Old 11-27-2017, 09:48 PM   #1
shoestring
shoestring's Avatar
Default We measured Redblock cam valve events; here's what we got.
So for years and years now, there's been no reference as to any kind of real, hard data concerning the redblock cams as far as, well, anything. The duration figures we have, what lift value is it? How does one manufacturer compare to another? If you do get some kind of info, it's often at some mystery measurement. As someone who values data versus speculation, it's been a challenge.
Anyways, we took matters into our own hands and measured up 5 of the 6 cams we have access to and put it all in a Google sheet which I'll share here. Here's what we did:
Installed each cam in my '91 245 as per the service manual and shimmed #1 intake and exhaust to 0.015" clearance. Note: this engine has had .040" trimmed from the head, but I have previously measured what this does to cam timing, and as rumored it absolutely retards timing 4 degrees. ALL TIMING MEASUREMENTS HAVE BEEN CORRECTED TO AS THOUGH THE ENGINE WAS ABSOLUTELY STOCK. I have a stock head gasket in this car so it does not come into play.
We measured lift using a dial indicator on the shim bucket. The first data point is at 0.001" lift, what we called "first movement", you could call seat-to-seat, though that would be just before any movement at all (too hard to be very accurate). We then recorded at 0.005", which, if you add in the 0.015" lash, would equal 0.020", or 0.5mm, a common Euro data point for some manufacturers. Next was 0.025", which is 0.040" or 1mm when you add the lash figure, another Euro data point. The last of this style of measurement was 0.035", 0.050 after adding in the lash, and everyone should be familiar with this. We then measured every 0.050", starting at 0.100", figuring that would be more relevant to cylinder head flow data points if you have them. We recorded intake and exhaust centerlines and the lift values we got (again, as installed, not gross lift), then went down the back side of the lobes recording the same points so you could calculate duration figures at whatever lift point you are working with. Finally, we recorded intake lift at TDC, which the Europeans also seem to like.
A couple notes here. First, these cams are all used, so there may be some variance from original, brand-new camshafts, though the IPD cam has few miles on it. Second, I've done this type of thing a lot of times over the years, so I'm confident in the numbers we generated. If something didn't look or sound right, we went back around (ALWAYS clockwise!) to check it again. Even if we were comfortable with what we got, we went back and randomly checked a couple points on each cam to make sure everything was repeating correctly. If the data's no good, what difference does it make how long it took, or how pure our intentions? Assume a MAXIMUM of 1 degree error, which should have no impact on comparisons for our purposes. Additionally, I occasionally find errors in my CALCULATION, that is, where I added the valve events to get the total duration figure. If you find some, hit me up so I can fix it. I do want to assure the crowd that the measured valve event timing is absolutely correct. When in doubt, use those numbers.
Anyway, for now we've done the factory Volvo A, D, H (oh yes I did), and K, as well as the IPD "VX". I have a B and a T which I'll get to, but it takes almost 2 hours to set it up and about 45 min per cam, so it's pretty much an all day affair.
Hope you get into this, we enjoyed doing it so that we could share it. When you click the link, give it a minute to load. There are tabs at the bottom for each cam that take a second to come up.
https://docs.google.com/spreadsheets...it?usp=sharing
Old 11-27-2017, 10:15 PM   #2
Good work! Thank you for sharing the information.
Old 11-27-2017, 10:59 PM   #3
oldschoolvolvo
oldschoolvolvo's Avatar
+1 thanks for the effort.
-Mike
1998 V70 T5
1979 242 DL 16v
|Feedback|
Old 11-27-2017, 11:20 PM   #4
EivlEvo
You senseless MANIAC!
Old 11-27-2017, 11:25 PM   #5
esmth
dirty swede
esmth's Avatar
That's awesome, thanks! awaiting the B cam results
Old 11-27-2017, 11:26 PM   #6
gsellstr
gsellstr's Avatar
Nice work man, thanks!
RIP
Nick Fengler "fengler" 8/6/18
74 144 B20
90 745Ti
Old 11-28-2017, 10:46 AM   #7
Ryan_R
OMG. This is such a GREAT resource to have put together. There is no word in the English language that says "Thanks!" enough for these data!
I've literally got a 'B' on my doorstep, and several 'A's in use. Can't wait to see what those measurements look like.
Much, much appreciated.
Thanks!!
