Old 01-14-2018, 09:07 PM   #26
iHateVolvoPeople
Originally Posted by To old for this View Post
Previously did the ground pins mod for enchanced timing. Is there any improvement if a chipped unit is used. My system is a 2.4 na. What is the best one for chipping.
Grounding advances it the exact same amount throughout the entire rev range IIRC, the chips will probably have a varying timing map adding as much safe advance as possible, and pulling it where need be.
Someone else who knows what they’re talking about will have to chime in though because i may be wrong.
Feedback Thread
Current:
'93 244T M47
'95 Camry A140E, 254k
'99 Camry A140E, 256k
'04 TSX 6MT, 210k
Old 01-14-2018, 09:32 PM   #27
sbabbs
sbabbs's Avatar
Once you have a chippable EZK you can put any EZK chip in it, 219 or 207 or 209 or whatever, turbo or non turbo it will work. IF you want custom EZK ignition tune then most important is the EZK tune turbo or non turbo.. WHo you gonna get your better ignition EZK tuned chip from??? Ha..
1995 940 White racing wagoon. T25 .64 a/r m90 to put in
Old 08-31-2019, 05:07 PM   #28
iHateVolvoPeople
Are the chippable gold EZKs worth anything more than any other chippable EZK? I have a 214 chippable gold box and don’t really have a need for it (most likely). What are the difference between say a chippable gold 214 and a regular black lh2.4 turbo EZK? More aggressive?
Old 08-31-2019, 05:29 PM   #29
sbabbs
sbabbs's Avatar
We'll the ones with replaceable chip, you can replace the chip with one you programmed up to do what ever the fluck you think would be better to do for your ignition curve in your racing volvo. Ones that don't have the chip you can't do nuthing with except add the chipped daughter board then chip it.
Yes they worth more cause guess why? They can take a chip. Wait you wanna know if gold is worth more then coal? Yeah.. Gold just means it has chippable chip for sure. Black gold with chip just as valuable.
As far as the ignition map tune relates to color? No, hey the red label ones got EGR on a black box. If you wanna keep track of EZK color scheemes..
Gold box EGR or not? CAn't tell they all have white labels regardless. Must memorize EGR number to know that if it is or not is that.
Old 08-31-2019, 05:53 PM   #30
iHateVolvoPeople
It’s an egr EZK unfortunately.
If anyone wants to trade a non chippable EZK (turbo) + cash for this chippable ezk, I would do it. Did that last year.
PM if so.
