Old 11-18-2018, 10:11 PM   #51
lummert
lummert's Avatar
Starting to notice that these injectors work better at 2.7 Bar fuel pressure. Engine idles rough until it warms up at 3 Bar fuel pressure. Duty cycle is nearly the same at either fuel pressure. Idle: 60% compared to 58%. Engine off : 82% compared to 79%. So I take it that the fuel pressure difference has little effect on the duty cycle. So go with the fuel pressure that works best for the injectors?
Info that I found on Mustang Cobra site about running injectors that are too big:
* Lower fuel pressure and increase injector openings.
* Run richer at idle.
* Run a less aggressive injector if ECU allows it.
* Raise the idle speed.
* A combination of a few above...
Old 11-19-2018, 01:04 PM   #52
lummert
lummert's Avatar
Swapped to a second BMW 2.5 Bar FPR because car was hard to start this morning (35* F) with the Buick 3.0 Bar FPR. Now to wait for it to warm up a bit outside to do a pressure test with this other BMW FPR.
Looking through my FPR's to see if I have a good OE Volvo type FPR.
Old 11-22-2018, 02:54 PM   #53
lummert
lummert's Avatar
Today I found a different dwell to duty cycle conversion chart. I retested with the dwell meter on a warm engine and got 36 degrees on 6 cyl scale. According to this chart 36 degrees on 6 cylinder scale = 40% duty cycle. 40% duty cycle at idle in closed loop makes much more sense.
Ground controlled circuit @ 36 degrees on 6 cylinder scale = 40% duty cycle
Feed controlled circuit @ 36 degrees on 6 cylinder scale = 60% duty cycle
Not sure about the voltage reading that I was getting. With dwell meter at voltmeter connected at same time between test point and battery positive showed 5.95 VDC. 5.80 VDC corresponds to 60% duty cycle on same chart.
Old 12-18-2018, 02:59 PM   #54
lummert
lummert's Avatar
Found specs for 36 lbs/hr injectors when running at 39.15 psi (2.7 Bars).
34.0 lbs/hr @ 39.15 psi
357.3 cc/min @ 2.7 Bars
257 grams/min @ 2.7 Bars
35.84 lbs/hr @ 43.5 psi
376.7 cc/min @ 3 Bars
.52 BSFC - Estimated HP @ duty cycle
52.3 @ 80%
62.1 @ 95%
Old 12-18-2018, 03:28 PM   #55
gross polluter
They see me trollin'
gross polluter's Avatar
Duty cycle is calculated by comparing the injector pulsewidth to the time it takes to complete an engine cycle.
For example, an engine idling at 800 rpm takes 150ms to complete one full engine cycle of 720 degrees crank rotation.
If your idle injector pulsewidth is 3ms then your injector duty cycle is 2%. Simple as that.
You’re trying to look far to into this.
Old 12-18-2018, 03:33 PM   #56
lummert
lummert's Avatar
One thing I know for sure is that these injectors (Bosch 0 280 155 811) work best at 39.15 psi (2.7 Bars), same as when running these on a Ford Mustang.
Old 12-18-2018, 06:36 PM   #57
gross polluter
When you’re trying to patch it into a different application such as this, maybe. When properly controlled they’ll operate just fine with any other common fuel pressure.
Old 12-21-2018, 11:48 AM   #58
lummert
lummert's Avatar
I figure they would work just fine a 3 bar with a larger AMM.
Old 12-31-2018, 05:42 PM   #59
lummert
lummert's Avatar
Running these 0 280 155 811 injectors at 2.5 Bar resulted in an average of 14 MPG with my 1988 B230FT on LH 2.2. Yesterday I dug out another Bosch 0 280 160 237 3 Bar Fuel Pressure Regulator that was in my stash and installed it. This FPR fits 1989 Pontiac TTA (Turbo Trans Am), as well as other 87-92 GM cars with 3.8 L V6.
The specs are:
37-43 PSI with vacuum connected
40-47 PSI with vacuum disconnected and plugged
Buick has it rated at 45 psi.
