Old 05-10-2019, 09:44 AM   #76
snailpoweredbrick
snailpoweredbrick's Avatar
Please add me to the list if there is room!
RWD Parts for Sale (240,740,940)
http://forums.turbobricks.com/showthread.php?t=243774
snailpoweredbrick is offline   Reply With Quote
Old 05-10-2019, 01:00 PM   #77
GTJordan
Been here for too long
GTJordan's Avatar
I still want one.
Jordan
Old 05-10-2019, 03:30 PM   #78
IansPlatinum
IansPlatinum's Avatar
What would be the ballpark price for one? Interested.
'96 854 Platinum - "Trusty"
'92 245 - "Boat"
'71 145 - "Rusty"
Previous:
'73 1800es - "Sunny"
'92 940T
'98 S70 T5
'99 S70 GLT
Old 05-10-2019, 04:06 PM   #79
Same
Old 05-10-2019, 05:15 PM   #80
Tfrasca
Tfrasca's Avatar
Also interested, depending on the price.
Old 05-10-2019, 07:40 PM   #81
CaseyHooligan
CaseyHooligan's Avatar
Thanks for the interest Brickers'.
If anyone is interested in these oil tubes please send me an email so I can keep in touch with you in a more convenient way.
Zeligsgarage@gmail.com
These are still untested, so I'll likely give a few out at no cost to those willing to try them, or at least evaluate them.
I don't have a clear idea on how much they might sell for, but the cost of making them in small quantities isn't cheap. I'll figure it out soon.
Blue 79' 242 GL
Engine Rebuild in process!
CaseyHooligan is offline   Reply With Quote
Old 05-10-2019, 09:43 PM   #82
MrD
Ditto interested
1993 940 Turbo - Silver / Grey
MrD is offline   Reply With Quote
Old 05-12-2019, 10:02 AM   #83
satanburns1
Satanburns2
satanburns1's Avatar
I emailed you Friday I believe. I will sit and respond with engine build specs. I can run proto type tube on my stock ish street/light race motor for a year if you want and report back. I'll get right on the email tho with all my build specs. I deff need one.
satanburns1 is offline   Reply With Quote
Old 05-12-2019, 01:42 PM   #84
AndrewTheHobbit
is there a downside to just running a AN tapped setup to and from the oil pump?
AndrewTheHobbit is offline   Reply With Quote
Old 05-12-2019, 05:52 PM   #85
satanburns1
Satanburns2
My engine was already assembled so I didn't want to tap the block. Then saw this thread and saw the solution I'm not able to devise...
Old 05-16-2019, 01:19 AM   #86
CaseyHooligan
I don't see why not. If you try it, show it!
Old 05-18-2019, 10:17 AM   #87
jmc0369
jmc0369's Avatar
emailed!
Member: TBCCS
"Emancipate yourselves from mental slavery; only ourselves can free our minds" - you know who!
"It is no measure of health to be well adjusted to a profoundly sick society" - Jidu Krishnamurti
jmc0369 is offline   Reply With Quote
Old 05-24-2019, 04:46 PM   #88
CaseyHooligan
So, I'm getting real close to getting those oil tubes made.
I went ahead and began working on some dedicated tooling.
A weld fixture and a tube bending jig that allows me to get tight radius bends very close to one another. These tools although being an expensive up-front investment, will allow me to easily(and more cheaply) make oil tubes on demand as needed.
Old 07-01-2019, 01:47 PM   #89
CaseyHooligan
*Fixed the pictures not remote loading!*
Just a little update,
I've managed to get a set of tubes bent that I'm happy with, although I had to resort to filling the tubes with bismuth alloy to prevent the pretty dramatic collapsing of the thin-wall tube.
You can see here what I've done, I used a low-temp alloy(~190F) to fill the tubes before bending so they bend more like a solid bar.
The Bismuth alloy looks and behaves a lot like solder, but melts below the boiling point of water so removing it is easy, just heat with a heat gun or place the parts in boiling water.
The end result is a nicely bent part, similar to a mandrel bent part. However, it can get a bit tedious filling and draining tubes.
I'm finding the process of making these tube components to be very labor intensive and I haven't yet found a supplier that get produce this shape to the needed tolerances, at least for a reasonable cost.
In the future I'll be using some other methods for producing these components, I'll have too!
Anyhow, I've completed my weld fixture and trimmed the tube assemblies to length, now I just need to TIG braze everything together, black-oxide them and box-em-up.
Old 07-01-2019, 03:42 PM   #90
Aw man. All of the image hotlinks are broken.
Old 07-01-2019, 07:01 PM   #91
CaseyHooligan
Can you see the images?
I logged out of Turbobricks and I can still see them.
Old 07-01-2019, 07:05 PM   #92
MrD
Prolly a permissions issue
Old 07-01-2019, 07:33 PM   #93
Yeah definitely a Google view permissions thing going on here.
Old 07-01-2019, 11:18 PM   #94
Cwazywazy
Single jingle
Cwazywazy's Avatar
They worked when I looked earlier..
I don't know what I have
Old 07-02-2019, 08:23 AM   #95
Stiggy Pop
Stiggy Pop's Avatar
I can see them
'79 242
943 pickup
Old 07-02-2019, 11:09 AM   #96
culberro
culberro's Avatar
To add more fun to this:
I can see the images while using my iphone.
I can not see the images on my laptop.
Old 07-02-2019, 02:13 PM   #97
I know someone with a mandrel bender for small tubing. I could see if its something they think they can tackle.
www.BEIGEPOWER.com
Kaplhenke Racing Facebook
The only safe bet is Ben.©
Old 07-02-2019, 02:57 PM   #98
pat244ti
pat244ti's Avatar
Another interested party here. I'd take 2 and 1 for backup
Another simple part that could save me a huge issue on a race weekend [losing the pump oring]
- Patrick
83 244ti - road race
83 244ti - rally
73 1800es - resto
08 c30 T5 6spd - daily
97 dakota 5.2 4x4 single cab short bed - apocalypse mobile
Old 07-04-2019, 04:16 PM   #99
Chilm
Double Dutch
Chilm's Avatar
I want one too, keep me posted please.
And... I can not see your new pictures either :(
Double Dutch - Build and goodies thread ;P
Volvo 945 - Blue Pearl - LPT Polar 2.3 Limited Edition
B230-FK Turbo - 90+ ported - 15G Ported - Airintake
Erland Cox Regrind - Blabla Chips - 3 inch exhaust
MBC on 0.95 - Wasted Spark - Sponsored by my wife
Chilm is offline   Reply With Quote
Old 07-26-2019, 01:18 AM   #100
CaseyHooligan
By the way, I think I fixed the pictures from that previous post about tube bending...
Tube Bending with pictures
