Old 08-20-2019, 10:41 AM   #1
redblockpowered
redblockpowered's Avatar
Default Making a 940 handle
Last weekend, I autocrossed my 944 for the first time and found the chassis to be... sloppy, to say the least. Turn in was limp wristed and it felt like all the car wanted to do was load the outside front tire and plow. What have you guys done to dial out some of the understeer? Specifically looking more for autocross/trackday experience as I'm not building a race car and I don't trust that handling limits can really be pushed on the street. Right now the car is as I bought it save a pair of Bilstein Tourings and overload springs in the rear.
I sell chips for LH 2.4!
Old 08-20-2019, 10:43 AM   #2
https://www.bneshop.com/collections/...e-strut-mounts
get a set of these and dial in a good alignment (as much - camber as you can manage)
and a slight toe-in
www.BEIGEPOWER.com
Kaplhenke Racing Facebook
The only safe bet is Ben.©
Old 08-20-2019, 11:05 AM   #3
rb92673
Ben's stuff is super nice and I have seen cars on the track with his stuff kick ass.
If you want to add camber and castor for cheap, you can move the strut mount and redrill the front holes. Cost $0.
http://forums.turbobricks.com/showthread.php?t=208119
Old 08-20-2019, 04:27 PM   #4
sbabbs
sbabbs's Avatar
Yeah camber mod and upper and lower strut braces and front IPD bar and kerplunky end links on the bar. I just did all that on my 95 940 turbo wagon. Makes it handle way better.
1995 940 White racing wagoon. T25 .64 a/r m90 to put in
Old 08-20-2019, 05:37 PM   #5
2manyturbos
Learn to trail brake late into the corners and you will eliminate some of the understeer.
Old 08-20-2019, 07:07 PM   #6
mikep
The MP
mikep's Avatar
What class?
Old 08-20-2019, 11:14 PM   #7
gsellstr
gsellstr's Avatar
Definitely do the Kaplhenke camber plates early on. Those not only allow for camber but they greatly reduce the binding when loading the suspension. No other changes on mine at that time, the difference was tremendous. Good springs and struts/shocks will go a long ways as well as bars.
RIP
Nick Fengler "fengler" 8/6/18
74 144 B20
90 745Ti
Old 08-21-2019, 07:23 AM   #8
redblockpowered
What class?
My car's in SM because of the M90 so I needn't worry about getting classed up. However I'm not planning on making a real race car out of it, just a more autocross/trackday friendly street car.
Old 08-21-2019, 08:51 AM   #9
shoestring
shoestring's Avatar
Run the SMR230.
Old 08-22-2019, 10:27 PM   #10
lummert
lummert's Avatar
My 88 765T has 24mm front bar from 92 960 sedan and 19mm rear bar from 87 760 sedan. 5mm difference front to rear. Fairly good balance but not into racing it.
Old 08-22-2019, 11:02 PM   #11
sbabbs
sbabbs's Avatar
Ohh yeah IPD poly front strut rod bushings. Don't forget those..
Old 08-26-2019, 11:26 AM   #12
JE Jr
JE Jr's Avatar
The 2 diferent chassis braces on the following link is a very nice upgrade! The ones pictured are Volvo Original but there are aftermarket too.
The lower 2 small braces are fitted to all 960 95- and S/V90 if you have a local salvage yard. The upper brace Im not sure if it ever was fitted to US-spec cars?
https://www.garaget.org/forum/viewto...07850#p3907850
White car: --744 GLE ´88-- Polishing object
Black car: --S80 V8 ´07-- Daily driver
www.garaget.org/JE_Jr
JE Jr is offline   Reply With Quote
Old 08-26-2019, 02:34 PM   #13
gsellstr
gsellstr's Avatar
I was just getting ready to mention those 960 braces. They are cheap new but easy to find at the yards as well. The W brace helps a little but going with something that triangulates the front end, between the radius rod mounts and the center of the front crossmember makes a much bigger difference, especially under braking. The side to side is a little better, but without that brace on mine the front end feels like mush since I'm used to having a lower brace on there.
Old 08-26-2019, 11:26 PM   #14
deadken
Originally Posted by shoestring View Post
Run the SMR230.
Please elaborate...
deadken is offline   Reply With Quote
Old 08-27-2019, 07:45 AM   #15
shoestring
shoestring's Avatar
Originally Posted by deadken View Post
Please elaborate...
It's the #230 Swedish Mafia Racing 245 LeMons car. Dormant, but pretty successful and in the garage.