I installed this fuel pressure regulator without any adjustment to the AMM POT screw. Waiting for the rain to let up long enough to check the baseline fuel mixture adjustment. The engine has a decent idle and good power. The warm starts seem to indicate that the fuel mixture is slightly rich. I also need to hook up the pressure tester and check against the FPR specifications.
Old 01-01-2019, 05:17 PM   #60
lummert
lummert's Avatar
Increasing the fuel pressure from 39 psi to 44 psi increased my MPG's from 14 to 19.8.
Old 01-03-2019, 09:48 AM   #61
lummert
lummert's Avatar
After taking time to set the baseline fuel mixture the MPG's are up to 20.94.
Old 08-01-2019, 08:49 PM   #62
lummert
lummert's Avatar
Been running these injectors for awhile now. Buick 3.0 Bar FPR, BMW white connector ECT, Open breather filter on valve cover. Toyota Supra Twin Turbo PCV valve mounted between block mounted oil separator and intake manifold vacuum port using 3/8 inch nipple (with vacuum pump intake filter fitted in the middle). Nipple on turbo inlet hose plugged. Been messing with adjusting the baseline fuel mixture. I have been enriching the mixture about a quarter turn using the AMM pot screw at the last 3 tank fillups. Every time I turn the screw another quarter turn clockwise i get .2 more miles per gallon, so far up to 24 mpg average on the last tank. I figure to keep enriching the mixture until the mpg's start to drop.
Old 08-07-2019, 08:58 PM   #63
lummert
lummert's Avatar
While replacing my 30k mile Autolite XP63 spark plugs with a new set I had on hand I found that number 4 plug had lots of white ash deposits. So I pulled the fuel rail to swap in a spare injector to replace number 4. Engine idles better, vacuum test gauge shows a steady 20 inches of vacuum at idle. Next I needed to reset the baseline fuel mixture. Managed to start with a baseline setting of 385 ohms at the AMM pot screw. Figure I'll end up with a baseline setting near 300 ohms (calculations show 298.67 ohms needed).
Old 08-10-2019, 12:13 AM   #64
lummert
lummert's Avatar
A day later and i had the top o-ring rip on number 4 injector and spray fuel when trying to start engine. Engine started but I smelled raw fuel, looked out drivers window and saw fuel running out from under car. Shut off engine, went to work fixing the problem. Had to pull injector rail in nursing home parking area before I could leave. Had 0-rings with me. Figured out that to be safe these injectors need one o-ring on the top and 2 o-rings on the bottom of each injector. So removed the o-ring spacer which is half as thick as 0-ring and installed to bottom 0-rings.
Everything seems to be secure at this time.
As far a baseline fuel mixture my calculations may have been incorrect. I was using 385 ohms as baseline starting point then remembered that when i had removed the plug from the AMM the baseline setting was 269 ohms. So 21% [300.6/363.1] more fuel should result in 269x.79=212.51 ohms
baseline setting.
Old 08-30-2019, 09:59 PM   #65
lummert
lummert's Avatar
Since fixing the leaking injector problem I've been averaging 24 mpg. But the hot restarts were acting like too much fuel. Cold start may have been too much fuel.
Yesterday I swapped the Buick 3 Bar FPR to the BMW 2.5 Bar (actually tests at 2.7 Bar/40 psi) fuel pressure regulator. The idle is much better, the running is much better, and cold and warm restarts are much better. Managed a 15-20 minute warm restart without issue.
Still tuning the AMM pot screw and checking the mpg's on tankful.
Old 09-03-2019, 08:20 PM   #66
lummert
lummert's Avatar
Yesterday I swapped the BMW coolant temp sensor for the correct LH 2.2 sensor with blue connector. This made an improvement in the idle quality.
Bosch 0 280 155 811 injectors
BMW 320i 2.5 Bar (tests at 2.7 Bar) fuel pressure regulator.
Old 09-06-2019, 09:30 PM   #67
lummert
lummert's Avatar
Note to self: Get rid of all BMW fuel system parts so that I don't keep trying to use them expecting a different result.
Today I swapped back to the GM 3 Bar fuel pressure regulator. With the BMW FPR the mpg's were worse and the car seemed under powered. Guessing that these Bosch Gen III injectors which are rated at 36 lb/hr at 4 Bar aren't very efficient at less than 3 Bar.
