Old 08-21-2019, 05:32 AM   #1
Fretka
Fretka's Avatar
Default B200FT/B230FT - What turbo?
Ssup guys,
Long time haven't had that pleasure to read heart warming comments on TB
Running TD04 16T right now at about 1.4-1.5bar and I think it's time for something a little more modern than the old hotbox.
Setup:
B200FT (probably switching to B230 bottom sooner or later)
Stock 530 head ;(
ENEM V15 cam
Adjustable cam gear
EVO 510cc injectors
3" exhaust
Cold air intake with no MAF
Bigass IC
Megasquirt ECU with Ford 4cyl coil pack
Future upgrades:
Exhaust headers
Something with the poor intake or 530 head (maybe 531)
Rods
Car is pushing about 230bhp with that setup right now, which makes me kinda sad, since "achieving 300hp goal is easy peasy".
Goal? Anything that is drivable with the setup mentioned before (boost builds up proper fast) but can supply up to, lets say, 400bhp.
Since I know precisely zero about turbos (GT243958XXHYBRIDCOLDAIRSCANIABLABLA 0.45823405 TRIM 2340ajgdsgnlfvb) some kind of ultra-beginner intro would be nice.
Ofcourse, going the cheap china ebay choo choo way because of budget.
Three cheapass turbos for example:
https://www.maxpeedingrods.co.uk/uni...bocharger.html
https://www.maxpeedingrods.co.uk/t25...71-gt2860.html
https://www.maxpeedingrods.co.uk/t3-...bocharger.html
Thanks in advance.
Mexipoku - custom low budget suspension solutions
Fretka is offline   Reply With Quote
Old 08-21-2019, 07:02 AM   #2
Sjeng
Sjeng's Avatar
I want immediate spool, and the potential for 800 hp on my 1965 tractor engine.
And above all, it should only cost about 45 dollars shipped.
You have to realize that this turbo does not exist.
It is always a tradeoff between power, response and cost.
Want response? Good, keep your mitsu.
Want power for cheap? HY35, T3/T04E, etc.
Want power and response? Twin scroll manifold with a nice Borg Warner turbo $$$$$$$$
Old 08-21-2019, 07:07 AM   #3
Fretka
Fretka's Avatar
Yes, thank you.
Problem solved, case closed, we can lock this.
But really I am just looking forward to understanding how to pick a turbo, because there are many people on threads like these telling "i have the hx35, it spools nicely and boosts really good", which gives me pretty much nothing. I have seen plenty of swedes pushing 500hp out of 8v 230 redblocks with different turbos.
And if that would be that one and only super expensive borgwarner turbo, which one would it be? You are saying that there is no chineez turbo that could be close to that one regarding specs?
P.S. - giving comment (or comparing to 16t or something) on the turbos seen in links above would be helpful as well
Old 08-21-2019, 01:25 PM   #4
GT3071 or anything in the 60/55mm turbine wheel range will work well. Get something with the smallest compressor wheel possible.
Old 08-24-2019, 02:35 AM   #5
Tentshedtrev
Tentshedtrev's Avatar
I'm really happy I spent a bit of time adapting a k24 off an s60r onto the latest 244 +t I did. Very decent response, cheap, and should breathe enough for a easy enough 300 something with supporting mods.
I'd call it very drivable, have yet to hear concrete facts on the HP they would run out of puff to support, I think there was a compressor map posted a while back that would help answer that. Few whiteblock guys are making some big claims with aftermarket compressor wheels and such..
Life is too short to stay redblock..
1990 740 SE, Eaton m90 supercharged b230F drift car
1983 242 turbo t5 whiteblock swap (in progress) (He351, MS3x, WC T5)
1983 244 (on blocks, currently parts storage)
1989 244+t k24 turbo, npr, rsi stage 3, chipped 954 and 207 ezk, and other dodads
1990 245 Mitsubishi 4D56 turbo diesel km132 transmission, water/meth
1983 245 m46 b230f Stahl header Toyota 4age ITBs MS2extra
Tentshedtrev is offline   Reply With Quote
Old 08-26-2019, 05:58 AM   #6
Fretka
Fretka's Avatar
Thanks for reply. Any comment here is helpful.
I have not heard about K24 before. Will look into it.
To make this thread (maybe) more clear, let's set the goal to 350bhp.
Old 08-27-2019, 05:10 AM   #7
Fretka
Fretka's Avatar
Looking for some dyno sheets or at least videos of pulls with B200/B230 + GT35 turbo. Looks like with proper mods it should fully spool up below 5000 rpm. By increasing rev limit to 7k rpm that should feel fine in between 4000-7000.
Old 08-27-2019, 09:33 AM   #8
Your engine will be out of breath by 5000 no matter what turbo you put in it.
Old 08-27-2019, 02:20 PM   #9
Fretka
Fretka's Avatar
Why so? As mentioned before, custom exhaust headers, ported head and custom intake manifold.
Old 09-05-2019, 08:20 PM   #10
aaron740gl
aaron740gl's Avatar
With current mods and future mods planned, i would suggest what harald said.. GTX30xx or similar bw would be perfect. Dual bb and a .82 divided housing with a proper twinscroll header; perfect recipe for new goals. Capable of 2bar if needed.
91' 744se with some stuff done to it
aaron740gl is offline   Reply With Quote
