Old 08-27-2018, 01:44 PM   #26
mikep
The MP
mikep's Avatar
Default Round 2
IPD blue 7-9 series sport springs, stock 240 springs from a GT that turn out to be the softest 240 springs ever (swapped, probably) and some cheap coilover shocks and springs from Lawrence.
Black front 240 spring, from an unknown donor (taken from the front of a GT by VB242, hoping they were sweet springs).
85#/inch.
Next up, IPD blue 7-9 series sport spring, front.
Starts around 130#, 145# avg, 150# peak. Some rise due to seat issues. Not a progressive spring.
Next up, 240 rear, unknown donor. Was found in a 242 GT.
poncy 95#, but 50% stiffer when in a 240 rear arm due to motion ratio.
Next, IPD blue rear for 7-9 series.
What? The same as a stock 240 spring? No, there's more. It's progressive.
The rise at the end is unresolved, so we had to test to a higher pressure. We chose a distance, and that distance wasn't enough.
95# rising to 140# and staying there.
So at normal ride height, cushy. In a turn or under load, you get less compression.
teal coilover, 350#. (not volvo related)
Shock time.
(not volvo related)
"made in canada" Pro Shocks T40902SA
(below that WB 735)
As set, good for 300#ish springs, didn't try adjusting them. Didn't see how to.
These are still available in black, starting around $80 each in a variety of dimensions.
Old 08-27-2018, 01:48 PM   #27
mikep
The MP
mikep's Avatar
I'll measure dimensions later. School is starting, need to sign off for a bit.
Old 11-01-2018, 11:47 PM   #28
towerymt
the real Towery
towerymt's Avatar
1988 Hartford CT 244
Front springs 80 lb/in
449mm (17-5/8") free length
166mm overall Diameter
13.2mm (.520") wire diameter
5.5 free coils
11.5" installed height hanging
8.5" installed height sitting
Rear 91 lb/in
415mm (16-3/8") free length
129mm overall Diameter
11.85mm (.466") wire diameter
7.5 free coils
15.25" installed height hanging
12.25" installed height sitting
Measured the springs that came off my '92 240 sedan.
Front:
17-1/4" free length
0.540" wire
Rear:
16-1/4" free length
0.475" wire
Rear springs had some blue on one coil. Fronts are still covered in undercoating.
Old 12-22-2018, 03:13 PM   #29
jwernerny
jwernerny's Avatar
I've got rear springs from a '94 964 (Mk I IRS), and a '92 944T if you want to measure them. PM me.
John Werner
* 1992 944T * 1988 764 GLE V6 * 2002 WRX Wagon (needs motor) * 2006 Honda Odyssey *
jwernerny is offline   Reply With Quote
Old 12-28-2018, 12:04 PM   #30
mikep
The MP
mikep's Avatar
Cool. I would like to measure towery's springs, too.
Old 12-31-2018, 12:43 PM   #31
towerymt
the real Towery
towerymt's Avatar
Old 12-31-2018, 07:29 PM   #32
mikep
The MP
mikep's Avatar
I mean, i’ll buy you fried chicken first..
Old 12-31-2018, 08:12 PM   #33
towerymt
the real Towery
towerymt's Avatar
Now yer talkin. Schmaltz me up, big boi
Old 01-02-2019, 12:23 AM   #34
Marvelous3
Who engineered this?
Marvelous3's Avatar
Should ride like **** with the 1.5:1 motion ratio squared in back.
Rear vert rate would be 222lb/inch.
Front you lose a little, so 130-ish.
If I had that much rate out back I'd want at least 250 in front to keep it from pitching.
What is considered a "good" ratio for us? Grey car is 300 front and 200 rear and seems to ride super predictable. I sort of guessed when I bought springs at those rates but maybe I got lucky? I'd always read you wanted more spring up front than in the rear.
Old 01-02-2019, 03:10 PM   #35
mikep
The MP
mikep's Avatar
Good question.
Most cars have more weight up front, so you need more rate in front for a similar frequency as the rear.
Even with a 50:50 balance, most o.e. engineers go a little higher in front so it doesn't "pitch" over expansion joints or small bumps in smooth roads.
For performance, it really depends on the suspension type, your driving style, surfaces, etc.
A solid rear axle has an odd motion ratio in roll, so to avoid a huge rear bar, some people go higher in rear. Some anti-roll bars (like ours) have a huge motion ratio as well. In front, it's half as effective on the control arms, compared to on the strut. The rear is even worse, since the effective arm length is the length of the control arm it is bolted to.