Fuel flow calculator shows:
Old fuel flow: 42 lb/hr at 58 psi (441 cc/min at 4 Bar)
new fuel flow: 36.38 lb/hr at 43.5 psi (382 cc/min at 3 Bar)
These same injectors are used in GM LS3 at 4 Bar (58 psi).
Old 10-11-2019, 09:36 PM   #68
lummert
lummert's Avatar
Found best running with these injectors is with:
Bosch 0 280 160 226 2.5 Bar FPR from BMW 318i
Bosch 0 280 130 023 coolant temp sensor with white insulator from BMW. Replacement may have green insulator. Has narrower tolerance than 0 280 130 026.
NAPA interchange for Bosch 0 280 130 023:
NAPA ECH TS5520 for 1984 Volvo 760 (black insulator)
NAPA MPE TS5520SB for 1984 Volvo 760 (white insulator)
1950 Ohms @ 77 degrees F
225 Ohms @ 200 degrees F
0 280 130 023 was used in:
Alfa Romeo
BMW
Bentley Turbo R
Bertone X-1/9
Chevy
Datsun
Ferrari
Fiat
Ford
GMC
GEO
Honda
Hyundai
Infinity
Isuzu
Jaguar
Kia
Lancia
Mazda
Mercury
Nissan
Opel
Peugeot
Pininfarina
Pontiac
Porsche
Renault
Rolls Royce
Saab
Subaru
Suzuki
Toyota
Triumph
VW
Volvo
Yugo
Old 10-24-2019, 06:40 PM   #69
lummert
lummert's Avatar
BMW temp sensor and 2.5 Bar fuel pressure regulator going well.
Tested the fuel pressure or BMW 2.5 Bar FPR with tester. 36 psi with vacuum connected. 39 psi with vacuum disconnected.
Old 11-02-2019, 07:28 PM   #70
lummert
lummert's Avatar
Wind and cold weather with this combo averaging 20.6 mpg.
Old 11-16-2019, 09:48 PM   #71
lummert
lummert's Avatar
Update:
Car was running fine in decent weather. As soon as it got colder the MPG's dropped to 18. When it was cold outside it seemed to have less power when pushing against the wind. I had also noticed that if I passed a vehicle black smoke would roll from the exhaust. I had looked around in my stash and found 2 more coolant temps sensors with the correct blue connector for LH2.2.
Today it was nice enough to try swapping the coolant sensor. It was 43 degrees F outdoor temp. I connected the DMM to the blue sensor and I got a reading of 2960 ohms. I connected the DMM to the BMW sensor with the white connector. I got 4560 ohms and still climbing. I took that to be the result of a failed sensor.
Old 12-03-2019, 01:52 PM   #72
lummert
lummert's Avatar
Update: Here we are again. After still having the issue that car runs like a fair weather car (good during good weather, not enough power when driving against the wind), I swapped back to Bosch 3.0 Bar FPR from Buick 3.8 V6..
Now 0 280 155 811 injectors 34 lb/hr at 3 Bar, using correct ECT sensor for LH 2.2, and 3.0 Bar FPR. Was able to set baseline fuel mixture.
Thinking the issue with using FPR for BMW was fuel pressure at idle (36 psi) was similar to idle fuel pressure with 3.0 Bar FPR, but, the rising rate didn't supply enough fuel pressure (39 psi) at lower vacuum reading.
Making short out of town trip this afternoon. Will be able to test for cruising power going both directions.
Old 01-15-2020, 02:52 PM   #73
lummert
lummert's Avatar
Update: No matter what I try the Bosch 0 280 155 811 injectors just won't work at 3 Bar when running LH2.2. Had issues with cold start and what seemed like flooding during warm restart. also had issues trying to get a decent idle. Seems that it was causing the exhaust to bang against the underside of my 88 765.
Tried another 3 Bar FPR with no improvement.
Swapped back to the BMW FPR and idle is good, no hard cold start, no flooding on warm restart,
I'm trying richer baseline setting with the AMM POT screw. I'm up to 301 Ohms now. My math says I can go as high as 333-350 ohms on the basis of initial baseline setting of 385 Ohms. Based on 11-17% increase in flow rate.
