Old 11-04-2018, 05:30 PM   #1
955IsAlive
Default Avoiding Boost Spikes B5254T2 \ K24 \ Stock ECU
I have a burned valve and a worn turbo in our XC90 2.5T.
Decided **k it, I'll drop a K24 in there and get a tune. But it'll be a few weeks before I'll be able to get that done.
I want to be sure I don't send the rods out the block. From what I understand, the stock ECU map won't react quickly enough to avoid the spikes.
Would looping the pipes at the TCV to keep the turbo at wastegate pressure help?
955IsAlive is offline   Reply With Quote
Old 09-03-2019, 03:21 PM   #2
955IsAlive
Update..... K24 appeared to be well within adaptation of stock ECU and it had no issues whatsoever managing boost with it.
I had R injectors and MAF on there and fuel trims are showing -19% or so. It's got plenty of fuel. I have about 6000 miles on it so far.
If for some reason you felt compelled, or had to for a short time, I suspect the K24 with stock MAF and injectors would be within adaptation of the ECU, even though the K24 flows a bit more at a given PSI compared to the TDO4-14T. I may validate that theory before I get it tuned.