300 front and 200 rear gets you roughly equal, which is a good starting point. The wagon with 350 front and 275 rear handled great with mild sways, but was bad to ride in on a bridge. The sedan we put together with 350 front and 225 read was very good. I think it had a 25mm ipd front, 19mm rear.
Old 01-04-2019, 01:30 AM   #36
woodenpudden
lacks goats
woodenpudden's Avatar
Correct, its only fault was a tendency to plow, but behavior on bumpy roads etc. was excellent
Originally Posted by DMFWallace View Post
Flunt delivers!
woodenpudden is offline   Reply With Quote
Old 01-04-2019, 02:56 PM   #37
towerymt
the real Towery
towerymt's Avatar
I wouldn't commit to a ratio front:rear, but I think I'd settle on about 3:1 as my favorite.
For example, I could like 300lb front /150lb rear, but I would never do 2:1 ratio with 800lb front springs.
I've used as high as 325lb rear springs. Went back down to 250lb on the autocross car. Have used lowering springs or cut overload springs on the rear as well. Soft rear springs seem to work fine for handling.
Daily driver: 300 fr / 125? rear (IPD lowering springs in rear, stock bar)
Lemons: 475 fr / 150? rear (cut wagon overload springs in rear, no bar)
Autocross: 550-700 fr / 250 rear (no rear bar)
I've also tried Jamex front lowering springs (they were soft), and 200lb rear springs (a LONG time ago). Car would rotate! Great for street tires and not a lot of camber. Didn't rely on a ton of front grip to make the car turn in. Toe-out and rear spring rate can make a 240 turn as well...but it's not as easy to drive. That was an early autocross setup.
Old 01-05-2019, 01:58 PM   #38
mikep
The MP
mikep's Avatar
^those 200# stock car springs were what I used after you figured out to use the top cones on the bottom of a 240 rear set-up.
For anyone comparing my post about front-rear balance, remember that RWD Volvos have a 1.5:1 motion ratio (squared) in back, and a strut car loses a bit of rate from the SAI. (5%)
200# in back becomes 300# in vert.
350# in front becomes 333#.
Old 01-05-2019, 08:16 PM   #39
Marvelous3
Marvelous3's Avatar
Good question.
What shocks and struts were you using? Off the shelf koni yellows or something custom?
Old 01-05-2019, 10:09 PM   #40
mikep
The MP
mikep's Avatar
Koni single adjust worked ok, chris had those in the wagon and sedan.
I like the r-sports and bilstein inverted struts a lot. If you ever need numbers to get them revalved, John V can steer you straight.
I just welded volvo tops on 260z struts to use bilsteins.
Old 01-05-2019, 10:14 PM   #41
John V, outside agitator
Skip the motion ratio talk for a second..Whatchoo sayin, mang? The spring is behind the spindle....
shock is in front roughly what..How many INCHES from front pivot to axle center? How many inches from middle of the axle to the shock?
Sleezattle WA, USA
--> CALL (206) 431-9696<----
www.rallyrace.net/jvab
www.rallyanarchy.com
Vive le Prole-le-ralliat
— Don Marquis
Old 01-07-2019, 11:53 AM   #42
mikep
The MP
mikep's Avatar
On a mid-80s 244,
front pivot to:
Axle 568mm
Spring 692mm
Shock 424mm
Old 02-06-2019, 05:44 PM   #43
towerymt
the real Towery
towerymt's Avatar
Sold. They soft anyway.
Old 02-22-2019, 02:27 PM   #44
klr142
Turbo, what?
klr142's Avatar
On a mid-80s 244,
front pivot to:
Axle 568mm
Spring 692mm
Shock 424mm
Go on, sir John?
Old 05-04-2019, 01:56 PM   #45
I found my set of NOS IPD wagon lowering springs. They are black and are from somewhere around 2003. They have tags on them giving you the spring rate. 153lb on both front and rear springs.
Old 05-06-2019, 08:51 AM   #46
mikep
The MP
mikep's Avatar
Cool, thank you Dave!
Old 05-07-2019, 12:26 PM   #47
jwernerny
jwernerny's Avatar
I'm assuming 245, correct? (Not 745, etc.)
Old 05-08-2019, 12:37 PM   #48
Yes, they are 245 springs.
Old 03-16-2020, 03:38 PM   #49
jwernerny
jwernerny's Avatar
From an old post I wrote in 2008 (http://forums.turbobricks.com/showpo...0&postcount=26
IPD Nivomat Delete Rear Springs:
92.5 lbs/in. Free Length: 20". Compressed Length ~8" (1100 lb load on each spring)
Old 03-19-2020, 09:36 AM   #50
shoestring
shoestring's Avatar
How about a spreadsheet for these? I love a spreadsheet.
