut a straight section into multiple rings (maybe 20mm long) and weld it back into a tube.
For cutting tubes I just use an angle grinder with a 5in cut-off wheel.
Old 08-26-2014, 04:40 PM   #21
MadDog_945
Våga Vägra 8V
MadDog_945's Avatar
Those welds were my first stainless attempts looks much better already ;)
I will backpurge everything for sure.
Old 08-29-2014, 04:22 AM   #22
MadDog_945
Våga Vägra 8V
MadDog_945's Avatar
Would you use Stainless flanges or Mild? i think mixing up both materials with the right filler could work.. but i'd prefer using both stainless.. but the Mild flanges are cheaper and dont warp like the Enterprise..
Old 12-09-2014, 09:41 AM   #23
towz-T
EL hipo explosive
towz-T's Avatar
more pics maddaog
'00 V70 2.5TDI <= stored until i sell it
'04 V70 2.4TDI <= exploded in norway
'10 V70 2.0TDI <= DD
'89 745 B204GT <= project moneypit
my introduction thread that i am desperately trying to keep alive
cuz on turbobricks, posting about something and not doing it counts as quitting a project halfway through. Quitting a project halfway through counts as finishing it.
Yay you finished it!
towz-T is offline   Reply With Quote
Old 12-09-2014, 12:20 PM   #24
BDKR
Section 9
BDKR's Avatar
Timely these recent posts are. I want to learn how to do this stuff bad.
For all you Dijkstra fanboys:
Old 12-09-2014, 01:04 PM   #25
Duder
Comes with a free Frogurt
Duder's Avatar
If you want all the benefits of a twin-scroll turbine housing, do the following with the manifold:
-Equal length runners to the collector
-Pair cylinders 1-4 and 2-3 together (on a conventional 1-3-4-2 firing order engine)
-Wastegate both sides separately with no crossover or leak path until they join back into the downpipe after the turbine
Twin scroll turbine housings take advantage of evenly timed staccato pulse energy from the exhaust flow at low engine speeds, and you need all of the above for it to work well. The fact that the exhaust flow path is divided all the way to the turbine housing also allows negative pressure wave scavenging if you use the right geometry for the engine speed you're tuning for.