-Ryan
Athens, OH
1987 245
1989 245 GL
1991 745 --Dog Waggin' 2.0
1995 945T -- Mildly modded
2011 XC90 3.2L AWD
https://people.ohio.edu/ridgely/e-code.htm
Ryan_R is offline   Reply With Quote
Old 11-28-2017, 07:54 PM   #8
swedefiend
swedefiend's Avatar
Can someone open this up and take screenshots?
I literally cannot see this at work or on my phone. WTF
Old 11-28-2017, 08:02 PM   #9
TurboDenny
Why am I here?
Awesome work! The 'Muricuh in me wants to see a .050" measurement to compare them Chevy cams.
Instagram: @itstotesdenny
Old 11-28-2017, 08:05 PM   #10
esmth
dirty swede
esmth's Avatar
you're lucky i'm bored
Old 11-28-2017, 08:12 PM   #11
swedefiend
swedefiend's Avatar
last one is IPD vx
Gracias
(But my break is over... I'll have to look later.)
Old 11-28-2017, 09:31 PM   #12
bobxyz
bobxyz's Avatar
The .035" valve lift values are the 0.050" cam lift values. The difference being the 0.015" shim gap.
Another set of cam measurements, but without the nice lobe profile details, is available at:
http://www.calgaryvolvoclub.com/foru...php?f=1&t=1942
For OP - are you sure about the 4° crank retard per 0.040" of head decking? I thought I'd figured this out as roughly 1mm of decking per 1° of cam rotation, or 2° of crank rotation, but my back-of-the-envelope scribbles may have been wrong.
Thanks for the detailed measurements and sharing with everyone!
Old 11-29-2017, 07:50 AM   #13
shoestring
shoestring's Avatar
Yes, I'm sure about 0.040" giving 4 degress retard. Years ago when I cut my first head I had read that this was the case and measured to confirm. If you go more, it may not be a linear value, but at least at this point it's accurate.
Old 11-29-2017, 09:29 AM   #14
photoman327
photoman327's Avatar
Another thanks.
Old 11-29-2017, 10:01 PM   #15
quillc
yv1a.com
quillc's Avatar
Would be illuminating having the M cam profile as well.
Chris
www.yv1a.com
Old 11-30-2017, 09:19 AM   #16
shoestring
shoestring's Avatar
If someone wants to send me one, I'll queue it up. Funny I don't have one for all the damn B230s around here.
Old 11-30-2017, 09:24 AM   #17
esmth
dirty swede
esmth's Avatar
holy frig are you in beverly, MA? i'm local and can borrow you an M cam
Old 12-12-2017, 02:11 PM   #18
OttoB
I put A and D cams in a CamDoctor measusement machine. Could share the results ( txt file) if anybody interested.
Old 12-12-2017, 02:54 PM   #19
Stiggy Pop
Stiggy Pop's Avatar
Nice work.
I'm in Western Mass near Springfield and have a spare, NIB, RSI Stage 3 turbo cam.
I think a lot of people, I know I am, would be interested in this data for the RSI cam. Let me know if you think we can coordinate somehow.
'79 242
943 pickup
Old 12-12-2017, 05:17 PM   #20
TWD
TWD's Avatar
I have one stored away. I know that I will never use it and that no one will ever want it, so can send it to you if no one is closer. The only request is that you can't send it back!
TWD is offline   Reply With Quote
Old 12-13-2017, 03:37 PM   #21
bent-grill
This is the biggest step forward in volvo home gamer hackery since john-v declared that lowering is for losers. Bravo guys, awesome work.
bent-grill is offline   Reply With Quote
Old 12-13-2017, 04:29 PM   #22
esmth
dirty swede
esmth's Avatar
I already lent him one
Old 12-13-2017, 04:40 PM   #23
122power
dude
122power's Avatar
Cam doctor.
Save the Volvo's.
Old 12-13-2017, 05:57 PM   #24
122power
dude
122power's Avatar
This, for all of them.
Old 12-15-2017, 05:40 PM   #25
shoestring
shoestring's Avatar
Cam Doctor for all would be pretty epic. I'd love to see the numbers. Calculus rules.
I'd love to do all that you want to loan me, but hold onto them until Spring. It's cold in the 01915 now...until April, probably.
I'm very happy to do this for everybody, and it's fun for us to do it. When the weather changes, we'll be on it.
