Old 03-06-2017, 12:47 AM   #51
FreeEMSFred
FreeEMSFred's Avatar
Originally Posted by Tuff240 View Post
Not all oil pans are created equal. Some years the "top plate" is just spot welded in a few places. Under high G's like a track car sees the oil runs out the sides between the top plate and the pan. We weld all of those up with a continuous bead or find the better year pans.
True in a sweeper! In a sweeper you have other issues, too, though. The top end of these engines only drains in right hand turns. In left hand turns it'll well up up there and you'll lose volume/surface level in the sump - this hurts. My head will be modified to assist in this area. The other issue to consider is that the top plate only provides oil control, as the pump is emptying the sump quite quickly and relying on refill through the hole to continue working. That's where lots of sub-plate capacity comes in - it gives you more time to empty and requires more latent oil in the head to cause an issue.
Which year sumps? The 94ish squirter I have has a close fit that fluid can leak through, but not quickly. The shape is more of an issue, though, with the cut out for the pump and pickup quite large. Building a good wet sump (approximating an hour glass) for one of these would not be easy due to exterior space constraints, but I intend to give it a shot :-)
Old 03-06-2017, 03:07 AM   #52
Tuff240
240 Ninja
Tuff240's Avatar
This is a cheap/quick/easy fix that we do to our street cars that will see occasional track time. I take a small chunk of 3" exhaust pipe, cut it in half, open it up a little to match/fit the oil pan, mark oil pan, cut hole in oil pan, weld in modified piece of pipe and cap both ends. Works great and keeps average mildly modified street cars with DOT rubber from starving for oil while in long left hand sweepers on a track.
-Patrick
Old 03-06-2017, 07:34 AM   #53
xmlhack
xmlhack's Avatar
Do you have a picture of the inside of the pan? What year engine did this pan come from. It looks like an old b20 pan.
72 Volvo 142E
xmlhack is offline   Reply With Quote
Old 03-06-2017, 08:41 AM   #54
Tuff240
240 Ninja
Tuff240's Avatar
Sorry, nope.
It's just a standard old 92 b230 pan.
Old 03-06-2017, 09:28 AM   #55
They're boxy but good!
Hmm, I inadvertently made an extra hole on the right side of the oil control plate when I welded in my oil return for the turbo, I didn't look too close inside when I hole sawed the hole in the side of the pan and ended up being half way in the plate and had to cut out a notch on it. I'm sure it's not as effective as your mod but I feel better now about hammering it around the 270° sweeper at nccar
[/url]
Old 03-06-2017, 03:31 PM   #56
FreeEMSFred
That can't be more than about an extra half quart/litre? Better than stock, but the issue with left hand sweepers cannot be solved by modifying the sump.
Here's my old first attempt at this, it has a full-length top plate with volume under it from front to back. The four wings take the volume up a full 2 litres, and the whole lot is spaced down 12mm for another litre, 7 litres all up. The top plate is fully welded and the only cut outs are dip stick and pick up tube of a minimal nature. Top plate height is important, and needs to be below high tide mark, approximately where low tide is at max RPM with a couple of litres of oil up around the rest of the engine. Any lower and you have less volume under control. Any higher and you have air under the plate and more slosh. This thing has worked well, though I've not really stress tested it to my own standards. Doing something like this on the Volvo is going to require more engineering and possibly a two-piece design for ease of removal.
Old 03-06-2017, 05:06 PM   #57
Tuff240
240 Ninja
Tuff240's Avatar
My solution is not about volume. I was trying to cure a problem with the oil light coming on (low oil pressure due to starvation) through sustained left hand high G turns. Once we figured out that it was oil creeping up the side of the block, this solved it. That was backed up with actual track testing at PIR.
Are there better ways to do it with more volume? Sure, but fitting even a Gp A style oil pan in a 240 is a pain in the ass. This drops right in with no problems or clearance issues and it does the job for most mild applications. If you are really serious about tracking (racing) a redblock, you should just dry sump. It's expensive, but so are cranks, rods and pistons after you burn them up.
That oil pan you posted isn't even a reblock oil pan.
And just in case anyone is intending on copying what I did, the bottom and sides are flush with the hole made and the top overhangs about 1/4" to create a natural oil shield of sorts. It's also all just below the original top plate.
Old 03-07-2017, 01:51 AM   #58
FreeEMSFred
Yes, I know it's not Volvo. It's the sump that I mentioned in an earlier post and said I'd upload a picture of and it's close to optimal as far as wet sumps go. As you say, and I'd already said, no wet sump is suitable for serious track use, but a sump like the above with lots of volume below a full top plate is as good as it gets. And good enough for most, if other things are taken care of. The engine it's from has the opposite problem to a redblock engine, right hand sweepers. I'm yet to modify that head, but when I do I'll post a thread specifically on oil control and cover it with a few example engines.
As for high-G left handers, the cure is to add drainage to the head on the right hand side so the ~2 litres of oil that get trapped up there can return to the sump and contribute to lubrication instead of flooding everything in site and potentially exiting through breathers (if any). I'm glad the tube oil control method helped, but you/they still had a LOT of oil in the top end that wasn't available for the pump to draw on.
Old 03-08-2017, 06:01 AM   #59
FreeEMSFred
I spent some time measuring my block this evening and although it can't hurt, I have my doubts about the benefit of opening up the feed tube to 13mm ID (matching pump and block) from 11mm ID. Why? Because the gallery from the pump entry to the block and the filter is a mere 10.0mm, and to improve this you'd need to bore it out from the bell housing end. Not a minor job, for sure. Is this in the plans? Or just a case of "may as well make it better while fixing the clearance issue"?
Old 03-08-2017, 09:04 PM   #60
CaseyHooligan
CaseyHooligan's Avatar
Well, I guess I'll find out if it makes a difference....
