Old 06-28-2019, 08:22 PM   #1
TR Conn
TR Conn's Avatar
Default M41 into a Duett
I started measuring and researching how to install an M41 behind the B20 in my ’58 Duett. I didn’t expect it to be easy, but the modifications to the trans tunnel look like quite a challenge. I need to keep the removable inspection cover if I ever want to remove the transmission.
I also found photos on Garaget that make me think that frame mods are also necessary.
Does anyone have experience doing this?
My fabrication skills are mediocre and I’m afraid of botching it up.
Unlike the PV444 and PV 455 the Duett has a “real” frame.
Would I be better off re-gearing the Dana 27 rear end (4.56 -> 4.10)?
Thanks for any insight or information
TR
Feedback thread:
http://forums.turbobricks.com/showthread.php?t=246561
TR Conn is offline   Reply With Quote
Old 06-28-2019, 10:26 PM   #2
How about an aftermarket overdrive unit installed in the rear section? Between the x frame section and the diff?
Old 06-28-2019, 10:54 PM   #3
The Librarian
We didn't have to do any frame mods to the P210 that we installed a J type M41 into. I wish I had pics but the hard drive they were on died 20 years ago. That truck got a custom fuel injected B20 using SU style throttle bodies, 4 wheel power disc brakes using 1800E calipers and rotors up front and complete rear end. The booster and master were reverse mounted under the drivers floorboard and the clutch linkage was converted to hydraulic.
I think the trans is sitting a little low in the Garaget pics. The driveshaft is definitely too close to the frame.
Old 06-28-2019, 11:03 PM   #4
TR Conn
TR Conn's Avatar
An aftermarket OD is a possibility, but I have an M41 sitting on the bench that I just finished going through.
Looking at aftermarket ODs, it seems that most all of them are for high power hot rods and are beyond my hobbyist budget.
Old 06-29-2019, 03:46 PM   #5
The way I heard it is that the D type BARELY fits, but the J type needs tunnel modifications.
Old 06-29-2019, 04:07 PM   #6
planetman
planetman's Avatar
Here are some pictures of the 1961 P210 hiperauto and I modified.
We used an M41 with a J O/D and we had to modify the tunnel and IIRC, the modified portion was behind the removable cover.
Don't forget the adaptor that connects the O/D to the transmission puts the O/D back farther than the stock output flange location.
Eric
Torrance, CA 90502
Old 06-30-2019, 12:20 PM   #7
volvorelix
My wife's 445 has an M41. The conversion was exactly as hiperfauto and Eric describe.
No frame mods.
Cameron
Portland
volvorelix is offline   Reply With Quote
Old 06-30-2019, 02:16 PM   #8
TR Conn
TR Conn's Avatar
Cameron,
Do you happen to have photos of the tunnel?
Old 06-30-2019, 03:11 PM   #9
JohnMc
JohnMc's Avatar
I put an M41 in my 544, but as already mentioned, it's pretty much entirely different. I had to replace roughly the same section of tunnel though. I think the 544 floor pans are just a bit deeper/lower vs. the drivetrain than a Duett's.
'63 PV Rat Rod
'93 245 16VT Classic #1141
Old 07-02-2019, 04:36 AM   #10
volvorelix
Originally Posted by TR Conn View Post
Cameron,
I'm sorry - I don't. The cuts I made were very similar to the tape outline shown above, and I used a second removable tunnel lid to make the 'new' section of tunnel.
Once you get past the first cut, it will come together more easily than you expect.
Cam
Old 07-02-2019, 11:52 PM   #11
TR Conn
TR Conn's Avatar
Thanks for the words of encouragement. I’ve been fabricating a new tunnel before cutting anything.
I’ve swapped M41s into two automatic 122S’s without much forethought. Duetts are quite a bit harder to come by.
Old 07-10-2019, 11:52 AM   #12
TR Conn
TR Conn's Avatar
I ran into a bit more of a project than anticipated.
The PO had screwed and pop riveted "new" floorboards in.
I already knew this was a problem, just didn't want to deal with it right now.
Old 07-12-2019, 07:08 AM   #13
slow240
Home Schooled
slow240's Avatar
I'm following this because I also have a '58 duett and my short list of modifications includes an m41, and disk brakes.
I'll polish your face
Old 07-12-2019, 08:44 AM   #14
JohnMc
JohnMc's Avatar
122 discs go on pretty easily, only issue being that 122 rotors and calipers aren't all that easy to find these days, and new replacements ar pretty pricey.
Old 07-12-2019, 07:16 PM   #15
TR Conn
TR Conn's Avatar
If you are going to install disk brakes, go all the way and include a booster.
Another possibility I considered was the remote boosters made for drum brakes. I don't know of any one that has used one. I had most of the necessary parts on hand for the disks and found a NIB Lockheed booster for $110 on ebay.
I'm on a deadline for the transmission/floor project. I'm taking this car to San Luis Obisbo for the show in September.
Old 07-12-2019, 07:28 PM   #16
Bosozoku_Volvo
Bosozoku_Volvo's Avatar
i dont remember the guys name for some reason, but theres a guy sorta near riverside with a YUUUGE yard of old volvos. i was gonna go to him for a driveshaft for my 66 122, but ended up selling the car. great guy.
post on the San Diego Volvo Sports America facebook page and mention that, theyll know who you (OP) need to talk to
just call me "CA$H MONEY"
Bosozoku_Volvo is offline   Reply With Quote
Old 07-12-2019, 08:24 PM   #17
planetman
planetman's Avatar
I think I know who you're talking about, but if it is, that source is no longer available. Believe it or not, the local government got on his case for having an unauthorized junkyard and he wound up dumping just about everything. Even though you couldn't see the site from ground level because it was in a small gulch/valley, they used pictures from an airplane or helicopter to justify their actions.
Was the guy's name Terry?
Old 07-12-2019, 08:35 PM   #18
planetman
planetman's Avatar
Yes, the parts are pricey, no they are not hard to find.
VP now sells repro brake rotors and drums for $100.00 each. They aren't made the same way Volvo STILL makes them, but they are a lot cheaper.
VP also sells repro 3 piston calipers now, but I still prefer to have my old cores rebuilt. I try to keep a set of rebuilt calipers in stock as it sometimes takes over a week to get them back from the rebuilder. And in fact, I just sold the set I had in stock 2 days ago.
Old 08-27-2019, 06:06 PM   #19
TR Conn
TR Conn's Avatar
I have the M-41 in and working, new floors looking pretty good and everything else back together.
Turned out to be quite a project.
I was able to cut out part of the trans tunnel, reshape it and reinstall it in order to provide clearance for the overdrive.
Before:
After:
Old 08-27-2019, 09:32 PM   #20
Looking good.