And yes, a lot of this is "eh, might as well while I'm in there".
I'm no Fluid Dynamics Phd, but in my experience it does help to improve some areas of a system, even if they aren't the biggest restriction.
Blue 79' 242 GL
Engine Rebuild in process!
CaseyHooligan is offline   Reply With Quote
Old 03-08-2017, 09:23 PM   #61
BillyMaysHere
BillyMaysHere's Avatar
mini surge tank/swirlpot of sorts>?
Old 03-09-2017, 02:35 AM   #62
FreeEMSFred
The real improvement only arrives by pushing the point of lamina flow further up the RPM/flow range and delaying the onset of turbulent flow. For a given perfect tube you will reach turbulent flow at some flow level and throughput will fall drastically despite raising pump end pressure, lowering bearing end pressure, and causing more bypass (where the spring comes in). Until that things are fine.
Smoothing things up definitely helps push that point higher, too. But the existing tube is fairly smooth, and 1mm larger ID than the bored out gallery. The worst parts aren't the 13 to 11 to 13 steps, they're the sharp right angle corners in a few places.
And you stated you were interested in low RPM flow. Although it's true that any improvement will help push pressure drop down, final pressure up, and flow up with it, measuring the improvement at the lower RPM non-turbulent end of the flow spectrum might be a challenge
If you did bore out the lower gallery to 13mm and retap the end for a bigger bung then yeah, there'd be a benefit in overall flow (only significant if the stock system was breaking into turbulent flow at some point, though), provided you followed the improvements through the filter input and output (easy enough to do). The upper rail is bi-directional so wouldn't need much touching and can almost certainly out-flow even a 13mm pump-to-upper-rail connection:
PI * 5.5 * 5.5 * 2 = 190.1 sq mm
PI * 6.5 * 6.5 = 132.7 sq mm
Not taking the non-uniform flow rate, nor the non-even split in flow to the two halves, into account, that's a clear win to the upper rail over any lower feed improvements.
Max effort: Bore that lower gallery out to 13mm and retap the end! Then radius all 90 bends. Then rest assured you've got zero pressure drop issues at higher RPM :-)
Old 03-10-2017, 02:40 AM   #63
peterwgpa
peterwgpa's Avatar
Like your mod Tuff and fact you have tested it.
peterwgpa is offline   Reply With Quote
Old 03-10-2017, 02:43 AM   #64
Tuff240
240 Ninja
Tuff240's Avatar
Track was literally 5 minutes away from our shop. I drove race cars to the track on the public streets several times.
Not as elegant and sophisticated as Casey or Fred would do, but it's simple and works. KISS
Old 03-11-2017, 08:45 PM   #65
CaseyHooligan
Blind now from all the science...
I totally agree with your determination in regards to the lower galley cross-sectional area.
But what about the stock oil pump transfer tube's interface to the pump? The oil leaving the gear pump cavity runs right into the end of the transfer tube!!! that point right there has got to cause significant turbulence(at any velocity). So increasing the transfer tube's cross sectional area, plus reducing the tube interface area change will likely slow velocity and reduce turbulence, at least before the oil gets the the block.
I'm all for theoretical simulation, but I already know oil system efficiency is not a critical issue for most so I'm just optimizing flow and addressing a few other issues here(main stud clearance, oil seal failure).
I'm a proponent of real-world experimentation, I'll just have to wait and see if all this makes a difference when I get this engine running.
Old 03-11-2017, 08:47 PM   #66
CaseyHooligan
Tuff, I'm totally taking a page from your book and adding a kick-out on the passenger's side.
Old 03-12-2017, 12:48 AM   #67
Tuff240
240 Ninja
Tuff240's Avatar
Cool, I look forward to what you come up with. I'm really enjoying watching your engine build thread. One of the best redblock builds here ever I think. At least as far as thought and care go. Some of us may agree or not agree with some things, but no doubt the level of detail is impressive to say the least.
Old 10-17-2018, 06:07 PM   #68
CaseyHooligan
Just sticking my head back in here after being buried by life and other projects.
I'm starting to wind this engine build back up so I can get it on the road.
I'll post more soon, promise!
Old 10-17-2018, 06:14 PM   #69
t8fanning
8v are still cool, right?
t8fanning's Avatar
Awesome. Can't wait to see it. I always wondered what happened to that awesome pump setup.
1982 242 Turbo.
Old 10-22-2018, 01:40 PM   #70
CaseyHooligan
It's still quietly sitting in the corner of the garage, patiently waiting to become a useful part of my life!
Old 05-09-2019, 06:48 PM   #71
CaseyHooligan
I finally started the process of building more of these oil tubes. Just received the machined fittings, enough for a dozen assemblies. In 4130 ChroMo.
Waiting on the tube bending, Then I need to TIG them together.
Hope to have something to show in about two to three weeks at this rate.
Old 05-09-2019, 06:55 PM   #72
t8fanning
t8fanning's Avatar
Put me on the list.
Old 05-09-2019, 07:16 PM   #73
CaseyHooligan
Put me on the list.
You already are!
Old 05-10-2019, 06:20 AM   #74
Swedbrick
Swedbrick's Avatar
Also interested if any are remaining! I was planning to make a similar set myself, but with the lack of a lathe, I'd rather get them made by a fellow tb'er
Volvo 745 - IPD springs, Sways, K-cam, LH2.4, M90 swap, 3.94 diff, track/daily
Peripoli Guilietta SS - 1962 vintage, 50cc, 2 stroke, 3 speed (handshift), straightcut and dogbox, runabout
Old 05-10-2019, 08:30 AM   #75
Stiggy Pop
Stiggy Pop's Avatar
hat in the ring
'79 242
943 pickup
